Personal monitor suggestions please.
Post by Emmet »
Hi all, recently had a play on a friends TC Helicon VSM300 personal monitor and would love one but sadly they don't make 'em anymore.
https://www.bhphotovideo.com/c/product/616741-REG/TC_Helicon_996_540011_Voice_Solo_VSM_300XT_Active.html
So, I'm after an alternative but like the TC it needs to be *very* compact (there's only so much space in our band vehicle) and needs to be loud and clear. Any suggestions?
Thanks in advance.
Emmet
Posts: 169 Joined: Fri Jul 26, 2002 12:00 am
Re: Personal monitor suggestions please.
Post by The Korff »
A few options off the top of my head...
There's a new TC thing, TC Helicon VoiceSolo FX150, that's a similar format but includes effects, both for monitoring and to 'pass through' to front-of-house, though it looks a bit bigger than the one you mentioned (wider anyway, if perhaps a little shorter).
Then there's the Mackie SRM150, which is another stand-mounted mini monitor thing (I forget what it looks like in the flesh though, it may be a bit too big for your needs), and finally Galaxy Audio do a few boxes in a similar format:
http://galaxyaudio.com/products/categor ... t-monitors
Some of those are very dinky indeed!
Cheers,
Chris
The Korff
Posts: 2279 Joined: Fri Jan 08, 2010 11:28 am Location: The Wrong Precinct
Post by Dave B »
I've used the Mackie SRM150 for years and they are great. One band I play in has the Behringer equivalents and they are fine, but the Mackies do sound a little bit better. I dep in a band where the guitarist uses the TC one (VoiceSolo) as Chris (also) mentioned and that's good as well.
So, everything's basically good .. ;)
I will, however, put the cat among the pigeons and suggest moving to a wired in-ear solution. I now have an aux from the desk going to a headphone amp and then to me and it's the best sound that I have had in gigs. Plus, with good earbuds, you can keep the volume levels under control and that's _really_ good for your hearing.
Just my 2c....
Dave B
Posts: 5935 Joined: Thu Apr 03, 2003 12:00 am Location: Maidenhead
Post by Music Wolf »
Dave B wrote:One band I play in has the Behringer equivalents and they are fine, but the Mackies do sound a little bit better.
I have one. It is a little plastic box and, on its own, it's horrible but on stage it cuts through the mix and works surprisingly well.
Music Wolf
Posts: 2894 Joined: Fri Feb 17, 2006 12:00 am Location: Exiled to St Helens
TC VoiceSolo fx150 here (I have two). Great little box, sounds superb and the fx are lovely. I would happily use it as an acoustic guitar combo too if I didn't already have an AER. It's nearly as good and ¼ of the price.
Posts: 22904 Joined: Thu Jan 23, 2003 12:00 am Location: Manchester UK
