Glue for soft plastic
Post by aekoi »
Hi there,
Im trying to beef up a cheap multicore and suggestions for glue that bonds soft plastics strongly would be handy. I'm making the multicore strands thicker by wrapping a sheath from a 'hollowed out' guitar lead round them to improve XLR grip.
I've used Loctite Sort Plastic glue. Pretty useless tho. Any suggestions would be great.
aekoi
Posts: 366 Joined: Wed Jun 26, 2002 12:00 am Location: Not of this Earth
Re: Glue for soft plastic
Post by Jumpeyspyder »
If you just want to beef up the strain relief take a look at heatshrink sleeving.
Jumpeyspyder
Posts: 1363 Joined: Fri Jan 20, 2006 12:00 am Location: Yorkshire
Jumpeyspyder wrote:If you just want to beef up the strain relief take a look at heatshrink sleeving.
+1 You can use heatshrink on it's own, or if you need greater thickness you can use heatshrink to hold extra sheathing in place.
Or if you want belt and braces, you can put multiple heatshrink sleeves on top of each other, each one about 10-20mm shorter than the one underneath. That way you build up a nice strain relief with no stress point :)
Posts: 20889 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by aekoi »
Lots of heat shrink lovers here! Thanks for the suggestions. a colleague suggested attaching a small cable tie just behind where the inner clamp of the XLR is supposed to (with standard size cable) grip. Tried it, kinda works.
How does that method .. um .. grip you? Thanks
aekoi
Post by Blue Lizard »
I find that self amalgamating tape is often quicker and handier than heat-shrink as it can be used at room temperature. I've used it to thicken out the ends of all the multicore tails that I've made for my own use.
Blue Lizard
Posts: 165 Joined: Wed Jul 02, 2003 12:00 am Location: Cleethorpes, UK
"It's not pretty, also you can't dance to it." - Frank Zappa www.bluelizardstudio.com
Post by . . . Delete This User . . . »
you can also get adhesive lined heatshrink , ....
bicycle tyre puncture repair kit rubber solutions can also be useful in these sorts of applications....
Posts: 2319 Joined: Mon Jun 23, 2008 12:00 am
aekoi wrote:Lots of heat shrink lovers here! Thanks for the suggestions. a colleague suggested attaching a small cable tie just behind where the inner clamp of the XLR is supposed to (with standard size cable) grip. Tried it, kinda works.
Cable ties only give protection against pulling, not twisting - you be amazed at how tightly the wires can get twisted together if the cable clamp is weak!
Post by aekoi »
Thanks guys for all your suggestions.
aekoi
Post by aekoi »
Found a suitable glue - Evostick Serious Glue. And yes, it does do what it says on the tube.
aekoi
