any gong or ozric fans here?
im trying to get a sound that is very similar to the synth sound that gong and ozircs use..im sure this one is piss easy but it totally eludes me....the sound is like its falling.they usually use it at the start of the song,,when the drums kick in after a long build up..you know what i mean ????i have a korg m1 and a korg triton and yamaha csx5 is it easy enough???
- paul tha other
Frequent Poster - Posts: 826 Joined: Mon Sep 06, 2004 12:00 am Location: scotland
Re: anoy gong or ozric fans here
In answer to your post question - yes
As to the "how" - I believe Ed Wynne referred to the synth "effect" you described as "waterfalls" - which is descriptively apt.
If it helps, I know in the earlier days he started most Ozric compositions using a couple of Pro ones. I'm fairly sure though that the sounds used in the waterfall-type effect came from a Wavestation. Latterly I thihnk he uses a Supernova instead? (or maybe in addition to?). There used to be a guy on here called Stevedog who knew them and their music/gear etc, so maybe he'd be best placed to give the detail if he's still around.
I think pretty much any decent (or otherwise) synth can do that type of thing though - modulating pitch and filter over time with an LFO I suspect. Possiblly with a pulse shape, maybe a sawtooth would work too? It also often sounds like the VCA decay is modulated so that the decay time either increases or decreases throughout the cycle of the patch.
Since i havent got any gear in front of me right now I cant be any more specific. Im sure others can me though. Good luck
...oh and in the early days Gong used the EMS Synthia I believe - expertly noodled by Tim Blake. Nowadays, with Miquette Giraudy doing the twiddling, I think she uses a Nord - on stage at least. Certainly when I saw them a few weeks ago in Glasgow she had a Nord on stage. Couldnt make out the other one though
Some of my best friends are pot-head pixies!
A simple analogue monosynth is what you need - if the filter can go into self-oscillation so much the better. I still turn to my Sequential Pro-One for this type of bloopy wibbly sound effect.
thanks for that dude..deff a step in the right direction!!!i will give it a go when i get home and i will let ya know how i get on...
ps i love my typo in the subject title
- paul tha other
Re: any gong or ozric fans here?
Hi again. I remembered that in '96 SOS interviewed Ed Wynne. Not a lot of detail about sound design but interesting nonetheless:
http://www.soundonsound.com/sos/1996_ar ... acles.html
Oh and yes noticed the typo
Actually I changed the title of the original post (but not the follow-ups), since “anoy gong or ozric fans here” did rather suggest you were encouraging people to wind others up, and I didn’t want disappointment setting in when they discovered that it was a bona fide question about synth sounds
Posts: 22117 Joined: Wed Jan 13, 2010 8:44 am
Oops! I mistook this thread for this gong by Sigur Ros. Which I love a lot and jumped in to flood the thread with kisses.
Anyways Ozric's space rock rocks too. No clue about their synth use though. Very new to them.
Les wrote:...oh and in the early days Gong used the EMS Synthia I believe
For what it's worth, if you've got Kontakt, you could have this Synthi library for a mere $59 :
http://www.soniccouture.com/en/products/g12-synthi-aks/
Don't have it myself, but I do own several other Soniccouture products, all of which are very good indeed.
D.
hey guys thanks so much for the replys...is it possible to do on a korg m1 for instance..its the keyboard i use live the keyboard player in the band has the triton and csx5..i did a bit of fiddling last night..i got close buts its not really there yet..i might try to use the m1 as a mono synth
ps thanks martin for changing the subject typo..although i quite liked it..
paul
paul
- paul tha other
Hi again Paul
Been away a while hence the delay.
AS it happens I have the M1rex module and the one problem youll find with it in trying to reproduce that sort of patch is that it doesnt have filter resonance. However, if it's the "falling" pitch descending sound youre after I think such a patch could be set up with the M1 architecture. The M1 LFO's should be able to be routed appropriately - although I have to be honest and say ive never tried to create this sort of patch with it. I use the basstation for that sort of thing - and occasionally (believe-it-or-not) my Vintage Keys Plus module as it has quite complex modulation possibilities. As usual, since im not online at home and so dont have the gear (and the manual) in front of me I cant confirm it. The other issue with the M1 of course is that theres very limited realtime control, not to mention the front panel single parameter editing of course. The same would apply to the VK too of course
It was indeed the Pro one that they (Ozric T's) used to get that 'bubbling' ( "waterfall") sound on most of their earlier albums & probably the rest.
Most 70s & early 80s monosynths can get this effect as can the late 60s EMS Synthi AKS & Miquette Giraudy did use this synth on most Steve Hillage albums & tours & still does with System 7.
- Captain Waves
Poster - Posts: 71 Joined: Wed Apr 11, 2001 12:00 am
Crikey! The Ozrics! Haven't thought of them for a while. I saw them once at The Brighton Centre. They turned into lizards and I thought I was trapped in a jungle. I couldn't speak. Everything appeared to be at the end of a tunnel. The floor was squishy and I sank into it whenever I sat down.
The moral of the tale? Use the correct type of blotting paper otherwise it's difficult to predict strength. Hoho, crazy days! So glad I've grown up ... A bit
I seem to recall an interview somewhere (possibly SOS?) where Ed Wynne was talking about his use of the Korg Prophecy, which he referred to as his 'bubble machine', if memory serves (and it usually doesn't
Miquette also used some mad box (early 90s Orb sessions, anyway) that was completely painted in psychedelic patterns, loads of knobs, not a single thing written on it to tell you WTF was going on - or certainly the one time I messed about with it it took a while to go 'ok, so that one's oscillator pitch, that one's cutoff...' and work it all out. I saw the Ozrics in about 1986 (playing with a band with the superb moniker "Thatcher On Acid") at the Club Mankind in Hackney- and that time the 'falling effect' was coming out of a Korg MS20.
Tricky to do it on an M1 because you don't have easy access to multiple parameters at the same time - a lot of this kind of thing is hands-on twiddlery, and the MS20 excels at this because you have both a hi-pass and lo-pass filter, both with resonance, all four knobs close together (2xcutoff, 2xresonance) and all available to one hand at once, while the other cranks LFO speed and waveform shape at the same time. It's all in the fingers, real time. Try an MS20 emulation and midi controller and you might get close.
Gong, Ozrics and Hillage thread - Xmas has come again already - smiles all round.
A couple of Ozric Tentacles gigs from the early 90's spring to mind - at Glastonbury with the Orb and the Shaman and at Sussex University - seems like last night - very, er, vivid memories.
At this point if anyone wants to ramble about the sub-aquatic synth and guitar sounds on Fish Rising I am all ears...
ok i got close..i used a mix between the triton and of of the soft synths in logic..wanna check out the results
http://www.myspace.com/progadellica/music/songs/space-jam-in-b-mp3-77982489
...im kinda happy with it...but for some reason the triton kept drifting out of sync
thanks for the help guys
paul
paul
- paul tha other
yey, for space rock! (nice track!)
Yes, I think definitely the whole analogue synth with filter being controlled with LFO and rising it up from low to high is what you want there. Preferably with resonance self-oscilating and a big dollop of delay.
You might like my space rock/krautrock too:
http://onrailsmusic.wordpress.com/
Some bits are even in 5/4!
- Guest
hey there nice tracks i like them a lot......cheers for all the help
paul
paul
- paul tha other
Hey PaulthOtha & Oli, I enjoyed your tunes! Solid & spacey , nice mixes too
- Captain Waves
While we're on the subject (occasionally) does anyone happen to know what poly synth was used predominantly on 'Erpland' ? especially on the first 2 tracks.
It sounds like the Roland JD800, & is sustaining chords ('pad') with a subtle lfo or envelope on the filter; a voice-like/etherial timbre.
I love that sound .
I can get very close with my JD800 & close enough with my Wavestation (when it was working), but afaik 'Erpland' came out a year before the JD800 was released (1990 & JD800 in 1991 ) which leads me to guess it must have been the D50.
I was certain that it was the JD800 until the release date discrepancy.
I know that the D50 was (as quoted in the SOS article @ 1998) one of
Ed Wynn's favorite synths of all time hence it may well be that.
I want to know these things..
I love that sound .
- Captain Waves
Just to go into a bit more detail on my last post above, re: that sound on Ozric Tentacles - 'Erpland' (2nd track) that Im after...
As I said its an etherial early digital synth voice-like sustaining slow chord sequence with a slow modulating filter sweep .
I thought it was a signature JD800 'pad' type sound.
I would have put all my money on that,( if I had any) but I recently found out that 'Erpland' came out a year before the JD800 was released, which leads me to the conclusion ,sort of, that it must have been a D50, given Ed Wynns & Joie Hiltons love of & extensive use of the Roland D50 at that time.
Not having a D50 to hand nor have I ever played one ,I cant solve this personal geek riddle.
I can also get very close to that sound with my Kawai K5000S but obviously its not this synth either as it came out @8 years later.
The JD800 can indeed do it, but it cant be that synth unless they had an early prototype.
Anyone?
- Captain Waves
Ok, even more detail about my last two posts as they are so vague , as in what track Im talking about etc .
Re: that synth sound that Im so interested in ( bordering on sonic obsession)
Its track 3 on 'Erpland' ; 'Tidal Convergence'
It sounds like late 70s fusion ala Brand X. Im not that interested in the track as such in itself or this type of music,( except I used to love Brand X at their best, & Gong & Hillage, the originals )
What it is about this track that Im interested in as I have already said twice , is that particular synth sound & treatment , the synth line that opens the track & continues throughout the track.
Its a particular synth sound that I have heard before in other artists tracks of that era ~( early to mid 1990s) & a sound that I have been trying to identify , 'nerd' that I am in this respect.
Again its a digital sounding synth , but a very warm one , slow chords & a slow sweeping filter on this track that almost sounds as if its a dual filter , band pass or high pass filter in series with a low pass.
Now as I said Im not familiar with the intricacies of the Roland D50s filter or advanced features & I thought it may be this synth filtered through a Korg MS20 , then I was thinking that it may be a Microwave ( due to the dual filter sound)as I think Joie & Ed used all these synths at this time.
I could have sworn that it was a JD800 ( & it can come very close indeed to this sound) but I recently found out that the JD800 came out a year after Erpland was released, so that is highly unlikely then.
I guess I really need to ask them, but it may just be a D50 on its own, so I thought maybe someone here with a D50 & who knows this album could enlighten me. ?
If not Ill have to ask the players
- Captain Waves
Hi Captain,
I admire your persistence in tracking down these elusive vintage synth facts!
Unfortuantely, I can't help you with your specific queries, but wanted to recommend NI Massive as a really interesting (plug-in) synth with regard it's wavetable modulation possibilities.
I just got it last week, and it makes the sort of extremely pleasing modulated / phaseshift / hardsync /harmonic sounds that I reckon you might like as well!
- Guest
Err... that'll be a yes. I am very much into these 2 bands, very ahead of their times, especially Gong. And Gong made some of the best sounding recordings I have heard to date. I really like the sound overall of "Steve Hillage The Glorous Om Riff", Analogue sound at it's best and worth a listen even if you are not mad on the music itself.
- SafeandSound Mastering
Frequent Poster - Posts: 1633 Joined: Sun Mar 23, 2008 12:00 am Location: South
Mastering: 1T £30.00 | 4T EP £112.00 | 10-12T Album £230.00 | Stem mastering £56.00 (up to 14 stems) masteringmastering.co.uk
