Adding ISRC codes
Adding ISRC codes
Post by Landed 1 »
Hi - totally new to this, and am struggling with ISRC codes. I've received a mastered disc from one of my artists with two tracks...no track data added at all. I've got Toast 10 Pro, and can see how to add the track names (CD text), but not how and where to add in the ISRC codes that I have for each track - and the printer/duplicator is itching to get hold of the master to finish production of the retailable single.
I'm told this is "easy'...but don't know where to start!!
All help gratefully received!
Landed 1
Posts: 2 Joined: Wed Nov 18, 2009 12:00 am
Re: Adding ISRC codes
Post by Weekender »
Save as Broadcast Wave?
Weekender
Posts: 18 Joined: Thu Oct 16, 2003 12:00 am
Post by Landed 1 »
Thanks for your reply. Sorry - may be coming over here as a complete Homer Simpson - but I don't understand what you mean......
Landed 1
Post by Weekender »
No, not at all. I was just about to go in to a meeting so I didn't have time to give a proper reply.
How did you master the tracks?.. If memory serves, what I did was when saving the files in Wavelab, then instead of saving as a wave file, I saved as a broadcast wave file. You then had the option of adding additional information. I'll check tonight and get back to you.
Weekender
Post by John Willett »
Does TOAST 10 burn ISRC codes at all?
TOAST 7 did not and you had to have Jam 6 to do it.
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Weekender wrote:Save as Broadcast Wave?
Unfortunately you're totally wrong - this has nothing to do with the file format used.
I'm not a Mac user but I understand that Toast is a general purpose disc burning program which is unlikely to support ISRC's. You need a specialist audio burning program. Waveburner might do it and Audiofile Engineering's Wave Editor might also be worth a look.
Cheers
James.
Post by Weekender »
Yip. I was thinking tat the last time I used it I used Wavelab. But it wasn't 'save as' it was in the disc burning 'bit'.
Weekender
