Toneport UX8 USB recording issues - White noise and lowered pitch of recording
Post by PhlipD »
Heyy there!
I just purchased a Toneport UX8, and am using an AKG Perception 220 Microphone.
I can hear the Microphone perfectly through the Headphone output on the UX8 with no issues with the sound quality.
However when I record into my 2009 iMac 21.5", 3.06 GHz Intel Core 2 Duo, with 4GB of RAM, and with no other program open other than my DAW (Garageband or Logic) there is White noise in the recording and pitch of the recording is lowered slightly.
I have tried changing the Buffer size, and even on Large it has the same problem.
I have no idea what to do! :tongue:
I have posted this also on the Line 6 Fourms, however I haven't had a reply from them at all, so I figured this is the next best place :)
Please reply ASAP,
Cheers,
Phil D
PhlipD
Posts: 1 Joined: Sun Feb 28, 2010 12:00 am
Re: Toneport UX8 USB recording issues - White noise and lowered pitch of recording
" this is the next best place"
^^^^^^"How to win friends and influence people"!
Heheh! I am sure someone will be along to help you soon. I know jack of macs.
Posts: 19140 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by ryan mead »
Welcome to the forums! :lol: It doesn't sound like your problems are related to your computer's processing capacity.
PhlipD wrote:there is White noise in the recording and pitch of the recording is lowered slightly.
Not sure about the white noise (is it really white noise? is it constant or intermittent? can you upload a sample somewhere?) but the lowered pitch might be due to your computer's / DAW's sample rate. Maybe you're recording at 48kHz and playing back at 44.1? Check the settings in Logic/GB and the mac's Audio/Midi settings...
ryan mead
Posts: 696 Joined: Sun Jun 19, 2005 12:00 am Location: Seoul
The white noise is often indicative of a clocking problem, and the different pitch sugegsts that the recording and replay sample rates are different for some reason.
Check that the USB cable is a good one and not damaged -- try using a different cable.
Check that the UX8 control software is set up properly, and that the unit is set to run on it's internal clock, not some external clock. Also that the recording software is operating at the same sample rate as the UX8.
hugh
Posts: 43683 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by ElecTrika-MixTek »
I recommend that you register your product - this is often a requirement for customer care; I'm sure they would be pleased to respond to you then.
ElecTrika-MixTek
Posts: 170 Joined: Tue Jan 26, 2010 12:00 am
