Violins and Cello
Violins and Cello
Post by R.T.D. »
Hello!
I'm going to record two violin and one cello in a small church tomorrow. I do want to capture a bit of the church acoustics, but not all of it.
I'm going to record all 3 the instruments together at the same time.
What is a good microphone placement to use? Mic them all seperately or make one setup with a few mics like a ORTF?
R.T.D.
Posts: 4 Joined: Sun Mar 18, 2012 12:00 am
Re: Violins and Cello
Post by Bob Bickerton »
I'd suggest an ORTF setup with maybe a couple of room omnis.
What mics do you have? Is it a concert or just a recording session?
Bob Bickerton
Post by R.T.D. »
It is for a recording session.
The mics I have available:
Neumann KM-85 (2x)
AKG C414 (2x)
AKG C451B (4x)
AKG C5900
Audix C111
Sennheiser MD-421
Shure SM57 (4x)
Shure SM58 (4x)
R.T.D.
Post by twotoedsloth »
You might consider putting two c451s in an ORTF or XY pattern, the remaining two c451s on the violins, and the 414 on the cello. Ideally you won't need the spot mics, but it can be helpful if you're jammed up after the fact.
twotoedsloth
Posts: 1136 Joined: Sat Jan 26, 2008 12:00 am
Post by R.T.D. »
Thanks for the info! I will do a little bit of extra research on the ORTF and going to use it. The tip about the spot mics are also really handy.
R.T.D.
If the C414s are the B-ULS model I'd use those as the ORTF pair. I find 451s a little bright for strings.
I'm not familiar with the KM-85s, but I'd imagine they would make good spot mics.
Bob Bickerton
Post by Hamund »
R.T.D. wrote:It is for a recording session.
Neumann KM-85 (2x)
AKG C414 (2x)
AKG C451B (4x)
AKG C5900
Audix C111
Sennheiser MD-421
Shure SM57 (4x)
Shure SM58 (4x)
your kidding - right? - I mean who would have that in the box? I'd go for the Sennheiser. 4 sure
Hamund
Posts: 48 Joined: Thu Feb 16, 2012 12:00 am
Post by R.T.D. »
Thanks for all the info! And no, I'm not joking.
R.T.D.
The Sennheiser is a dynamic mic, probably not the best mic for a stringed instrument, in my opinion.
I might be wrong.
twotoedsloth
Post by Persuazion »
Neumann KM-85 (2x)
AKG C414 (2x)
AKG C451B (4x)
AKG C5900
Audix C111
Sennheiser MD-421
Shure SM57 (4x)
Shure SM58 (4x)
You're kidding... right???
Persuazion
Posts: 909 Joined: Sat Oct 29, 2005 12:00 am Location: Scotland
