VST's that sound like Korg Trinity?
Re: VST's that sound like Korg Trinity?
Post by Pitchfork »
Martin Walker wrote:
Pitchfork wrote:Forget the Trinity banks - I think Alchemy is the one!
I agree that Alchemy is the one, but the Trinity banks raise an extremely important point that should be discussed.
Yes you are dead right Martin, that should be stopped - I meant my post from above as in my OP, for the sounds/pads - looks like Alchemy is perfect...
Pitchfork
Posts: 724 Joined: Wed Jun 25, 2003 12:00 am Location: London
I think this thread has begun to highlight a bigger problem for legitimate sample developers being undercut by those who basically grab their content from others rather than create it themselves, and needs wider publicity.
This issue doesn't just result in lower incomes for the good guys who spend a lot more time genuinely developing new sounds from scratch - in many cases ripped off material is not as declared 'copyright free' to use in your own music, and particularly with loops ripped from well-known albums musicians who buy them could possibly get into trouble if they released music featuring them.
Not nice :frown:
Posts: 22580 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by Shambolic Charm »
does alchemy still do resynthesis in the way cameleon did?
Shambolic Charm
Posts: 671 Joined: Wed Jul 13, 2005 12:00 am
Post by muzines »
Much better. And faster.
muzines
Post by Tímo »
Another interesting topic (I remember Feline's, and I'm sure Zukan might too. ;) ).
Regards sampling and legalities, isn't it fine if sampling anything else other than the dry waveforms? Say, several waveforms are layered, programmed, modulated, and with effects over the top - effectively constituting a "patch", all done within the Trinity or whatever ROMpler synth you're using - wouldn't something like this be ok for commercial sample fodder since it's changed distinctly away from the basic ROM sounds? I thought it's just dry waveforms themselves that are protected?
As for the Trinity sound... I still have my Trinity! And incidently I also mainly use it as a pad/strings machine as that's what I feel it does best, as touched on by another user. The EGs and modulation capabilities are great for it, very evolving, particularly when you have combis involved (several patches playing all at once using the same midi channel) and when you're working the ribbon and joystick for its money. The Trinity also has a very clean and airy quality to it, very separated, in terms of 'space' for sounds.
Tímo
Posts: 121 Joined: Wed Sep 25, 2002 12:00 am Location: Derby, England
http://Infekted.org ~ Access Virus news & community
Tímo wrote:Regards sampling and legalities, isn't it fine if sampling anything else other than the dry waveforms? Say, several waveforms are layered, programmed, modulated, and with effects over the top - effectively constituting a "patch", all done within the Trinity or whatever ROMpler synth you're using - wouldn't something like this be ok for commercial sample fodder since it's changed distinctly away from the basic ROM sounds? I thought it's just dry waveforms themselves that are protected?
If you've created those patches yourself using the raw waveforms and the synth engine then this should indeed be OK.
The big difference here is that this particular product is not being advertised as a set of original patches created using a particular synth, but with the slogans:
"Over 300 mb of legendary dance / techno sounds"
"THIS SAMPLE PACK IS A MUST IT CONTAINS MANY PHAT SOUNDS FROM THIS MODULE"
"ITS JUST LIKE HAVING THE REAL THING"
In other words, it sets out to copy the essence of the Korg Trinity for £5.75, even including its photo on the pack shot. Do you think for that price that those 300MB of sounds are original creations?
Post by muzines »
Even sampling *your* patches programmed by you and derived from copyright recordings for a sample library is not ok.
It's essentially the same thing as taking a hit song, using that song, even editing and mashing it up, to create a derivative work, and selling it unlicensed as your own work.
Analog synths are ok, as there are no copyright recordings involved - you cannot copyright analog-generated signals. You can't even (which I think is wrong) copyright your own synth patches, even though they may represent hours of work and skill.
But because romplers are based on recordings, those recordings are copyrightable, and thus you cannot create derivative works on those without a license from the manufacturer.
These terms are always explicitly stated on sample libraries from reputable manufacturers. With musical instruments, like a keyboard, it's a bit more of a grey area as there often isn't a license agreement as such. But the fair, intended use of a musical instrument is to make music, songs and so forth. But using it to generate a sample library from the recordings contained within does not come under the same usage terms, and is prohibited.
muzines
Post by The Pearl Works »
What if I make a sample library from my Petrof upright?
Am I not allowed to sell the library because Petrof own the copyright to the "sound" of the piano which they manufactured?
The Pearl Works
Posts: 192 Joined: Thu Sep 15, 2005 12:00 am Location: North West
Post by muzines »
No, it's quite clear. There are no sound recordings that you are exploiting, therefore you are free to sample it.
The law is quite clear - you cannot create a derivative work from someone else's "sound recordings", as those sound recordings are copyrightable works, unless the copyright owner grants permission or a license to do so.
A piano contains no sound recordings, therefore no problem. A sampled electronic piano *does* contain sound recordings under copyright, therefore a problem.
muzines
Would a sawtooth waveform inside a Trinity be considered a "sound recording"?
The Pearl Works
Post by muzines »
If it's a sound recording, then in theory, yes. If it's synthetically generated by synth electronics, then no.
However, you'd have to be able to prove in court that an infringement of that particular sample was being done, and in the case of a raw simple waveform, that's impractically difficult to do - and if that was all that was being infringed, a manufacturer is unlikely to pursue such an action.
It's the more recognisable stuff that's easier to prove - like when the D-50 came out, then stuff people found exciting was the samples like DigitalNativeDance and stuff. Simple waveforms are easy to get, but those specific unique samples are hard, and consequently they are more eminently sample-able - and easier to prove an infringement of.
BTW I'm not a lawyer or anything, but this is my common understanding of this stuff. I'm not coming at it from the legal side, but from the soundware development side.
muzines
Post by Tímo »
I deplore scammers and pirate leeches as much as the rest of them, but I don't see anything incriminating from the description alone. There's nowhere it states that it samples the dry, raw waveforms of the Trinity.
It could be audio samples of a bunch of programmed, layered, modulated patches or the like, which I don't think would be copyrightable due to being 'performances', turning one thing (the ROM) into something sounding completely different from the individual raw waveforms themselves? In which case yes, a sampled collection of patches could easily be 300mb (if attack and releases are captured, along with evolving modulated filtering, amp ADSRs, effects, etc.), yes, the patches could be made "phat" prior to sampling via use of onboard processing (EQ, effects, etc.), and yes it would still sound like a Trinity because it was achieved using one.
(Incidently, the Trinity was never one for dance sounds. Not sure where anyone could make up 300mb worth of dance sounds from it!)
Tímo
Post by muzines »
Tímo wrote:It could be audio samples of a bunch of programmed, layered, modulated patches or the like, which I don't think would be copyrightable due to being 'performances', turning one thing (the ROM) into something sounding completely different from the individual raw waveforms themselves?
The patches aren't, but as those samples are based on copyright recordings, then yes, the sound recording copyright still applies. Just as if I used a James Brown sample but filtered and envleoped and EQ'd it - it's still using someone elses recording and thus a breach of copyright.
Once again - it doesn't matter what you do to the sounds, the fact that those recordings (ROM samples) are being used to create a new commercial library without a licence is a no-no.
Of course, if the sounds really are totally unrecognisable, then it's going to be difficult to prove in a court, but that's a technicality.
Any synths which use recordings to create their sounds cannot legally be used to create a sample library unless you have explicit permission and/or a licence to do so.
muzines
Spectrasonics has an interesting FAQ about this as part of their Omnisphere docs.
Check the section entitled LEGAL/SAMPLING FAQs a fair way down the page at http://www.spectrasonics.net/instruments/omnisphere_faq.php - it covers a lot of ground being discussed here.
Posts: 9978 Joined: Wed Sep 01, 2004 12:00 am Location: Brighton & Hove, UK
Post by Tímo »
Got ya, so it's termed a "derivative", regardless of the amount of modulation, layering and processing used.
That's cleared things up. :)
Tímo
Post by Neil C »
Shambolic Charm wrote:If they call it 'Kork Trinidy' or something we all know what it means.
The site name ends with a 'Z'. Kind of sets out the stall/pushes the package across the dingy pub table really.
Neil C
Posts: 461 Joined: Tue Apr 01, 2003 12:00 am Location: Under a PlopEgg
Post by Tímo »
Actually, how does this work then?
http://www.lo-res.com/nicebeats/Akai/3115A_synthline.htm
Nicebeats/Nicebytes Synthline Korg Trinity - AKAI format
Not only does it sample Trinity patches, it looks like it sampled the raw waveforms too:
Korg Trinity Akai Sample CD - Nicebeats Synthline #3115 wrote:These are not loops – these are the raw sounds taken from each model, meticulously multisampled and mapped out into Akai format at 16 bits, 44.1khz.
Looks like Nicebeats made sample CDs of the JD990, JV2080, QS6, SY85, Audity 2000, XP80, D70, 01/W, Proteus, Orbit - all ROMplers - along with other virtual analogues.
And the rest.... http://www.lo-res.com/nicebeats/
Tímo
Post by muzines »
just because they did it, doesn't necessarily mean they were allowed to.
FWIW, a lot of Roland ROM samples, including the V-Drum stuff and much of the D-50/JV-era content actually belongs to Spectrasonics, and is licensed to Roland.
Note that there are some grey areas, for example, Roland's much-sampled drum machines. Technically, TR-808's are analog synthesisers, but the TR-909 also contains samples, and obviously the next generation boxes (TR-707, etc) were all samples - Roland kinda of missed the boat on protecting their content, and as a result those sounds have effectively passed into the public domain (one of the key tenets of copyright is that if you don't actively protect your work, you can lose the ability to exert your exclusive right to copy.)
The fact that people get away with this kind of thing though is more down to what the companies decide to pursue, not whether you are technically allowed to do it or not.
muzines
Post by hollowsun »
The reason some of the older sample based ROMpler stuff (D50, M1, etc.) is almost public domain is because of the technology of the time.
When the D50 came out in 1987, the only way to sample it was on a hardware sampler such as a £2,500 Akai or Emu (ideally with £1,500 of RAM expansion!!) and the only currency for distributing them was floppy disks sent by snail mail so it wasn't really a threat to their sales and they weren't too concerned. Even in the early days of the internet, no-one was going to spend hours on 14k dial-up at 10p a minute up/downloading samples so it still wasn't really a threat to them.
Nowadays, of course, you can extensively multi-sample a Fantom or Motif, whatever, and have it available for millions to download in minutes for free and play in their £300 (or free) software sampler .... and THAT is a MASSIVE threat to their which is why manufacturers are far more protective these days. And that old stuff from the 80s is now out there, spawned probably from a handful of S1000 floppies made 20 years ago!
hollowsun
Posts: 2036 Joined: Thu Jan 20, 2005 12:00 am Location: Cowbridge, South Wales
Website / Music Lab Machines / Blog
Post by hollowsun »
Desmond is spot on with his assessment...
A 'sample' is a recording of a sound. Someone might not own (or need to own) the copyright of the sound (if there is one) but they own the copyright on the 'recording'.
That is why you can sample an analogue synth or a piano or a guitar freely but you cannot sample a ROMpler or a sample library or a sample based drum machine, whatever.
So you can sample a real piano but you can't sample a digital piano. And if you sample a real piano, you (technically) hold the copyright on those samples/recordings and if someone else nicks them and re-distributes them (even if they modify them), you can wallop them. But if you sample a Clavinova, Yamaha can wallop you ... but they can't if you sample their C7 acoustic grand!
Technically speaking, you can sample the kick and snare of a TR909 (analogue) but you can't sample its toms, hi-hat and cymbals (samples).
But you can freely sample an entire TR808 (all analogue) and you can sell them or give them away but, technically, you cannot call them "Roland TR808" because that is exploitation of a registered trade name which can also be copyrighted and Roland can have your arse and have your work withdrawn if you did make a "Definitive Roland TR808" soundset ... but you could call it "Ultimate Dance Beatbox" or somesuch without any problems.
You may remember a little upset a while back when all Fender Rhodes library suddenly disappeared and returned with a new name ("Classic EP", whatever). This is because someone bought the Rhodes trademark and objected to the name being used on sampled products from the likes of Scarbee, etc., even though it is perfectly legal to sample the sound!
But there are grey areas... sample based products long discontinued where the manufacturer no longer exists and the samples/recordings are of no commercial interest to the original copyright holders (if they still exist), for example, are fair game. There's a chance that someone might come out of nowhere and say "Oi! That's my copyright - cease and desist" but it's unlikely (and as I have experienced, some can actually be grateful for resurrecting some of their lost 'children' .. so to speak).
However, others are much stricter. Roland, for example, forbid the sampling of their old drum machines because they still hold copyright and they may want to use them in a new product of theirs. Which is fair enough. So sampling and re-distributing their TR707 is a no-no. But Roger Linn's probably not bothered about his old LM1 and 2 being sampled (even though, technically, he could object and be within his rights to). But even if he doesn't object to those old 8-bit drum sounds being sampled, he MIGHT object to his tradename being used. Or might not... depends if he thinks it benefits him and his current products - which it might. More specifically, it depends whether the usage tarnishes his name/professional reputation and that is a big concern for trademark owners...
These CDs flogged on eBay that the seller advises is a 'must-have' are a case in point.
Yeah! Right! A single sample from each sound, badly recorded, badly looped (if at all) and sounding like utter shite and totally unusable. That (potentially) tarnishes the professional reputation of the original manufacturers/copyright holders and the seller can be hammered on so many levels (if eBay gave a sh!t about copyright that is!).
There's also something called "Unfair Competition".
For example, I get a MiniMoog Voyager in and I multi-sample its presets extensively, one sample for very note - maybe even multi-velocity samples for every note - using long samples that breathe and evolve. I spend time carefully programming everything so that it is, to all intents and purposes, indistinguishable from the original Voyager and I put that on sale for $50. A bargain. All the presets from a Voyager for 50 bucks. Wow!
Even though it is perfectly legal to sample an analogue synth such as the Voyager, Moog could rightly claim "unfair competition" in a court of law and would probably win because their £1,200 products' sales are quite likely to be affected by my $50 soundset. They could also have a claim that the settings used for the various presets are (effectively) their copyright ... which would probably be supported.
However...
I could sample the presets from a Prophet 5 without any real danger of litigation.
Now, I could get a Voyager in and sample sounds I create myself on the Moog and also avoid litigation. But if I 'exploit' the Moog trademark to add kudos to my soundset (i.e. "Ultimate Moog Voyager") to enhance my sales, Moog could get stroppy ... and rightly so - "unfair competition" again. But I could sell it as "Ultimate Analogue" without risk ... whilst running the risk of not selling any because the 'Moog' name is not exploited to give the library credibility ... it's just a.n.other analogue synth lib and there are loads of those out there - it would be the 'Moog Voyager' tag that would make it desirable.
Similarly Doepfer, whoever. Even though their modular systems have no presets (obviously), Doepfer would be within their rights if I released a 3GB DVD of Doepfer sounds I created from scratch for $150 called "Definitive Doepfer" on the same grounds - exploiting their trademark/brandname to add kudos to my product and enhance my sales and potentially troubling theirs ... "unfair competition". But I could release it if I called it "Definitive Modular".
It's a bit of a minefield but to be honest, a lot of this is just common sense. I just wouldn't make a comprehensive library of Voyager sounds on moral grounds (even though I could probably make a pot of money) because Moog (and Doepfer, whoever) deserve respect and I wouldn't want to do anything that might jeopardise their sales. I could have sampled the crap out of a DSI 'Evolver' a while back and released it as a product but that would be unfair to Dave Smith.
On the other hand, I would have no moral turpitude sampling the crap out of a Prophet 5 extensively.
Do you see what I mean?
Basically...
You can sample a Roland Jupiter 8 freely and without restriction but if you are going to sell it or give it away, whatever, you cannot use Roland's trademarks
You CANNOT sample a Roland Fantom because the sounds utilise copyrighted 'recordings'. Well... technically you can't - you certainly can't sell it carrying Roland's trademarks
However, you could combine and splice and merge samples from a Jupiter 8 with your own programs from, say, a Korg Trinity or whatever to create something totally new and that would be ok - but not if you tried to sell it using any of the manufacturers' trademarks. It is unlikely that such a commercial soundset would fall foul of the original samples' copyright holder(s) (although it could in theory) because they're on the lookout for more blatant contraventions.
If all this seems confusing and draconian when sampling ROMplers, think of it another way...
You wouldn't buy a product that had sampled, say, the Garritan Orchestra sample library and which was called 'Ultimate Garritan'. You would immediately think "Wow - what a f'cking ripoff ... selling someone else's samples? That's terrible" ... but it's the same for ROMplers - selling someone else's samples!
Of course, there is a way around this ...
Get permission!
At the end of the day, apart from an understanding of copyright law (essential in this business), a moral compass is also required. Sadly, some peoples' are pointing south! Image
hollowsun
Post by muzines »
Thanks for the detailed and accurate post. Also, if others are still unclear on this, search out Eric Persing's forum posts of various forums about this - he explains this stuff very clearly as well. And he, like our esteemed Hollowsun here, has extensive experience as a sample soundware developer.
I think so. But, as someone once said, common sense isn't very common... :frown:
To be honest, I largely assume all sample libraries are crap unless they come from a developer I know/trust and who's skills and attitudes are exemplory, or am proved otherwise by the quality of the product.
These are the Scarbee's, the Spectrasonics, the Illio's, and many more (won't namecheck them here).
Sampling (ie developing multisampled playable instruments) is something, a bit like synth programming, that is easy to do badly, and really hard to do well, and often difficult to evaluate pre-sale.
If I could have a quid for every patch I've loaded up where the mod wheel, aftertouch, velocity, key scaling etc do nothing at all and are left unrouted, I'd be... well, significantly better off.
Those cheap products on ebay are largely all ripped off, or are crap and done by people with the desire to make some cash, not to make and market a good product. And there are many of us, including many on this forum I'm sure, who have had their work ripped off and copied and sold by someone else for profit and frankly feel rather peed off about the whole thing. These people have devalued the whole soundware concept to a point where it's really really hard to invest the time into making a good product because you just can't get much of a return on it.
But hey - you need to rise above the charlatans, because there *are* people out there who will appreciate it...
muzines
Post by Tímo »
Thanks for the extended elaborations. I was basically just wondering how the hell it, and the other ROMpler sample sets Nicebytes ran, so blatantly ever managed to get in the commercial sector without being reprimanded. They would've stood to piss off quite a few of the large manufacturers.
Tímo
Post by TBTS »
ive always liked the emu audity 2000 for programming intricate evolving pads.....
TBTS
Posts: 228 Joined: Thu Jan 08, 2009 12:00 am Location: London
Apple Certified Technician + songwriter ** Shiny New Website with new music, videos etc... ** http://www.turnbacktospring.com
TBTS wrote:ive always liked the emu audity 2000 for programming intricate evolving pads.....
+1
The Pearl Works
Post by hollowsun »
desmond wrote:Sampling (ie developing multisampled playable instruments) is something, a bit like synth programming, that is easy to do badly
The artist Degas once said:
"Painting is easy when you don't know how... but very difficult if you do'!!
hollowsun
