http://www.soundonsound.com/sos/may03/a ... an0503.asp
Now i've tried to run the SANDY software but it crashes my system so I've unistalled it.
However i downloaded my mother board instructions and read the following.
.......................A..............B..............C............D..etc
PCi 1.........Shared
PCi 2.....................Shared
PCI 3........................................Shared
O/b Usb1..Shared
O/B Usb2..Shared
O/B Lan1..Shared
Then a statement under the grid reads.
NB:When using cards PCi cards on shared slots ensure the drivers support "Share IRQ" or that the cards do not need IRQ assignments. Otherwise conflicts will arise between the two PCI groups making the system unstable and card inoperable.
I'm a little confused because a table above it (i can't cut and paste out of a PDF doc) states
Irq 5 9 10 and 11 are listed as "IRQ holder for PCI steering".
Now from the first paragraph I'm thinking I'm doomed
 as the motherboard is just not right to give a PCI card exclusivenes.something the LM demands i believe.
 as the motherboard is just not right to give a PCI card exclusivenes.something the LM demands i believe.But from the last statement about IRQ holding i see i may be able to do some steering?
Hope someone can give me some hope
Rgds Ronnie
