Recording REALLY long sessions
Post by johnnybigoode »
So, long story short.
There will be a DJ gig @ my bar tommorow, and the guys are even bring some old school mk2s.
I wanted to record it hard.
Last time I tried, I just routed the 'tape' output into Ableton Live, pressed record, and enjoyed the evening.
When I tried to save it, the whole thing crashed and I lost over 5 hours of audio.
I believe this happened because of the 32bit OS, the final file was just too big.
Is there anyway to automate new audio file creation when the total recording is over, I don't know, 90 minutes?
johnnybigoode
Posts: 3 Joined: Thu Jun 02, 2011 12:00 am
Re: Recording REALLY long sessions
Post by Matt Houghton »
What medium are you recording on to? There's a 4GB file size limit on FAT32 drives, for example.
Matt Houghton
SOS Reviews Editor
Post by Richie Royale »
Probably a good idead to just stop (for a second), then start every 90 minutes or 2 hours, so you might get a fractional gap, but at least it'll be two or three separate files.
Richie Royale
Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Post by grab »
If it's a DJ gig, you're only going to be recording the stereo out to FOH, right?
By my calculations, if you're recording stereo 32-bit WAVs at 96kHz, you have 5592s before you hit the limits of a 4GB file. That's 93 minutes. If you record 16-bit stereo at 44kHz, that goes up to 24347s, which is 6 3/4 hours.
Of course, if your software has problems with this, then new software is the answer. Most modern software will automatically split long recordings over multiple files to stop this being a problem. Reaper definitely does - and it costs you nothing to download and use.
grab
Posts: 2420 Joined: Sun Jul 08, 2007 12:00 am Location: Cambridge, UK
Post by Aliweasel »
grab wrote:Reaper definitely does - and it costs you nothing to download and use...
... for 30 days.
Aliweasel
Posts: 372 Joined: Fri Mar 31, 2006 12:00 am
Ugh, I would hate to use a new software in a couple of hours just for that but...
Is there anything special I need to know to do this with Reaper?
johnnybigoode
Post by Mowens800 »
Not sure if this would work on your software. Set up a second input exactly the same but don't arm it until 90 mins approaches. Just keep switching what is armed. You'll have files with overlaps which should do the job (unless when you hit arm, your software stops recording). You could test this before hand though.
You can then edit them together seamlessly after the gig and not have the short millisecond gap as described above.
Mowens800
Posts: 234 Joined: Thu Jun 16, 2005 12:00 am
The gaps aren't the problem, It's a DJ set, later I can always make some small edit to get the missing beat - the problem is... I wont be at the venue the whole evening. And the other person who could simply press F9 twice is... well... forgetful...
I'm not confident on using reaper for the first time tonite (actually, in a few hours) so I'll have to just hope for the best.
Thanks for everyone's help.
johnnybigoode
Geez you guys have it easy!
When recording shows or AGMs (THEY can go on for fekkin ever!) we ran a Ferrograph 15ips then a Brennell 15ips then reloaded the Ferrie' di da...All the time a Truvox was running DP tape at 3&3/4ips as Asaver.
Today I would run a hi fi VHS machine as a 3hour backup.
Posts: 19140 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
Post by Aliweasel »
How big can you make a wax cylinder?
Aliweasel
Post by ken long »
grab wrote: By my calculations, if you're recording stereo 32-bit WAVs at 96kHz, you have 5592s before you hit the limits of a 4GB file. That's 93 minutes. If you record 16-bit stereo at 44kHz, that goes up to 24347s, which is 6 3/4 hours.
No such limit if he records to NTFS using RF64 or w64.
ken long
Posts: 3631 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
