Project Ukulele
Re: Project Ukulele
Thanks guys :)
It was seriously stressful waiting, and a great relief when it came out so well. I really had doubts about one of the splits closing fully.
Going forward, now I've had a chance to examine the back I've discovered that I won't need as many cleats as I feared. The braces will do a lot of the work. And I've decided to put a flatter curve on the new braces just to ease the stress on the repaired back.
Just off now to make a start on those braces.
Re: Project Ukulele
Post by Frisonic »
So Andy, if it is you that's won that £160m how much do you think it would change your life? For example, my guess is that rather than pay someone to finish building these ukes you would instead build yourself a workshop fit for a god, sure... but would you still have time to moderate these forums or dump us in favour of a higher form of philanthropy? Or just go mad for a few years on fine wine and dubious women!
Frisonic
Posts: 2951 Joined: Wed Jan 27, 2010 12:00 am Location: Refugee currently in transition.
Still strictly project but lately on the run.
Re: Project Ukulele
Ah Frisonic, now there's a thought....
And I still haven't checked my ticket yet... But it's £166 Million, not 160... and just to put that missing £6,000,000.00 in context...
That alone is enough to purchase a fine Mews residence in Central London, a small farm in the country with enough space for a multitude of workshops and studios, an orchard, and some woodlands. Then to equip the workshops and studios, including some CNC machines, get training on Autocad and using the CNC machines, stock up with loads of materials...
And, of course, fine wines, fine whiskies, copious amounts of cider, and a constant supply of the finest, most dubious, women ;)
And yes, I'd still be here and enjoying myself. The only difference is that instead of downloading pdf's to help answer questions about equipment I don't have to hand, I would be resisting the temptation to buy one or two for my own collection so I can test my solutions first ;)
But until that happy day...
Here's a pic of the new braces already radiused and ready for glueing. I've decided to take a few extra precautions to help avoid future problems with the back. So first of all, I've put a slightly flatter radius on these, 2mm on the lower bout and 1.5mm on the other two. I'm also going to cut them lower and generally make them a lot lighter so the whole back can flex a little more once re-assembled. And I've also decided to glue them on one at a time using clamps rather than do them all together with the go bar deck. That will avoid the risk of the go bars rocking the braces over and hitting the back (if you remember, I had a few battles like that originally and have to consider whether that might have contributed to the problem).
And here's that first brace glued. I used the hide glue again seeing as everything was to hand and everything went smoothly. I'll glue the other two over the next two days, and then add cleats where needed.
Re: Project Ukulele
Very pleased to see these pictures. Great stuff :bouncy:
Posts: 20880 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Re: Project Ukulele
And what do you do when you've glued the first brace?
You glue the next one :)
And as you can see, this time I dug out the Klemsia type clamps because they have a longer reach.
And then, I did some boring but useful stuff. I put the drill in a bench mount, chucked up the brass bristled brush, and cleaned up a bunch of stuff. I do like keeping my tools in good condition :)
Re: Project Ukulele
OK, I know it's not exciting, but for the sake of completeness...
2 shots of the third brace glued. All things being well, tomorrow I'll make the cleats and glue them too.
I won't comment on how someone else came to be given MY winning lottery ticket!! However, I am amazed at how otherwise intelligent people agree to be identified as lottery multimillionaires.
Re: Project Ukulele
I hope you aren't thinking of being a professional Uke builder Andy. This would have to be the world's most expensive Uke by a long way you if you wanted to make a profit. ;) Have you set yourself a date to finish?
Re: Project Ukulele
Post by Studio Support Gnome »
I dunno Wonks.... an old mate of mine by the name of Gordon Markendale, used to build ukes for George Harrison, and oh boy, can he can take TIIIIIIIIME to produce stuff.....
Posts: 3025 Joined: Tue Jul 22, 2003 12:00 am Location: UK
Mostly Retired from Audio.... If I already know you I'll help,  if not....    Ask Hugh Robjohns, unless that is you're in need of 80's shred guitar... that, I'm still interested in having fun with...
Re: Project Ukulele
Andy has yet to finish. Gordon may yet be outdone!
Re: Project Ukulele
Post by . . . Delete This User . . . »
I've got an SG i started rebuilding 12 years ago, still in bits,,... i think the record is safe.....
Posts: 2319 Joined: Mon Jun 23, 2008 12:00 am
Re: Project Ukulele
And how's Dave B's Frankenstein coming along?
Re: Project Ukulele
Wonks wrote:I hope you aren't thinking of being a professional Uke builder Andy. This would have to be the world's most expensive Uke by a long way you if you wanted to make a profit. ;) Have you set yourself a date to finish?
Yep.....
EVENTUALLY !!!!
But if I was building professionally I would be doing it very differently. For a start, I would need a proper workshop. And I would be working full time, not a few hours each afternoon. And I would be using a lot more jigs, moulds and machines.
This project is more about what someone could achieve using basic tools and techniques working in their shed.
But once this project is finally finished, I will be building the jigs and moulds for a 'production model' that could be built much quicker. That will include a side bending machine, a sanding thicknesser, router templates for necks, fretboards, braces, fret slotting tools, jigs for cutting binding channels, and so on.
I already have all the woods and hardware for the production prototype, Koa front back and sides, Indian Rosewood neck, very pretty :)
Re: Project Ukulele
Go for it! But the Uke craze could all be over before you get started. I hear bagpipes could be the next big thing. ;)
Re: Project Ukulele
Bagpipes!! I'll need a lathe for those!! Would you settle for Bagpuss?
But meanwhile, all three new braces are in place.
And from there all I needed was to put some cleats across the glued splits... and here they are
I used offcuts from the back, cut into diamondish shapes and bevelled the top edges. Then applied them with hide glue again. No need for clamps, these were all rubbed joints. You apply glue to the cleat, place cleat on the back, and rub the cleat against the back until it grips. Then hold in place for a few moments until the glue starts to gel. They hold in place easily, the gel stage is enough to hold them safely. Hide glue dries in two stages, the gel stage is the initial grip, and then it fully dries by dehydration. As the water dries out, the glue shrinks and pulls everything together tightly.
Day off tomorrow
Re: Project Ukulele
Post by Jumpeyspyder »
zenguitar wrote:Bagpipes!! I'll need a lathe for those!! Would you settle for Bagpuss?
Sorry couldn't resist:blush:
Jumpeyspyder
Posts: 1363 Joined: Fri Jan 20, 2006 12:00 am Location: Yorkshire
Re: Project Ukulele
Back to work this afternoon...
And time to get those braces in shape. And rather than high and tapered, this time it's low and square.
Lovely pile of wood shavings there :)
And then it was time to start cleaning up the body ready to refit the back.
Guess I'd better put some thought into how I clamp the back on before I rush ahead :)
Re: Project Ukulele
Post by Frisonic »
Looking good Andy.
Frisonic
Re: Project Ukulele
I want to see it finished by tea-time.
Re: Project Ukulele
Oh, it'll definitely be finished by tea-time, just not sure which tea-time ;)
Meanwhile, back to the back...
And that's the old braces out. Just need to trim them back flush to the kerfings. Then trim out the kerfings to accept the new braces.
With good planning, and a little luck, the new braces were a good match to the old ones. So mostly it was cleaning out the old notches, just one edge needed extra trimming. So now it's ready to glue tomorrow.
And I took some time to prepare the Go Bar Deck of Doom once more, and to make sure the Go Bars are all the same length. I'm doing all I can to minimise risk.
I still haven't decided whether to go with the white glue or the hide glue. I'll sleep on the thought, but a lot depends on the weather tomorrow I think.
Re: Project Ukulele
Ah yes. The case of the exuberant go-bars :bouncy:
You seem to be really zipping along now - great stuff :)
Re: Project Ukulele
What about yellow glue - aliphatic resin adhesive?
Jumpeyspyder
Re: Project Ukulele
Ah... it's times like this when I wish I had all the references or links to hand. But, essentially, 'Aliphatic Resin' is a posh name for PVA. It tends to be applied to the part of the family that has less slip, Titebond and some Humbrol wood glue are good examples, and because they have the yellowish colour those are known as yellow glue. But the white Humbrol glue I'm using is just fine for the purpose.
It all went smoothly, no crises to deal with. Apply glue to kerfings, apply back, place first 6 Go Bars, final adjustment, and then load up the rest of the Go Bars.
I've got to finalise the headstock designs now, and get back to carving the necks.
Re: Project Ukulele
Post by Dan LB »
Looks like a job very well done - let's just hope the go bars all stay in place until the glue dries!!
Dan
Dan LB
Posts: 1691 Joined: Sat Jan 28, 2006 12:00 am Location: Wicklow, Ireland
Re: Project Ukulele
Post by Frisonic »
Can't wait to see what you decide to do for the headstock and what drives your choice (tone, balance, robustness, aesthetics).
Frisonic
Re: Project Ukulele
Headstock design... not too big, not too small, looks good, relatively straight string pull. Gotta do some lay out drawings and finalise a couple of designs. But largely head-scratching, thinking, drinking and smoking, until I have a clear mental picture of what will work. Once I have that, I can draw it accurately and make templates.
Meanwhile...
the back is back :)
All in one piece and looking good. And one very relieved luthier :)
Gotta get online and order replacements for the sacrificed bindings soon. And maybe see if there's anything else I might need for the future that I can get it at the same time.
