How do i design a website.....
So i want to design a website, ive never had a bash at designing one before.
Whats the best way to go about this? Should i be looking at flash or HTML? Which is the easiest for a beginner to start with?
Are there any programs ideally free/cheap that can help me along the way?
Tar
Ray
Tar
Ray
Re: How do i design a website.....
HTML
Use the internet to teach you.
Then play with Notepad.
That's what I did.
I will be more helpful soon...
That's what I did.
- Carlospresents...
Poster - Posts: 51 Joined: Wed Sep 01, 2004 12:00 am
Alphajuno wrote:Should i be looking at flash or HTML?
HTML
Alphajuno wrote:Are there any programs ideally free/cheap that can help me along the way?
I don't like to recommend it but Microsoft Frontpage.
Dunno if there is a free/cheap Mac equivalent but to get started, a WYSIWG app is what you want. You CAN do it in a text editor by typing out the HTML but it's a bit daunting if you're an absolute novice.
Steve
- hollowsun
Posts: 2036 Joined: Thu Jan 20, 2005 12:00 am
Website / Music Lab Machines / Blog
Before you do anything with software draw what you want on a big bit of paper... or several. Screens with arrows between them and the things you want on them. This is your design.
If you're going to have any text... draft it before you start coding. Get a look at what you're making. You don't need any software to do that and it will save you buckets of time later.
Then you can look at coding. I'd avoid Flash unless you're building a very graphic/multimedia site. If HTML will do the job (my site is HTML) look up the beginners stuff on the web and you're away.
Think about the information that you are going to present. Think how the user will navigate to it. Concentrate on getting this part right before all the bells and whistles.
Try to keep the content and style separate. Learn a bit about CSS by browsing the demo site Zen Garden.
The complete HTML reference can be found at World Wide Web Consortium.
Try to stick to the free and open standard stuff to maximise compatibility and accessibility. (ie avoid Flash and browser-specific features). Check your site on a variety of browsers/systems.
Consider using some kind of Content Management System (CMS) (or wiki or blogging system) if you are building more than a few pages and want to maintain it - geeklog is one of many many examples.
- TAKEN.BALL.GONE.HOME
Poster - Posts: 15 Joined: Mon Sep 16, 2002 12:00 am
I agree with Rob C,
start with a piece of paper, think about the design first, then go about learning the tools you need to realise your idea. Think of the analogy with music - instead of buying some software and hoping that'll compose for you, get the idea first then get the software that best suits you.
One of the best sites I've seen, or certainly one where the designer has a good approach to website design and maintenance is www.lingcars.com she says "a website is like a pet or a house plant, if you don't feed/water it, it will die" it is an entertaining website if nothing else, and yet uses no Flash Harry techniques
Michael B wrote:One of the best sites I've seen, or certainly one where the designer has a good approach to website design and maintenance is www.lingcars.com she says "a website is like a pet or a house plant, if you don't feed/water it, it will die" it is an entertaining website if nothing else, and yet uses no Flash Harry techniques
And it just goes to show it's a matter of taste - that is a terrible looking site to my eyes
Yep, the site is cluttered to say the least, but the point I was making is that a site should be entertaining, which if you read some of it, and watch the movies, the scat on Top Gear - Chop Gear it really is a hoot.
I compare this with some of the more 'classy' and 'moody' looking really slick and long faced, and they may look good but they tell me nothing. Whereas the site I mentioned, even though I have no intention of leasing a car, had me chuckling away and so I remember the site name after only one visit!
Alas, I do have to admit that in the media industry image takes precedence over substance
Hello,
use iWeb for Mac, very simple, very effective, no need to know HTML or whatever. This is what I did with it, check Apple site for more, you can do a lot more...
http://www.villa.schumann.sizaret.net
Cheers !
Cheers !
It really depends on what you want to do with it. Are you looking to have a blog, many sections and content, and want it easily updatable? If that's the case you should consider using a content management system (CMS) like Wordpress to build your site. If you are just looking for a really simple web presence then starting off with an application like Dreamweaver is a good first port of call. Find a simple (professional) site you like and load it into Dreamweaver. You can split the screen between 'design' and 'code' modes - you'll be able to see how the site is put together and can reverse engineer it. I would do this in conjunction with a beginners HTML book so you know what the code means. Try to develop a site using W3C compatible code and CSS rather than using the old way of structuring it with tables - works better across browsers. Once you get really comfortable with the code you can ditch Dreamweaver and use something like BBEdit or Homesite. I would keep away from Flash for now other than using it for things like an MP3 player (like myspace). At first it can be difficult to understand the code - but do persevere!
Ben
Ben
Also, it may be an idea to get down to the newsagents and get a mag, there are some like .NET that will usually inlcude some giveaway software that will get you started with the basics so that at least you learn a bit about HTML. Once you've understood the concept that a web page consists of code that 'tells' a browser what, where and how to display content, you're off!
To give you an idea, whilst looking at this page....
if you're using IE go to View/Source
or Firefox go to View/Page Source
It'll look quite complex, but loook at each line and you'll see the HTML
Bear in mind this is not a simple basic page
The HTML or Flash Q is like asking 'Addition.. or Calculus?'
- moo the magic cow
Regular - Posts: 224 Joined: Wed Oct 25, 2006 12:00 am
Thanks a bunch everyone for the help.
I shall spend a bit of time this weekend planning what it should look like, followed by a lot of google.
On the issue of webspace, is it best to stick with your ISP or are they more suitable alternatives?
Hi Alpha
KISS
Nice, simple, elegant personal website
Free simple template based software to download and build web pages
PersonalWebKit
Serif Web Plus 6
Web easy Express 6
Online simple strong webpage builder software
Moonfruit £2.99 per moth
Low cost simple strong web page builder
NetObjects Fusion
7 Deadly Sins
Unless a welcome page is doing sometime useful, unnecesary to have one
... cut to the chase.
For increased space & downloadable uploadable allowance, extra email addresses,
less restrictions on what you can put up, more control, far more flexible webdesign,
and a simple domain name eg www.Alphajuno.com or.co.uk or whatever
(not a looong domain name prefixed by your ISP's name)
best to move away from your ISP (also helps look a bit more pro & not a cheepskate
This is low cost & useful (has a website builder too).
http://www.123-reg.co.uk
KISS
PersonalWebKit
Serif Web Plus 6
Web easy Express 6
NetObjects Fusion
7 Deadly Sins
- Pop up ads (93% annoyance level)
- Being required to install extra software to view site content (89%)
- Dead links (86%)
- Confusing navigation (84%)
- Required registration to access content (83%)
- Slow-loading pages (83%)
- Ineffective site search tools (80%)
Alphajuno wrote:On the issue of webspace, is it best to stick with your ISP or are they more suitable alternatives?
- tea for two
Our Imagination take us to wherever we want to be.
https://www.soundonsound.com/forum/view ... p?p=784793
https://www.soundonsound.com/forum/view ... p?p=779531
holy crap, is that your house? i'm coming over for a visit!!!!
nice website by the way!
are you ready to RAWK!!!! / Our first Review!
I have sent you a PM.
- Ian Threlfall
New here - Posts: 6 Joined: Wed Dec 24, 2003 12:00 am
Alphajuno wrote:Thanks a bunch everyone for the help.
Depends on how much space your ISP gives you. Look at how many MP3s you'll be hosting and their total filesize, and see if it'll be sufficient. Here in the states I pay about $10 a month for hosting (have your own www domain and everything), but I'm looking at a UK site that wants 30 pounds a year.
- moo the magic cow
I started, as someone else suggested, by getting Dreamweaver and loading other people's websites to see what they've done. You'll need Photoshop too - and you've got to start thinking in pixels when you size images.
Most web designers do a draft first on paper, then in Photoshop (or similar). That way, you can move elements & colours around and re-size them until you're happy with the layout - then start working in Dreamweaver.
(You can also nick someone else's layout and just change the pics & text to fit your own needs!)
If you hit any problems, just Google a question - you'll find lots of detailed help online.
- Steve Marshall
New here - Posts: 5 Joined: Thu Feb 08, 2007 12:00 am Location: Wiltshire UK
Steve Marshall wrote:I started, as someone else suggested, by getting Dreamweaver .... You'll need Photoshop too....
But that's the best part of £1,000 - Mr Juno wants something cheap/free to get a feel for website creation. I suggested Frontpage because it is free and although it generates horrible code, would let him dip his toe in the water and make something basic to get started.
And Dreamweaver has one hell of a learning curve as does Photoshop (although I would recommend Fireworks as a graphic accompaniment to DW) - probably not what Mr Juno wants/needs just to have a dabble.
Steve
- hollowsun
I would suggest using a free program called NVU. It's available for Mac / Linux / Windows and is a complete Web Authoring System to rival programs like FrontPage and Dreamweaver. I use this as well as notepad and am very impressed with it.
If you are looking for website templates, take a look at these sites:
Open Source Web Design
Open Web Design
Open Design Community
All of these templates are free as they are open source. All you have to do it keep the creators name in the footer at the bottom of the page.
If you are looking for a decent but cheap web host, I recommend the following:Streamline Net. I've been with them for over three years and they have been very good.
Hope some of that helps.
Open Web Design
James Houlston
how about these guys
came across them whilst asking myself the very same question. Anyone any experience?
as far as free HTML editors are concerned, I've been trying to teach myself with this
seems ok so far....
seems ok so far....
I honestly think you ought to sit down calmly, take a stress pill and think things over
Twitter
The HTML Editor at www.coffeecup.com has WYSIWYG and Code views and, as far as I can make out, most of the functionality of Dreamweaver but it's only $49 (£25)to download! There's a free 30-day trial too.
Best price for domain names: http://www.1and1.co.uk
Web hosting: http://www.hartserver.net My website (below) costs £10.60 PA for 100 MB of webspace & 5 GB download. My other website costs £9.09 per year for 50 MB webspace & 5 GB download. So, you could be on the 'net for only about £13! If you wanted to expand later you just need to email them and it's done in a few days. Hope this helps.
Stuart.
Stuart.
- Stuart Churchill
Poster - Posts: 79 Joined: Thu Oct 30, 2003 12:00 am
Birthday Song 4 U. Personalised Birthday Songs
