hello chaps,
i am trying to get my Focusrite 828 to Connect to my Digi 002 via optical cable so i can by pass those dull preamps the 002 comes with, and i cant get a sound in on Pro tools , also i thought by connecting my 8228 i would see 8 Digig inputs in pro tools , one for each pre amp running at 44.1, but i still only see a pair of spdif inputs,
the cable i am using is the optical cable that came with a cd player, is this the problom? should i be using a optical cable that is multi channel or "ADAT" if so this would explain whay i cant hear nor can see any extra channels
thanks
steve
lightpipe??
lightpipe??
- Steve honest
Poster - Posts: 81 Joined: Sun Dec 26, 2004 12:00 am Location: London,England
no animal ever called me honey
Re: lightpipe??
Hi there,
I have been told that to connect multi channel equipment via lightpipe it has to be an "ADAT" type multi channel optical cable and that consumer cables won't work. I just hooked up my ADA8000 to my Motu 828 a few weeks ago. I ordered a one meter Leisure Lynx Fibre Optical Cable (part number OLC100) for 8 pounds and it did the trick.
Hope that helps,
Enjoy your new gear and happy mixes,
Jay
Hope that helps,
Jay
Re: lightpipe??
Sorry, but this is nonsense.
There is absolutely no difference between an 'ADAT-type multi-channel' optical cable and a consumer optical cable.
notefarm wrote:Hi there,
Re: lightpipe??
Hi Steve
Have you selected the ADAT inputs in the Digi 002 software?
'Lightpipe is Lightpipe'! - only difference is the quality of the cables but any will work provided they have the right type of connector on the end
Cheers
Anton
Cheers
Anton
- BoogieBear
Poster - Posts: 85 Joined: Tue May 01, 2001 12:00 am Location: Anglesey UK
You see when I was a young kid Elvis was top of the charts - That's 'Presley' not Costello!
Re: lightpipe??
BoogieBear wrote:Hi Steve
Cheers
Anton
HI Anton
well its not lisitng the adat inputs in the input button on the channel, and i have looked at the i/o drop down menu and i cant seem to find a path for them there , and also in the hardware tab i cant find a button for adat there either, there is mention of spdif, but i toggled that hoping to make something happen ,
is there another place i can look for these adat inputs?
thanks
steve
- Steve honest
Re: lightpipe??
Hi Steve
Sorry but I'm not familiar with the Digi 002 but from what you say you may need to update/re-install the drivers
If you have the manual read through the section on selecting inputs - is there a hardware switch any where on the unit - on the back maybe?
You might need to get some 002 help off the user forums for that piece of kit
Cheers
Anton
Cheers
Anton
- BoogieBear
Re: lightpipe??
hi chaps
thanks for all your kind suggestions, i just got it working , in hardware set up , it would offer me adat button if i was in 44.1 or 48 k, but no higher, which is a bummer because i like to work in 88.2 almost all the time!!!
i wonder if this is a limitation of pro tools LE and the 002 that it only offers adat in the lower resoloutions?
but thanks agin for your help , im now enjoying my dreadful voice , thru my lovely preamps
steve
steve
- Steve honest
Re: lightpipe??
ADAT only works at 44.1 or 48K, over a single light pipe.... higher sample rates require multiple optical connections using a standard called S/MUX , which splits the signal (for Sample rates up to 96 K) over 2 optical cables, 4 channels per cable. which AFAIK the 002 does not have hardware support for....
- . . . Delete This User . . .
Frequent Poster - Posts: 2319 Joined: Mon Jun 23, 2008 12:00 am
Re: lightpipe??
hi idris
i have done a bit of reading up and yes in the abscence of a 2nd hole on the back of the 002, im stuck at 44.1 for the small studio in the house, but still at least i have those lovely ISA preamps to go thru , im just working out how to insert and return me comps and gate now,\
cheers
steve
cheers
steve
- Steve honest
