Q: What are your top 3 mixing reference tracks?
Post by BJG145 »
BigWheel started this thread, but then it got broken somehow. (?)
It was quite interesting, so I thought I'd try and kick-start it again. The basic question was which, and why...
Posts: 7902 Joined: Sat Aug 06, 2005 12:00 am Location: UK
Re: Q: What are your top 3 mixing reference tracks?
Post by . . . Delete This User . . . »
as noted by several the first time around,
AC/DC's "back in black" is a popular album to reference rock/guitar driven material against.....
Posts: 2319 Joined: Mon Jun 23, 2008 12:00 am
Post by Mixedup »
I didn't catch that thread, but it depends entirely on what I'm mixing... which means it's more than three tracks. Also, not sure if there was a link to the most recent SOS article on the subject.
Mixedup
Post by Ken P »
I am currently using the following for a new electronica project which I believe demonstrate true mixing genius in the genre:
Thomas Fehlmann - Hana (from the album Low Flow)
Thomas Fehlmann - Honigpumpe (the whole album!)
Gotye - Heart's a Mess (Supermayer Mix) (from the album Kompakt Total 10)
1 and 3 on Spotify.
Ken P
Posts: 87 Joined: Fri Aug 27, 2004 12:00 am Location: Somerset, UK
Post by 4TrackMadman »
AC/DC "Back in Black" one of the ones for me as well :)
Scorpions "Love at First Sting" although lately I gravitate towards "Sting In The Tail"
Celtic Frost "To Mega Therion"
4TrackMadman
Posts: 1114 Joined: Wed Oct 30, 2002 12:00 am
Post by Guest »
None at all at the moment. I was sitting there one day working on one of my pieces, and every now and again checking it against some favourite reference material, and i thought to myself "what the hell are you doing!?"
I realised that i was being an arse. I know what i like, i know what sounds good, why did i need to have something to A/B with? I don't do this with other works. I don't listen to a commercial recording and then quickly put on another recording to make sure that thay have similar texture before i decide if i like it or not, if it works for me.
So i gave up using reference tracks in an attempt to keep other people's creations out of the room when i'm creating things that will hopefully have a more of me in them.
That was a few years ago. Now i just see it as a bad and lazy habit.
For me that is, not for anyone else... Y'all do as you like.
Guest
Post by Mixedup »
ow wrote:None at all at the moment. I was sitting there one day working on one of my pieces, and every now and again checking it against some favourite reference material, and i thought to myself "what the hell are you doing!?"
It's not about creative stuff, it's about calibrating your ears. You listen to a track for several hours when mixing, so it's easy to become accustomed to it and lose perspective — your tolerance of HFs becomes higher over time, which causes problems with esses, cymbals, overall mix balance etc. If you can do without, and take regular breaks, then fair enough. But personally, I find it beneficial to do a quick AB from time to time — I don't mean listening to the track all the way through, just a quick five second burst so I'm not flying with no idea where my horizon is!
Mixedup
Mixedup wrote:It's not about creative stuff, it's about calibrating your ears.
+1
When you've been working on a track for hours at a time you do begin to lose perspective. I frequently wind up the lows and highs more as I progress, and add more ambience, in the belief that I'm 'improving' a mix, when all I'm doing is adding salt to a meal that I'm finding harder and harder to digest. Pulling up a reference track for a minute or two helps you to press your ears' 'reset' button.
Sometimes it comes as a shock when I go back to a reference and think how lifeless it sounds at the side of my own mix - this is the time to take as long a break as my deadline permits, because my perspective has left the building! :crazy:
Posts: 21237 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
I’m finding it increasingly beneficial to let artists supply me with reference material. It exposes me to music I might not otherwise hear, stops me becoming complacent and provides me with fresh challenges. The less I like the music I’m challenged with I find the more I learn!
Too often you can get side-tracked with your own likes/dislikes, when what you really have to do is hear what the artist/producer is trying to say.
Post by Mixedup »
The Elf wrote:I frequently wind up the lows and highs more as I progress, and add more ambience, in the belief that I'm 'improving' a mix
Amen to that. Pretty much every time I mix without any reference points, I find I end up with a mix that's overly scooped in the mid-range, which leaves the mix sounding hollow on the 'y axis', and which is overly ambient and thus a little hollow on the 'x axis'. Regularly monitoring in mono only can help on the latter too...
Mixedup
Post by Shambolic Charm »
very enlightening. I usually leave mixes for a few days and then go back. I'll try that see if it is a more instant fix for that state where Judgment seems to get lost
Shambolic Charm
Posts: 671 Joined: Wed Jul 13, 2005 12:00 am
Post by Guest »
For you. It works for you, right? But it doesn't work for me. I know what it's about, i know why people use ref tracks and have done. But it doesn;t work for me.
Guest
Post by Mike Senior »
Funny -- it's the opposite with me! I usually end up with something that sounds boxy and horrible to start with.
Then I start making it even worse... :headbang:
Mike Senior
Posts: 1085 Joined: Fri Aug 08, 2003 12:00 am Location: Cambridge, UK
Post by Džoni »
Mike Senior wrote: Then I start making it even worse... :headbang:
Mhm, Mike, sure you do. We believe you... ;)
Džoni
Posts: 82 Joined: Sun Oct 14, 2007 12:00 am Location: South Africa
Come on, Mike - publish one of the Mix Rescues that failed! :D;)
Post by aekoi »
Not recording much just now but for testing live PA rigs I favour a blast of some or all of the the following -
Candi Staton - You Got The Love (to be sure the subs are working)
Anthrax - Safe Home
Jimmy Eat World - The Middle (I think this record pretty much uses all of the audible frequencies, all of the time)
Britney Spears - Baby One More Time (which I'm ashamed to say sometimes makes me nearly cry, and don't say "Me too", I'm being serious)
Grace Jones - Slave To The Rhythm
aekoi
Posts: 300 Joined: Wed Jun 26, 2002 12:00 am Location: Not of this Earth
Post by oggyb »
Nine Voices - Yes, for acoustic guitar;
Living Forever - Genesis, for drums (though there are only about 3 places in the UK you can achieve that sound);
This is the New [ ****** ] - Marylin Manson, for a lesson in mix buss compression;
Choke - Hybrid, for the crystal clear, sparkly production, and to hear the polyrhythms and tonality clashes.
That's four. . .
oggyb
Posts: 1079 Joined: Sat Feb 09, 2008 12:00 am Location: Leeds, UK
Post by MadManDan »
aekoi wrote:Britney Spears - Baby One More Time (which I'm ashamed to say sometimes makes me nearly cry, and don't say "Me too", I'm being serious)
It's a tight track.
I recently fell in love with "When It's Over" by Sugar Ray. Very well done mix. A lot of little elements but still an uncluttered mix. I love the fact that these heavy guitars play on the first beat of every bar of the chorus but are faded out by the end of beat two. Great song too.
MadManDan
Posts: 601 Joined: Mon Sep 13, 2004 12:00 am Location: Across the pond....New Yawk
Late '14 mini 3 GHz i7 16 GB
Catalina 10.15.7. Glyph atomic. FF Scarlet 18i8.
Sup Drum 3. Cubase 11 Pro
iCon iKb 8x.  Mics, spkrs, 'phones, gtrs, greedy cat
Post by Blue Lizard »
aekoi wrote: Grace Jones - Slave To The Rhythm
+1 8-)
Blue Lizard
Posts: 165 Joined: Wed Jul 02, 2003 12:00 am Location: Cleethorpes, UK
"It's not pretty, also you can't dance to it." - Frank Zappa www.bluelizardstudio.com
Post by oggyb »
MadManDan wrote:I recently fell in love with "When It's Over" by Sugar Ray. Very well done mix. A lot of little elements but still an uncluttered mix. I love the fact that these heavy guitars play on the first beat of every bar of the chorus but are faded out by the end of beat two. Great song too.
Lots and lots of sub-200Hz makes me dubious about agreeing with this. Very good use of background guitars though, nice and grungy.
oggyb
The Elf wrote:Come on, Mike - publish one of the Mix Rescues that failed! :D;)
Hah! The funny thing is that I think I already have -- if you have a look back at the Turn Back To Spring one in Mix Rescue May 2010 you can even hear my first version which they didn't like. Win some, lose some...
I quite like that mix too, but I much prefer the one for 'Toxic'.
Mike Senior
Hah! The funny thing is that I think I already have -- if you have a look back at the Turn Back To Spring you can even hear my first version which they didn't like. Win some, lose some...
Ha ha! Yes, I’m going through one of these at the moment. Between myself and the studio owner we’ve been burning the midnight oil, feverishly pummelling a number of songs to achieve the vision described to us by the band. The last mixes I returned to him he was ecstatic about – “I can’t wait for the band to hear these!”
I proudly played the first mix of a number of songs - “listen how huge we’ve managed to make you guys sound!”
The band sat quietly through the mix. As the last beat died away there was a profoundly dismal silence…
“We don’t like ‘huge’”
Back to the drawing board! :headbang:
