vocal reverb reversed
Post by Plockton Blue »
Hi all,
Hope you're all outdoors enjoying this fine weather, and not stuck indoors in a stuffy studio...like me :frown:
Anyways, I'm trying to take the reverb from a vocal and reverse it. Is this a plugin method, or more a 'solo' the reverb, reverse it, record it, then re-apply?
Or is there another way?
Thanks for any help.
Cheers
Plockton Blue
Posts: 15 Joined: Mon Nov 23, 2009 12:00 am
Re: vocal reverb reversed
There are ‘reverse’ presets for various reverbs that apply an envelope with a slow fade in followed by an abrupt end.
This is useful in an emergency, but if you’re after classic Poltergeist reverse vocal effects a much more effective alternative is to reverse the vocal track, add reverb and re-record it, then reverse the audio once more. Voila - instant spooky vocals!
Here's a good tutorial on how to do it:
http://designingsound.org/2010/05/jim-stout-special-making-a-scary-voice-effect/
Posts: 22041 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by hollowsun »
You need to turn the tape over so that it's playing backwards...
Oh! Hang on.....
hollowsun
Posts: 2036 Joined: Thu Jan 20, 2005 12:00 am Location: Cowbridge, South Wales
Website / Music Lab Machines / Blog
Post by Dave B »
I tried that with Cubase as per Hollowsun's recommendation. Now I can't see what's on the screen - am I doing something wrong???
:bouncy:
Dave B
Now then lads - retain your dignity please :D
I’m wearing my sensible hat today ;)
Post by Zukan »
You used the wrong tape Dave B. Try gaffer.
Zukan
Posts: 10125 Joined: Fri Sep 12, 2003 12:00 am
1-2-1 Tuition
Post by hollowsun »
Martin Walker wrote:’m wearing my sensible hat today ;)
That'll be a first then! ;)
hollowsun
No, it's the green one with the feather.
Post by ManchesterMidischool »
Apply the reverb to the vox as a send.
Make your bus send pre-fader and then turn your vox down so that you just hear the 'wet' vox.
Export this as an audio file.
Import this wet signal as a new audio track and reverse it.
Turn your vox back up.
You can now add it just before your vox in the timeline so that the fx draws closer in reverse sounding like it sweeps up on you from a distance and 'sucks' you into the main vox part.
Posts: 3 Joined: Fri Jul 02, 2010 12:00 am
Music Production Courses.
midischool.com
That won't work as you've written it - you need to reverse the vocal first, then apply the reverb.
Posts: 21202 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by DaleSmith »
indeed!!!! I did this last week for a Sepultura style metal vocal.
export the phrase you want the reverse reverb for. reverse the phrase, apply a reverb ( 100% wet ). record or bounce the reverb, then drag it back into the original track. reverse the reverb you bounced, and line it up against the start of the phrase, or wherever you want it.
easy.. works really well with delays too
DaleSmith
Posts: 261 Joined: Tue Apr 29, 2008 12:00 am Location: Hull, UK
But dIdn't I say all this when I first replied to the OP :headbang:
:bouncy:
