Studio monitor stands seem to come in two types - low cost and shaky or high cost and ugly except for the elegant Blue Sky The Stand .
The Stand is a premium priced stand that combines good looks with steady support and adjustability.
The Stand, generically named, can hold near field monitors up to 80 lbs each. I'm not sure if I'd go put them to that test, although they are very stable at 30 lbs.
For most powered studio monitors, The Stand can position the monitor height between 33 inches and 45 inches, on any horizontal plane and vertically plus or minus 20 degrees. That should look after most situations in a home or project studio.
Monitor Stands compared
Studio monitor stands range from the low cost On Stage stands around $80 a pair to Sound Anchors around $650.
It is inevitable that you're going to bump into the monitors or stands while wiring or adjusting something around the mixing desk. You don't want the monitors falling down.
While the On Stage stands have a stated capacity of 90 lbs, they become unstable at 20 lbs or more. The leg and stand assembly are too weak and the stand will sway. Trusting them with expensive powered near field monitors seems foolhardy. Even 20 lb Dynaudio BM5 or BM6a monitors swayed on them.
Raxxess and Argosy (range $300 a pair) stands achieve more vertical stability by using two legs or a boxed leg. They also allow sand filling to give the stand more mass.
Sound Anchors (Studio Economik) are made from welded steel and are the tanks of studio monitor stands. They are not particularly handsome but are not going to drop the monitor.
All of these stands suffer from relatively narrow bases which can create lateral instability. Given the monitor is at least 3 feet up in the air, there is considerable vertical leverage to the monitor which causes swaying. It makes me nervous.
Blue Sky's The Stand has a 30 inch wide base, more than double to 10 x 14 inch base of the Sound Anchors. However, with the four leg configuration, the stand nests in closely with other gear and doesn't get in the way. Each stand weighs 25 lbs.
Height Adjustments
The Blue Sky Stand adjusts in height from 33 to 45 inches in 3/4 inch increments with an ingenious mechanism.
You put one foot on the cast iron base and simply lift the monitor to the desired height. At each 3/4 inch increment, there is an audible click which is locking the inner and outer cylinders. It's quite simple and easy and felt secure with a 30 lb Klein + Hummel 0300 monitor on the stand.
To move the monitor down, you have to lift the inner cylinder to its maximum height and push it gently to the bottom of its travel. At that point you lift up to the desired height.
When the stand and monitor are installed in a tight spot, returning the monitor to the lowest setting may require moving things out of the way.
The Raxxess and Argosy stands are not adjustable. Sound Anchor Compact Adjustable is adjustable with two bolts to secure height.
Mounting the studio monitors
The Stand comes with a main bracket for easy installation of Blue Sky monitors, for which it was designed.
Blue Sky Monitors have mounting brackets on the bottom which screw into the main bracket.
The bracket allows + or - 20 degrees of angle if you want to aim the speakers downward for instance.
There is an optional bracket for mounting other monitors that provides a wide base plate and safety strap. They are sold for $90 a pair.
However, you can remove the mounting bracket and install your own bracket or plate using a 1/4 inch coarse threaded 3/4 inch bolt.
Stability
The Stands are made with care. The cast iron bases are perfectly flat. In case your floor is slightly uneven, adjustable rubber feet can take up the slack. You can also install feet for carpet although they are not supplied.
I was impressed by the quality of the manufacturing. The base and cylinders came in two boxes. Assembly was well explained and easy.
Other than a tiny bit of play between the two cylinders, there is virtually no side to side movement in The Stands supporting 30 lb studio monitors. It's the first time I have felt confident with mounting my K+H O300s.
I will follow this review with details of how I adapted The Stands to support the K+H O300s.
