Which effect VSTs are the best qaulity for audio production mastering?
Post by Parco »
Anyone have any good suggestion? :headbang:
Parco
Posts: 354 Joined: Thu Feb 25, 2010 12:00 am Location: Hong Kong
Cakewalk + Sound Forge -> ASIO + MMCSS + Windows 10 -> TI XIO2213B -> Echo AudioFire 4 -> HH MX250 + Wharf Delta70
A native USA style contemporary R&B artist in HongKong
Re: Which effect VSTs are the best qaulity for audio production mastering?
Post by Aliweasel »
I really like Density, a compressor with MS processing capabilities and some really clean gain reduction. I tend to use it on a low ratio to bring quiet parts up but it's capable of some more aggressive GR too.
It's downloadable here.
Aliweasel
Posts: 372 Joined: Fri Mar 31, 2006 12:00 am
Post by Grooze »
I'm a big fan of Izotope Ozone. It's damn pricey but can be used to do more or less an entire mastering project on its own, I've found. It's efficient and pretty with all its online graphical displays.
http://www.izotope.com/products/audio/ozone/#features
Disclaimer: I'm not a professional.
Grooze
Posts: 1 Joined: Mon Apr 26, 2010 12:00 am
Post by SafeandSound Mastering »
I would take a look at products from these companies :
Izotope
Kjaerhus Audio
Flux
Sonalksis
Voxengo
Stillwell (on a budget)
This will certainly get you on the right footing, you will have to listen incredibly carefully to what is best for each mastering job you encounter.
cheers
Posts: 1670 Joined: Sun Mar 23, 2008 12:00 am Location: South
Post by Parco »
eh... well.... actually all I want are some VST which have excellent sound qaulity (e.g. high precisions, just like PSP audioware Xenon), and the compressor would better be multibands and parallel (of course it need to have a dithering and noise shaping at last) :headbang:
Parco
Well plenty of suggestions, download demo's, listen and choose.
Some excellent software developers have been mentioned.
Post by Tony O'Shea »
Hi Parco,
clearly it's your choice but just to say that here we use broadband compression far, far more than we use multi/split. Nonetheless if you do want a good multi then take a look at the Flux Alchemist.
Cheers,
Tony
Tony O'Shea
Posts: 79 Joined: Tue Oct 13, 2009 12:00 am
Senior mastering engineer - MiroMastering
www.miromastering.com
With the Flux compressor I tried I noticed the side chain
filter was on by default, not a great idea IMO.
So the compression is not as smooth as you might have thought once this filter is switched off.
