What audio interface buffer size do you use, and why?
Some recent tests being discussed in this PC Music thread have shown that your choice of audio interface can have a marked effect on how many plug-in effects/softsynth voices you can run, particularly at lower latencies/buffer sizes:
http://www.soundonsound.com/forum/showf ... ber=918351
The big confusion there seems to be what buffer sizes most musicians typically use/need, so let's try to find that out here 8-)
Please explain the reason for your choice with a short post e.g.
a) Monitoring live vocals
b) Playing guitar through plug-in effects
c) Playing drum pads live
d) Playing keyboards
e) Mixing/mastering
f) Composing
I suspect this will prove very useful information for audio interface manufactureres fi they know what the majority of us are trying to do with their products ;)
Posts: 22536 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Re: What audio interface buffer size do you use, and why?
OK - I voted first, and my choice of 256 is for playing softsynths - at 44.1kHz this buffer size offers me a perfectly acceptable playback latency of 6mS. I tend to leave it the same for mixing/mastering too.
Re: What's audio interface buffer size do you use, and why?
Post by Dave Rowles »
Well, I voted for 256, because that's what I generally use for tracking. on my interface at 44.1 it gives the slightly higher latency of about 7-8ms, but I don't often notice a problem with that.
However, I will add that I use a range of latencies depending on what I'm doing. For instance, I may drop down to 128 sometimes tracking something really percussive just to be safe on timings, and for mixing I'd bump it up to 512, again, just to be safe. Plus by then latency isn't that much of an issue.
Dave Rowles
Posts: 1580 Joined: Thu Feb 28, 2008 12:00 am Location: Isle of Man
Post by muzines »
In the main, 128 or 256 gives me acceptable performance for playing synths and stuff. Occasionally if there's something particularly timing critical, I might whack it down to 64.
32 puts a little too much strain on my MBP system - it's fine for just playing a simple softsynth, but playing a heavier one, particularly with other fx on, is a bit heavy.
If I'm playing guitar through FX and software monitoring, I will go to 64 (again, 32 here, by the time you are adding live amp modelling and FX processing, is a little too heavy for me).
However, the days of moving up to a higher buffer setting to mix with are long gone for me, I seldom find it's necessary to go to a 512 buffer size or something as Logic is pretty well optimised in this area.
So generally speaking, I'm at 128 most of the time for general use, and shift down to 64 for software monitoring live playing...
muzines
Mostly 256 to allow for using softsynths, but since I monitor outside of my DAW (RME TotalMix) I'm happy to run at 512 to get a bit more grunt when the mix needs it.
Posts: 21406 Joined: Tue Aug 14, 2001 12:00 am Location: Sheffield, UK
Post by Matt Houghton »
You may choose only one"
Hi Martin. I've not filled this is, as I don't use only one!
I can't remember the last time I thought of the buffer size as a set-and-forget thing: it depends what it is I'm doing. I'll set it for as low latency as I can get it if tracking V-Drums/BFD or playing soft synths via MIDI; or to free up as much CPU resource as I can when mixing very large projects with a gazillion thirsty plug-ins; or leave it at whatever it happens to be set at when 'programming' instrument parts. Like Elf, I'll use Total Mix for monitoring while tracking so the setting isn't important there.
It also depends to some extent on which computer system and audio interface I'm working with at the time, and what word-length/sample rate I'm working on.
Matt Houghton
Posts: 1594 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Post by onesecondglance »
ditto. i set it as low as it can go when recording MIDI inputs, but then whack it up pretty high when doing other things so it doesn't bother me.
onesecondglance
Posts: 1248 Joined: Wed Jan 02, 2008 12:00 am
Post by Spangler »
Voted 64 for tracking edrums - it'd be 32 if my set-up could reliably sustain it (close, but it'll occasionally blast digital noise down the 'phones).
After drums I'll track guitars through Guitar Rig at 128.
After that I increase the buffer throughout a project as demands dictate - heavy use of certain Play and Kontakt libraries will often force me up to 512 at which point I'll start to freeze tracks to decrease CPU load. I intend to upgrade my PC soon. I'd like to stick with the interface for its particular feature set.
(Tascam FW1082 / Phenom X4 9750)
Spangler
Posts: 154 Joined: Fri Jan 21, 2005 12:00 am Location: Newcastle
clicky
Post by narcoman »
Tracking.
Short as possible . Generally 128 for me.
Mixing. 1024.
narcoman
Posts: 3287 Joined: Tue Aug 14, 2001 12:00 am
Battenburg to the power of 20 - said by Richie Royale in a moment of genius. 4pm. Wed 16th Nov 2011. Remember where you were....
Post by Pete Kaine »
64 Samples and it's mostly for midi inputting via a keyboard/ midi drum pads so "C" I guess.
I will slacken it off to 128 if the need arises and it's perfectly fine response wise, so I guess I'm just using 64 because it's there and I can.
Pete Kaine
Posts: 3217 Joined: Thu Jul 10, 2003 12:00 am Location: Manchester
Post by mhaigh »
128 - i use Guitar Rig/Amplitude a lot. Can get it down to 64 but the system can be a little flakey down there. Don't move it for mixing.
mhaigh
Posts: 451 Joined: Wed Nov 14, 2007 12:00 am Location: Hockley, Essex
Post by redleicester »
64. For composing, an option that wasn't in Martin's list. :lol:
Covers a multitude of sins - VSTi, external instruments, slave machines etc.
Agree with Matt too - when it comes to mixdowns I tend to ramp it up a bit, but anything above 128 makes decent accurate playing difficult unless you adjusts your playing timing to allow for it. Come what may, the idea of anything as high as 6ms is my idea of hell.
Thank god for RME.
redleicester
Posts: 283 Joined: Fri Oct 24, 2003 12:00 am Location: England's green and pleasant land.
Ars longa, vita brevis, occasio praeceps, experimentum periculosum, iudicium difficile.
Thanks for all your replies thus far.
Oh, and I've added 'composing' as option f) :bouncy:
Sorry I didn't specifically cater for those musicians who routinely change settings depending on the task. Will those who fall into that category please vote 'None of the above', so we can include them :headbang:
Post by daedalus »
256 for me, mainly composing and softsynths. Occasional live instrumentation. Depending on the amount of VIs I will go higher (512, 1024) for mixing. However, got a new rig and will try permanently moving to 128 for composition and VIs.
daedalus
Posts: 212 Joined: Thu Mar 02, 2006 12:00 am Location: LA
Just a piano and some sketch paper please...
Post by jaminem »
Voted for 512 (and sometimes even 1026)
Why?
1. My interface has HW direct monitoring so for recording guitar, vocals and overdubs the latency means nothing to me, so..
2. I just set it high so that I have no risk of dropouts and my processing count being curtailed
3. I don't really 'play' keyboard, yes I can bang out a few chords for strings and that but my playing isn't effected by any sort of feel, as I edit/quantize afterwards any way to get the feel I need, I 'spose for playing piano type sounds it is an issue but at that point i tend to reduce it before I start mixing (and using plugins) do a take, than wang it back up again before mixing begins.
4. mixing, buffer size is irrelevant isn't it, except for plugin count?
5. for guitars I use a real amp (so HW direct monitoring again) or split the signal off to a POD type device to get the right sort of sound and then record a DI for re-amping or POD farming/Guitar Rigging later. For bass a DI sound is nearly always good enough to monitor, if not ditto what I do for guitars.
To be honest latency/buffer size just isn't any issue for me, so I don't worry about it.
jaminem
Posts: 1533 Joined: Mon Mar 19, 2001 12:00 am
Post by ken long »
1024 for transfer work (Wavelab)
512 for MIDI programming (Logic). I don't actually "play" instruments so this is fine. Low buffer on Wavelab will cause dropouts. It tend to whack it right up (this is Wavelab specific though).
Easy Martin.
ken long
Posts: 3631 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
Post by . . . Delete This User . . . »
narcoman wrote:Tracking.
Mixing. 1024.
ditto
Posts: 2319 Joined: Mon Jun 23, 2008 12:00 am
Post by Bob Moose »
I use 64 samples for realtime audio. I play keyboard and (very soon) drum controllers so I need near-zero latency. When CPU load is an issue, which almost never happens for me, I switch to 128 or 256, but never above as latency would become too noticeable.
Most DSP softwares I use are quite CPU-friendly so these settings are valid for my 5-year-old laptop too. The exception is when needing lots of voices on polyphonic samplers. But I prefer keeping the latency low so I simply reduce the number of voices. For example, on my laptop that has a 5400rpm drive, I am using Ivory Italian Grand with all features enabled, though only 36 or 48 voices of polyphony, but the latency is still set to 64 samples.
I still do not have Kontakt and use a custom Max/MSP polyphonic sampler but as it is very simple it does not require a top computer for getting enough voices.
Also, when requiring an additional complex "tape" track in live I render it to a wave file instead of processing it in realtime, so that the CPU can be used for the actual live playing.
When working in non-realtime or when recording, latency does not matter so I may go up to 1024 samples, but it is rarely needed in practice, then finally I leave the latency to 64 samples most of the time on desktops, and 128 or 256 on my old laptop. I do not like working with huge projects, so for very complex tracks I break the workflow into logically-structured small projects. Anyway a big part of the processes is not even done inside the DAW.
Sometimes, I also program some very complex DSP processes that could not be rendered in realtime, so I render them in non-realtime and then use the files I get as new audio samples.
If I was using 10 convolution reverbs at the same time, or some of the newest "emulation" VST instruments, or if I made 64-track projects with lots of plugins, things would be different I'm afraid.
EDIT: I forgot to precise that I only use 44100Hz or 48000Hz sample rates and do not plan on using other rates in the future (48kHz when working with images of course)
-j
Bob Moose
Posts: 694 Joined: Thu Jan 17, 2008 12:00 am
Post by gregrs »
a) monitoring live vocals
On my PC (running Reaper) using a Focusrite Saffire Pro 40 I use 128 - minimal delay without any clicks or pops. Also tend to use zero-latency reverb e.g. EpicVerb.
d) playing live keyboards
On my MacBook using a Focusrite Saffire LE I use 64 for playing keyboards through MainStage.
e) mixing
PC/Saffire Pro 40 again... 1024 because the delay doesn't matter and it runs smoothly
EDIT: made clearer after I saw the a-f list above...
gregrs
Posts: 44 Joined: Sun Jan 09, 2005 12:00 am
Post by ElGreco »
I play my guitar live through effects plugins with a Scan 3XS laptop and an RME Babyface @ 128 samples & 96KHz. This gives me a RT latency of 4.32ms.
But I would like to note that personally I think that the ASIO latency and the process (mixing, playing guitar live, composing etc) by themselves don't mean anything.. One should take into account the Samplerate too and most important if the audio card is a PCI or external (firewire, usb). External audio cards have hidden buffers that give greater roundtrip latency than internal ones at the same ASIO setting.
So, the question would be: at what roundtrip latency do you feel comfortable to mix, monitor live vocals, compose etc?
ElGreco
Posts: 128 Joined: Mon Sep 27, 2004 12:00 am
ElGreco wrote:External audio cards have hidden buffers that give greater roundtrip latency than internal ones at the same ASIO setting.
True, but many people posting here (including me) are primarily playing softsynths, so round trip latency isn't applicable. Moreover, once you start asking people about round trip latencies including hidden/safety buffers, extra latency due to converters etc. the question can become overly complicated to answer.
I also suspect many musicians won't actually know their real world latency - I use the excellent CEntrance LTU to manually measure this value, but I suspect its results might come as a shock to some musicians :beamup:
Post by Andi »
64 because I can. I track at 64 for monitoring purposes and generally just leave it there unless I get crackles when I'm mixing, when I'll go to 96. Good old RME!
A.
Andi
Posts: 672 Joined: Thu Sep 02, 2004 12:00 am Location: Berkshire, UK
A
Post by mosso »
I use 256 at 48kHz and that's for composing and playing softsynths. I'd prefer 128 but that's a bit too much strain for my (admittedly old) MBP.
mosso
Posts: 49 Joined: Thu Jul 10, 2008 12:00 am
I tend to go for 2048 with my RME Hammerfall 9636 card but that's down to problems with Adobe Audition V2 which has big problems with its performance. Even though I rarely use Audition 2 nowadays, I've still stuck with that setting as reliability is more important than latency for most of what I do.
Of course, I'll take it down to 64 or 128 when using virtual instruments.
James.
Posts: 16919 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Post by TheBazmeister »
Mixing. 1024.
Same. Only use small buffers when tracking things I need to hear live through headphones though - Cubase delay compensation means you can lay down synth tracks at any old latency, as long as you monitor your synth through an amp or whatever.
TheBazmeister
Posts: 69 Joined: Sun Jun 04, 2006 12:00 am
