Two recommendations
Two recommendations
Post by Exalted Wombat »
I'm playing keyboard and running sound for an amateur pantomime this week.
For a straightforward sound cue playback system, Multiplay2486 from www.audiovisualdevices.com.au is doing a great job.
For running my Asus laptop into the sound system, a £15 toy from Maplin, designed for car audio systems, has turned a horrendously noisy link into a perfectly quiet one. Here's the link.
Don't suppose it would do much for problems with an ungrounded psu, but for this one it worked wonders.
Exalted Wombat
Posts: 5847 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Re: Two recommendations
That’s perfectly adequate for breaking the loop, although distortion and bass response are likely to be below par for real work (fine for a local pantomine though ;))
A decent DI box is the best candidate for quality music :D
Martin Walker wrote:(fine for a local pantomine though ;))Martin
Oh No It Isn't !!!!
:tongue:
Martin Walker wrote:That’s perfectly adequate for breaking the loop, although distortion and bass response are likely to be below par for real work (fine for a local pantomine though ;))
Previously, I WAS using a pair of quite decent DI boxes. I expected the Maplins unit to sound inferior (not that ultimate fidelity was necessary, or even desirable, for FX cues) but it didn't. I was also surprised at the size. It's not pretty, but there's a pair of quite big transformers in there.
Exalted Wombat
Martin Walker wrote::tongue:
You were supposed to say...
Oh Yes It Is!!
I don't know.. you feed someone a line...
:headbang:
Oh Yes It Is!!
:headbang:
Oh sorry! I didn't know. I'm just fitting this local amateur panto into the gaps of what must be my 35th or so professional one as MD! I must pay more attention :-)
Funny how, when you share the information that something that OUGHT to be cheap-and-nasty actually performs pretty well, someone else who hasn't tried it always comes back to reassure you it must be crap after all!
Exalted Wombat
Post by InactiveX »
Exalted Wombat wrote:I must pay more attention :-)
He's behind you! ;)
I use one of those ground loop isolators in my Commodore 64 to protect the SID chip at the output, as it is rather fragile electronically and easily fried.
InactiveX
Posts: 197 Joined: Fri Jul 22, 2005 12:00 am Location: England
Exalted Wombat wrote:Funny how, when you share the information that something that OUGHT to be cheap-and-nasty actually performs pretty well, someone else who hasn't tried it always comes back to reassure you it must be crap after all!
Sorry EW - I'm not trying to tell a granny how to suck eggs, but attempting to offset the hordes who rush off to buy the cheapest ground loop isolators they can find instead of a decent DI box.
In other words - thanks for the recommendation! :bouncy:
Let me just remind - this isn't a DI box. It doesn't offer loop-through of the input signal, there's no ground-lift switch, it doesn't interface to a lo-Z balanced input. It's just a lumpy, ugly pair of 1:1 isolation transformers with phono connectors in and out.
It just happened to be exactly what I needed to go between a laptop computer and a mixer. And, having tried this quick-and-dirty solution, I was very happy not to need anything "better" - it sounded just fine!
Exalted Wombat
