MAN6760 Datasheet
Re: MAN6760 Datasheet
Hi jecci - sounds like you're talking about PCB design software...? What program is it...? Might need to ask this on their forum or contact their tech support as I'm not sure if you'll find many people trying this on SOS.
My favourite link for unknown semiconductors is here:
https://www.alldatasheet.com/
- Folderol
Forum Aficionado -
Posts: 20314 Joined: Sat Nov 15, 2008 12:00 am
Anything that's just a pdf or an image file won't contain a suitable CAD file.
That's the sort of thing the manufacturer would normally provide. You've probably got the dimension data in the pdf datasheets to draw up your own CAD file for it (assuming that if you are using a CAD PCB layout program you can draw a simple CAD drawing with eight correctly spaced solder pads on it).
