"Burning-in" headphones - proven or waffle?
Post by Evie McCreevie »
I've recently got a new pair of AKG 701s...
Various 'authorities' on the net recommend 'burning-in' for 300(!) hours. Others say it makes little or no difference.
Surely this can be proved conclusively - once and for all - by some boffin or manufacturer?
Simply measure any decent cans' response when brand new, then after burning in. Check for a measurable difference, and evaluate if that difference is in any way beneficial.
Has this been done?
Evie McCreevie
Posts: 445 Joined: Mon Sep 06, 2004 12:00 am Location: Dublin
Re: "Burning-in" headphones - proven or waffle?
Post by Mixedup »
Evie McCreevie wrote:Surely this can be proved conclusively - once and for all - by some boffin or manufacturer?
Yes... though more difficult to be truly scientific about it: how to you blind test the same pair of cans before and after burning in? Maybe the playback level has a bearing on it; or the frequency content of the material played through them...
Certainly my HD650s got subjectively better over the first few months.
Mixedup
Post by ezza »
I burned in my K701s and I'm absolutely convinced that it made a difference for the better. I also googled this extensively and never came across any tests that showed that burning changes the sound. In the end I decided that it wasn't a lot of effort so why not...
/erol
ezza
Posts: 233 Joined: Fri Nov 19, 2004 12:00 am
Post by SafeandSound Mastering »
Some drivers whether in headphones or loudspeakers do require time to reach their optimal performance. I know Dynaudio Acoustics used to suggest a "wearing in" period.(They may still do)
I do not think it takes too larger stretch of the imagination to believe that moving parts may require some regular movement before the materials settle down and perform optimally or at least in a more stable manner.
cheers
Posts: 1670 Joined: Sun Mar 23, 2008 12:00 am Location: South
Mastering: 1T £30.00 | 4T EP £112.00 | 10-12T Album £230.00 | Stem mastering £56.00 (up to 14 stems) masteringmastering.co.uk
Post by Exalted Wombat »
Evie McCreevie wrote:I've recently got a new pair of AKG 701s...
Has this been done?
If "burning in" was accepted science it would be ... well ... accepted science. The fact that it isn't may suggest an answer to you :-)
There are no "accurate" microphones, speakers or headphones. Suggesting that a "burning in" period will mellow such tools may reduce any tendency to want to exchange them on the day of purchase for sounding "different".
Subjectively, of course, the difference between "burning in" and "getting used to" is impossible to detect!
There's some point in burning in active devices simply as part of the testing process. If it lasts the first week, it's likely to be a good 'un. Some manufacturers find it economic not to test but just to replace early failures without question. If the failure rate is low enough, this is not necessarily immoral.
Exalted Wombat
Posts: 5846 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Post by ramthelinefeed »
It depends what type of lighter fuel you use for the burning. Some people favour butane over propane as it has greater mass and helps to give deeper basses and a more airy top end.
ramthelinefeed
Posts: 2433 Joined: Mon Jun 23, 2003 12:00 am Location: UK
A weasel hath not such a deal of spleen as you are tossed with!
Post by Mixedup »
Exalted Wombat wrote:If "burning in" was accepted science it would be ... well ... accepted science. The fact that it isn't may suggest an answer to you :-)
Except that this isn't a binary scenario. Scientific testing gives you various possibilities: something may be proven to be possible or impossible; it may be demonstrated to be probable or improbable; or of course the results may be entirely inconclusive, whether due to lack of evidence or difficulty in interpreting the results. What you're saying is that one of the above hasn't been shown to be the case... but that still leaves a lot of possibilities ;)
Mixedup
I'm sure everyone has experienced the 'burning in' process involved after the purchase of a new pair of shoes. When you first put them on they feel stiff and inflexible, yet after wearing them for a while they soften and become much more comfortable.
Exactly the same thing happens with a lot of different materials, including some of those used for making loudspeakers and headphone drivers. This is well known and documented in the professional and academic literaure.
The characteristics of the fabrics and especially the glues and supporting flexible surrounds often change during the early period of use, before settling down to a stable state for the rest of the product's lifetime, before eventual failure.
These changes in characteristics can be very subtle, or they can be surprisingly significant... and whether you can hear it or not depends partly on the listener's hearing accuity, but much more so on the actual product design.
If some parameter of the material -- such as its stiffness or self-damping -- plays a critical role in the overall performance (resonance tuning, say) of the product, then that performance will change audibly as the material 'beds in'.
Some designs require and rely on very tight parameter specifications to deliver the specified performance. others are far less critical... and that's why not all products reveal an audible burn-in period.
My personal experience with AKG K701s is that their performance does 'mature' during the first few hours of use -- but nothing like 300 hours!
Hugh
Posts: 43679 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by 1-1-2C »
Hugh Robjohns wrote: My personal experience with AKG K701s is that their performance does 'mature' during the first few hours of use -- but nothing like 300 hours!
+1
I just listened to my pair of 702s straight out of the box and there was a noticeable improvement in bass extension over the first hour or two.
So I left them running at a loudish volume overnight to see if there would be any change. I'd say there was some difference between the 5hr mark and 15hr mark (from when I left them overnight) *maybe* a very little again at the 25hr mark (left for a second night) but not really very noticeable.
They are now well past the 300hr milestone and I'd be extremely hard pressed to say there is any difference between now and at 25hrs.
Hope this rambling helps in any way whatsoever. :tongue:
1-1-2C
Posts: 15 Joined: Tue Aug 12, 2008 12:00 am Location: Glasgow
Post by John Willett »
Has this been done?
I have various things from various manufacturers.
But with the K701 it seems that the consensus is that it needs a very long burning in time and I think about 500 hours is the norm for these.
I know 0VU had (has) a pair and I am sure he said that they needed a very long burn-in; were pretty nasty at the start and great when finished.
John Willett
Post by RegressiveRock »
Has this been done?
Burn in: proven. For the AKG701 there's a definitely settling in and deepening of the bass response and improvement of the general frequency balance.
500 hours? Mmmm... I'm not sure I agree with 2 guys (JW and 0VU) I respect immensely: sorry but the major differences are gone pretty quickly - say 50 hours tops playing my iTunes library loud and placed around the box.
Reg
RegressiveRock
Posts: 1495 Joined: Wed Sep 01, 2004 12:00 am Location: Buntingford, Herts
Post by planetnine »
feline1 wrote: It depends what type of lighter fuel you use for the burning. Some people favour butane over propane as it has greater mass and helps to give deeper basses and a more airy top end.
Sure that wasn't what Hendrix used...
:beamup:
planetnine
Posts: 414 Joined: Mon Sep 13, 2004 12:00 am Location: lincolnshire government experimentation zone
Planet Nine, Lincoln, UK.
Has this been done?
Reg
Normally I agree that about 48 hours is fine.
But for the K701 I have heard many many people saying that they need a very long burning in time and 500 hours is what has been said by many.
John Willett
Post by The_BPP »
500 hours? shurely shome mishtake? That's 21 days of solid playing(!) Blimey, pleased I went with the DT880s, now. They did need some burning in, mind.
The_BPP
Posts: 1399 Joined: Thu May 13, 2004 12:00 am Location: Lincolnshire
Touch & Go
John Willett wrote:[Normally I agree that about 48 hours is fine.
But for the K701 I have heard many people saying that they need a very long burning in time and 500 hours is what has been said by many.
Mine seemed to settle in after a couple of weeks of ‘normal’ use (50+ hours-ish?). The bass deepened and the front-to-back imaging increased.
I might be goaded into believing that they continued to improve beyond this period, but it could be a combination of wishful thinking and familiarity.
When my 701s give up the ghost I’m straight back for another pair with no hesitation at all.
Posts: 21430 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
This is what 0VU said on the matter in this thread back in 2009:
I'd give them at least 100 hours before trying to do anything with them as before that they're actually pretty nasty sounding and very disappointingly harsh and bass light. I've found with all the pairs I've bought that there's quite a marked change at about 100 hours or so. They then go on steadily but noticeably improving over the next 100 hours or so, and then more subtly for a while longer. After 300 hours any change is slow, very subtle and probably due as much to wear and tear and normal aging as to 'running in'.
If you can bear the wait, I'd say leave them alone for 200 hours, and maybe up to about 300 if you can stand the suspense They should, however, be quite usable as a reference after about 200 hours. Just don't try to use them straight away as you'll wonder why you bought them!
Curiously, the K702s seem to need even more running in. I've only got one pair so far but they needed about 200-250 hours to pass the first big change point and didn't settle in to the K701s 200 hour sound until past 300 hours. That is however, only based upon one pair, whereas the K701 comments are based upon nine or ten pairs that I've bought for myself or other people so far.
Incidentally, the K702s are even better than the 701s Not a huge leap; more an incremental improvement but everything is just a little bit more 'refined'/'developed'/improved/etc. Hard to describe; they're just that bit more 'special'. And a less ...er... obvious colour too
700-800 hours sounds pretty extreme to me. I can't reliably discern any change between pairs once they pass 300-400 hours (I've had the luxury of having several pairs here and being able to compare them at different run times). The K701s (and now K702s) seem to need more settling time than any other piece of gear I've ever bought. Certainly the Sennheisers I used before them (and still have and use from time to time - HD580/600/65/25) only need a fraction of that to hit their stride; I'd say 20-50 hours (ish) and they're pretty much settled.
The K701s do seem to benefit more than the Sennheisers from a good powerful amp. It's odd in that I find that in some ways they're more forgiving than Sennheiser HD600/650s of what they're driven by (i.e. they sound better than the Sennheisers when plugged into a fairly average/crap headphone socket on a piece of gear, even though the HD600/650 are probably easier to drive and need less power to sound at their best) but when given a good powerful amp (and they do like something with plenty of power) the improvement in the K701s is greater than I get from putting the Sennheisers on a better amp.
So 0VU recommends around a fortnight of constant running to achieve the optimum sound quality... and while that seems rather more than my own experiences I gladly defer to his opinion as he certainly has better ears than me.
Hugh
Post by fay spook »
It is a little bit amusing that when someone from hi-fi world says they can hear a difference they are told to back it up by measurements or double blind tests.
Yes most of the headphones I have used have got better as they break in, not sure about some Ultimate Ears (armature) or some old curl-up Yamahas- they stayed crap. Much as turntable cartridges and loudspeakers do.
Does something like this help?
http://www.gr-research.com/myths.htm
http://www.head-fi.org/forum/thread/482386/building-a-headphone-measurement-lab/180
(there is a link about 4 post in on this page- it links to a pdf but the link is very long)
fay spook
Posts: 264 Joined: Wed Sep 09, 2009 12:00 am
Post by . . . Delete This User . . . »
my experience is the same as that of 0Vu... i usually whack em on a football, and run them for a week in a cupboard out of the way....
i can reliably tell the difference between a NEW set, and a run in "new" set....
without being told which is which.
i know any number of other people that can also do the same....
0VU, i'm pretty sure, doesn't need to A/B but can tell if they're run in just by picking them up and having a quick listen, the man has the longest audio memory i've ever encountered.
Posts: 2319 Joined: Mon Jun 23, 2008 12:00 am
Post by fay spook »
Nuff said by you all. I agree!!!
fay spook
Post by Axonaut »
Headphone transducer burn in is a myth. All those 50 hour burn in sessions are a waste of time. :shock:
Who says so? Not me, Horst Werner from AKG
From our experience and knowledge we cannot confirm that there is a burn in effect of the transducers taking place.
Normally the sound of headphones changes only over many years and then mainly caused by the ear pads (less low end since the ear pads get more densely by sweat etc.).
However, during the first hours of use of headphones, the ear pads - in the beginning a little stiff ... start to accommodate to the users ears and head and the sealing becomes better, as a result the bass can be increased a little, on the other hand the distance between the headphones and the ear may become closer, i.e. fewer air volume between ears and headphones is available and thus less bass.
Horst
AKG
So, you can wear in headphones (just like Hugh's shoes analogy), but you actually have to wear them, and it doesn't matter if you listen to anything or not. Probably you get a similar result if you put them on a football, or whatever.
Based on AKG's statement: blasting audio through phones left lying around overnight has no effect whatsoever. I guess this practice could be the origin of some of those '500 hour burn in' stories. I imagine a few people are diligently burning in their new headphones for weeks but rarely wearing them.
I was wondering why manufacturers don't simply burn in headphones for you - they could avoid all this hassle and confusion about burn in. I think the above statement from AKG is the explanation, and it's basically for the same reasons that manufacturers don't wear in shoes for you.
Axonaut
Posts: 70 Joined: Sun Apr 11, 2010 12:00 am
Post by ROLO46 »
Dont burn em in
Stick them in the lower oven of the AGA
Cures most pro audio problems in my house. :angel:
ROLO46
Posts: 881 Joined: Thu Nov 29, 2007 12:00 am
Axonaut wrote:Headphone transducer burn in is a myth. All those 50 hour burn in sessions are a waste of time. :shock:
Horst
AKG
Thanks for that post Axonaut.
When starting this thread, I said:
"Various 'authorities' on the net recommend 'burning-in' for 300(!) hours. Others say it makes little or no difference."
Looks like we're back where we started!
Surely any significant difference between new and 'burned-in' cans would be measurable?
Any 'evidence' produced so far has been purely subjective.
Evie McCreevie
Post by Axonaut »
Evie McCreevie wrote:Thanks for that post Axonaut.
Not really an answer, but here's a post that has it all... Apparently different viewpoints from two representatives of the same manufacturer (including a familiar name), a real test of speaker drivers demonstrating a change in response, etc...
http://www.head-fi.org/forum/thread/154481/burn-in-time-myth-or-fact
Axonaut
And when all is said and done, what are you going to do about it?
You get used to a new room, a new instrument, a new piece of equipment in various ways. So the process isn't completely one-sided!
Exalted Wombat
Horst
AKG
But I have heard the opposite from the chief headphone designer at Sennheiser.
He recommended 48 hours of pink noise at normal listening levels.
He says it's due to the glue in the headphones settling into the final position.
John Willett
