A Rare Visit Here... getting an iPad to interface with Windows...
For all other computers and operating systems, including Atari, Linux and mobile apps.
Post by Mike Stranks »
Mutter, mutter... grumble, grumble... :protest:
Just spent the best part of two hours trying to transfer a group of PDFs from my Win11 PC to my iPad... Worked out a 'fudge' in the end with the help of Mrs S who needs to do this much more often... but the whole process was as user-friendly as a cornered rat...
Before anyone says 'iTunes'... I explored that option and still got nowhere...
Does it really have to be so tortuous...?
Mutter, mutter...
Mike Stranks
Posts: 10585 Joined: Fri Jan 03, 2003 12:00 am
Re: A Rare Visit Here... getting an iPad to interface with Windows...
Post by Kwackman »
I don't have a PC but would email as an attachment or Dropbox/wetransfer not work?
Kwackman
Posts: 3456 Joined: Thu Nov 07, 2002 12:00 am Location: Belfast
Post by Bob Bickerton »
I wondered if Airdrop would work on a PC, but apparently not. A similar app is Airdroid, though I haven’t used it. Download the app to both devices and transfer over wifi. There’s a cost of course, but it’s cheap enough: https://www.airdroid.com/pricing/airdroid-personal/
This article offers solutions too: https://www.airdroid.com/file-transfer/ ... ut-itunes/
I’ll often simply email files to myself if I can’t Airdrop.
And it’s probably worse going from iPad to PC ;)
Edit: Davey’s suggestions will work fine too. Depends on how many files and how often I suppose……..
Bob Bickerton
Posts: 5356 Joined: Fri Dec 20, 2002 12:00 am Location: Nelson, New Zealand
Kwackman wrote: Wed Sep 14, 2022 12:11 pm I don't have a PC but would email as an attachment or Dropbox/wetransfer not work?
Yup!
That was my 'fudge'!! :)
Mike Stranks
I use an online file host which is accessible from any phone/tablet/computer that is online — Dropbox in my case.
Posts: 41725 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Kwackman »
Mike Stranks wrote: Wed Sep 14, 2022 1:02 pmThat was my 'fudge'!! :)
If sending files via email or a dropbox type system is "tortuous" and a "fudge", you must have had a very charmed computer life to this point! :D
Glad you got sorted though. :thumbup:
Kwackman
Post by resistorman »
Kwackman wrote: Wed Sep 14, 2022 3:28 pm If sending files via email or a dropbox type system is "tortuous" and a "fudge", you must have had a very charmed computer life to this point! :D
:lol: indeed.
Also, I would not recommend iTunes on PC for ANYthing, it is the Work of the Devil.
Getting data in and out of an iPad to a PC is a horror, and it used to be much worse. I don't know if there is a way to directly connect it. I use Microsoft 365, but Dropbox works a bit better.
resistorman
Posts: 2869 Joined: Sun Nov 22, 2015 12:00 am Location: Asheville NC
Thanks all!
The answer is... GoogleDrive Offline Mode... (I'll be using the iPad where there's zero Internet access...)
Mike Stranks
Post by MarkOne »
iCloud Drive seems to work OK for me here, obviously it's native on the Mac and in the later iOS incarnations, and on Windows too.
Transfers are basically drag and drop
MarkOne
Posts: 2988 Joined: Thu Feb 15, 2007 12:00 am Location: Bristol, England, Earth, Perseus Gap, Milky Way
My Music on Apple Music
My Music on Spotify
Post by sonics »
resistorman wrote: Wed Sep 14, 2022 3:46 pm
I have to agree with this. I have forty years of tech experience and find the whole file management system on iOS very difficult. It just doesn't work for me. I'm not happy in an icon-only world; I like menus and text boxes!
I've found cloud storage (I use Box), Documents (by Readdle) and iCloud installed onto the PC will get me the results I need. I've also just bought a lightning to USB cable to experiment with transfer to a flash drive.
sonics
I seem to remember writing about my similar problems on a quick and foolproof way to transfer files from my iPad to my PC via a direct cable connection, rather than faffing about sending myself email attachments or download links, and subsequently discovered a PC app that let me do this.
Unfortunately, its name just doesn't trip off the tongue, so the last time I needed it I spent ages wading through folders trying to find it, and am currently doing exactly the same thing.
When I've found it again I'll post its name here - this makes perfect sense, since I next time I need it I can look up this post to see what it's called :headbang:
Posts: 21476 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
OK - found it. It's AOMEI MBackupper Standard (Free version) - or at least it was, read on...)
It seems that others may have had the same naming difficulties as me, because when I just launched AOMEI MBackupper Standard 1.9.0, it informs me that a free update was available and on visiting the website it states:
"Starting from version 2.0, AOMEI MBackupper has been renamed to FoneTool"
Since it's designed for easy transfer of files between iPhone, iPad and PC, perhaps I'll remember this name more easily ;)
So, belay that previous information - I'm actually now recommending FoneTool
https://www.ubackup.com/phone/campaign/ ... rsion.html
Can I say again that whilst I haven’t tried the Airdroid app mentioned earlier (https://www.airdroid.com/pricing/airdroid-personal/) would appear to solve all these problems enabling two way drag and drop of files between iPad and PC over WiFi.
Can anyone comment on this? Could be the perfect solution.
Bob Bickerton
Meeting was this evening... Google Drive Offline was fine and I could access all the PDFs in a non-connected environment...
Mike Stranks
Post by RichardT »
Mike Stranks wrote: Wed Sep 14, 2022 10:52 pm Meeting was this evening... Google Drive Offline was fine and I could access all the PDFs in a non-connected environment...
I use Google Drive myself as a low tech but workable solution - particularly as it shows up as a share destination in iPadOS, which makes it relatively easy to use.
RichardT
Posts: 4897 Joined: Fri Aug 13, 2004 12:00 am Location: UK
DropBox, Box, OneDrive, iCloud Drive, Mediafire, pCloud, Google Drive, Mega... any of these will allow you to share files across platforms for free.
Posts: 20925 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Well, ****me! I don't know macs and I never had any kind of iThing but I always thought .pdf files were universal.
Posts: 17905 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by Kwackman »
ef37a wrote: Fri Sep 16, 2022 4:41 pm Well, ****me! I don't know macs and I never had any kind of iThing but I always thought .pdf files were universal.
They are. (Mac & iPad user)
Kwackman
Post by shufflebeat »
I've been using Drive for quite a while with no idea there might be a compatibility issue.
For instance, I upload from the PC to Drive on a browser, open the Drive app on iPad, download, then "open with/in..." a pdf app I was introduced to while studying, EZpdf.
Since the introduction of the Files app there are more options for storage and perusal on the iPad but I tend not to bother.
shufflebeat
Posts: 9639 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
Post by adamburgess »
iTunes has always been an abomination on a Mac. Can't imagine the torture with Windows!
I don't transfer stuff that often, but AirDrop (and the ability to copy/paste :clap: ) between Apple devices is really great if you're in a hurry. Overall, totally agree that the iOS filing system is so clunky! Adobe Acrobat I use for charts and things, and is always ok - but, still seems crippled by the OS.
adamburgess
Posts: 185 Joined: Sat Nov 03, 2018 12:18 pm
The issue is, Dave, transferring them from a Win 11 machine to an iPad... you can't just drag 'n' drop... It's not the PDF format that's the problem... it's transferring any files in that direction...
Mike Stranks
Mike Stranks wrote: Sat Sep 17, 2022 4:36 pm
Oh, I see, (not really). Bluetooth?
In a further development...
I'm currently doing some experiments along the lines of, "What's the absolute minimum kit I can use to get an acceptable video record of an event?" Today's experiment was based on my iPhone 11...
"Easy-peasy" thinks me. "I transfer photos between the phone and my Win 11 machine all the time using a cabled connection."
But Apple thought differently. It wouldn't contemplate dealing with a 5GB video file either by cable transfer or upload to Googledrive.
A helpful little app called FoneTool got me sorted...
30 years ago I spent significant amounts of my working day working out how to get disparate computer system to talk to each other. Progress does not seem to have been so quick in this regard as it's been in other areas of computing... :lol:
Mike Stranks
Mike Stranks wrote: Sun Sep 18, 2022 7:50 pm "Easy-peasy" thinks me. "I transfer photos between the iPhone 11 and my Win 11 machine all the time using a cabled connection."
That's the little app I was recommending further up this thread - works great for me! :thumbup:
