Firewire 800 - Does using a FW400 device in the chain slow the bus down to 400 speed?
Re: Firewire 800 - Does using a FW400 device in the chain slow the bus down to 400 speed?
Post by thescientist »
reading is pretty overrated these days :headbang:
thescientist
Posts: 303 Joined: Thu Feb 14, 2008 12:00 am Location: USA
Post by emilylaurence »
This slow performance generally occurs due to hard drive corruption. This problem lead in sluggish performance as well as decline in processing according to the given command. In such situation its required to format the hard drive to remove these bugs. However after formatting the drive your all data get erased. In sense to recover those back to hard drive, you cab use backup file. But in case if you have no back up then in such situation, you can also prefer to third party Drive Recovery Software. This is very eligible to recover and restore all lost, corrupted or formatted data to the hard drive. It works for different drive category like Lacie drive recovery or any other
emilylaurence
Posts: 1 Joined: Thu Feb 02, 2012 12:00 am
