Nuisance neighbour evidence..Need some recording advice
Post by techmonkey »
Hi all,
I have a nuisance neighbour in the flat directly below mine who plays loud bass music all day and I need a way to record it so it picks up clearly for evidence purposes as I'm planning to take legal action.
I have tried recording using a variety of cameras, both with the internal mics and using external mics but none of them seem to be up to the job as the bass noise/music does not pick up.
The type of bass is a booming thud thud thud type, from dance music and although you can't hear the music from my flat, you can certain hear the bass. If I stand outside the door of the neighbours flat I can hear the music and pounding bass very clear but again, it's hard to record clearly on my cameras.
I'm wondering if anyone can recommend some equipment or a certain type of mic I should buy to record this type of noise?
I have an old Aiwa MD recorder which has a mic sensitivity switch and adjustable digital mic input control setting on the screen which I could try using perhaps with a decent external mic? I also have been looking at those pocket digital "dictaphone" recorders, not sure if they would be up to the job.
If there is any professional equipment which is not massively expensive (my budget will run to £200 or so) which can record noise levels and vibration on floor etc, that would be even better.
I'd appreciate any advice!
Paul
Note: I have been through the usual Council complaint procedure had their "black box" recording equipment which you are only allowed to keep for 3 weeks. As it turned out, it was a locked briefcase containing a Sony Minidisc recorder with the standard wired remote control/mic outside the briefcase. This is what the Council uses for court evidence.
techmonkey
Posts: 13 Joined: Tue Mar 27, 2012 12:00 am
Re: Nuisance neighbour evidence..Need some recording advice
Post by ramthelinefeed »
You don't say where you are based,
but here in Brighton, one phones up the Environmental Health 'Noise Patrol' people at Brighton & Hove City Council, and they send round two slightly frazzled put-upon public sector types with a clip board, who personally stand in your living room and assess the nuisance-factor of the noise with their ears.
ramthelinefeed
Posts: 2433 Joined: Mon Jun 23, 2003 12:00 am Location: UK
A weasel hath not such a deal of spleen as you are tossed with!
Post by Richie Royale »
Have you spoken to your neighbour about the problem?
If that fails then contact your local Environmental Health team (if you are in the UK) to see if they can help. They should come out and check the noise level with an SPL meter.
Might be worth having a look on this site
http://www.noisyneighbours.net/
Richie Royale
Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Post by necromunger »
you can get a cheap db meter to see how loud it is but just ring the council and they will send someone out with the right equipment as by law it has to be calibrated to be used in court and those meters costs 2-3k.
have you spoken to them about it or are they the f u about it.?
http://www.amazon.co.uk/dp/B0015NSTLI/ref=asc_df_B0015NSTLI7156790?smid=A3P5ROKL5A1OLE&tag=googlecouk06-21&linkCode=asn&creative=22206&creativeASIN=B0015NSTLI
necromunger
Posts: 388 Joined: Fri Mar 10, 2006 12:00 am
Thanks for the replies guys.. I should have provided a bit more info I guess and just added on the PS as an after thought! To give some more background... this problem has been going on for like 5 years and the Council and Environmental Health have been lets say, less than helpful over this time. Even the police wouldn't do anything.
The neighbour really is the "neighbours from hell" and are totally unapproachable..they basically shout "f off" if you knock and turn the volume up.
So what I'm doing now on the advice of my solicitor is seeking a County Court injunction against the Council, as it's easier than going after the tenant in the Magistrate Court apparently. But I need a water-tight case with good evidence..hence I need some good recordings.
My solicitor actually warned the Council we would take them to court and so now the Council is requesting to look at my evidence. I have a diary log going back 5 years, camera recordings, photos etc, but nothing good on the audio side.. hence why I'm here!
techmonkey
This is rather complicated..EVH's definition of what is a noise nuisance, and mine, are lets say, somewhat different!
EVH naturally goes by the legal definition but they also have all these ridiculous procedural restrictions on how long they can record for, when the noise occurs, needing two witnesses and not being able to witness out of office hours etc etc. In short, their procedures and restrictions means the tenant is able to cause a nuisance and get away with it and EVH don't consider it a "statutory nuisance".
I actually had a noise abatement notice issued against the tenant by EVH quite early on in this complaint, which the tenant subsequently breached. EVH were unable to witness a breach due to their restrictions and so the tenant got away with it. And because the tenant was not living in the flat for a long time, and kept spending odd days there, EVH have maintained that it's no longer a statutory breach.
My solicitor takes a different view and thinks the Council have legal responsibilities that go beyond the Environmental Health Act and that the Council and EVH have not done enough and aren't carrying out their legal duties.. in the last 5 years EVH have only visited the tenant a handful of times (and on only 3 of those have actually spoken to the tenant). Despite dozens and dozens of complaints.
In short, my solicitor thinks with the amount of evidence I have over the last 5 years, we have a good case for compensation and a Court injunction forcing the Council to act against the tenant, but good audio recordings of the noise would make for an iron-clad case.
techmonkey
Post by grab »
Worth getting a cheap sound meter - they'll only cost £10-20. ("A-weighting" is the type you want, I believe.) Recording will only give you what the noise sounds like, not particularly how loud it is, so this will give you some nicely formal numbers to put in your noise diary.
grab
Posts: 2420 Joined: Sun Jul 08, 2007 12:00 am Location: Cambridge, UK
Another solution, featured in the BBC documentary 'The Day Today', is simply to go round to your neighbour's flat, smash in the door and unleash a TIGER.
I do sympathise re: the public sector loonery of your local Council.
B&HCC's binmen used to wake me up at 6am every morning. Which more or less contravenes the law (which basically says they should wait until 7am to wake me up ;)
Their Environmental Health people agreed, but said they couldn't do anything because "we can't take ourselves to court" :headbang:
Narrowly avoiding facepalming myself unconscious, I suggested to them that they shouldn't NEED to take themselves to court, if they just STOPPED BLOODY DOING IT, being, as they were, well aware of their own breaking of the law.
But that didn't work, so I just moved house instead.
BEST STORY EVER. :D
ramthelinefeed
I am pretty surprised, though, that your local council's Environmental Health people cannot witness breaches "outside office hours" - not least because one of the typical rules of legal thumb for whether noise constitutes a "statutory nuisance" is that it is occuring between 11pm and 7am...! How can they ascertain this if they only work 9 to 5!?
Brighton's lot will come round as late as 3am at the weekends.
This suggests to me another route: your council will have a formal Complaints procedure. If you follow that, and don't achieve satisfaction, you can take the matter to the Local Government Ombudsman. This would be a damn sight cheaper that taking the council to court.
ramthelinefeed
PS I am also slightly perturbed that your solicitor was not aware of the Local Government Ombudsman. But then I dare say they'd prefer you to pay them to take the matter to court instead...
ramthelinefeed
Most of the noise that upsets you will be low frequency noise, and that is quite hard to capture with typical consumer recorders because they usually automatically filter the very low freqencies to provide a better, rumble-free recording quality!
To record it effectively you'll need a boundary or pressure zone mic -- or a contact mic -- fixed to the ceiling (or maybe a wall), and recorded with something that has a flat resposne down to 10Hz or so.
There's lots of things that would do a reasonable job... but specific advice will depend on your budget.
Hugh
Hugh Robjohns wrote:Most of the noise that upsets you will be low frequency noise, and that is quite hard to capture with typical consumer recorders because they usually automatically filter the very low freqencies to provide a better, rumble-free recording quality!
This is an excellent point - but conversely, will the court have a PA rig with bass bins and subwoofers capable of reproducing sound down to 10Hz ? :round1:
ramthelinefeed
Post by ken long »
^ they don't need to listen to it. figures should suffice.
ken long
Posts: 3631 Joined: Mon Jan 21, 2008 12:00 am Location: Somers Town
I'm All Ears.
Post by narcoman »
You live in a flat?
then the properties will be owned under leasehold. Contact the the owners of the lease or the maintenance company. It will be in breach of the terms of the lease and will affect thew mortgage on the property. If the neighbour is a leaseholder his mortgage may be in jeopardy under such a breach OR if he is a tenant his landlords mortgage will be.
Either way - contact the maintenance company or his landlord if he is a tenant.
narcoman
Posts: 3287 Joined: Tue Aug 14, 2001 12:00 am
Battenburg to the power of 20 - said by Richie Royale in a moment of genius. 4pm. Wed 16th Nov 2011. Remember where you were....
Post by nathanscribe »
feline1 wrote:I am pretty surprised, though, that your local council's Environmental Health people cannot witness breaches "outside office hours" - not least because one of the typical rules of legal thumb for whether noise constitutes a "statutory nuisance" is that it is occuring between 11pm and 7am...! How can they ascertain this if they only work 9 to 5!?
Councils. Enough said. I went through the complaints procedure when I lived on a narrow alley with a pub opposite the flat (it had been a cafe at first) that the landlord used for personal and very loud parties after hours at random times of week until stupid o'clock in the morning. Of course, the one time the council team came round (only worked weekends till 9 or something), nobody was in and you could have heard a pigeon fart.
I kept logs, sent them, phoned back, complained again, nothing ever happened. And the police are too busy with proper crime to do anything about stupid crap like noise, unless one turns it into something by going round with a dustbin full of what comes out of the dog and pours it through their letterbox, etc.
Anyhow, I am amazed that for 5 years the OP is still living there. I'd have moved by now if there was any way at all of doing so. My utter and absolute sympathies if not.
nathanscribe
Posts: 1566 Joined: Fri Jan 19, 2007 12:00 am Location: Wakefield, for my sins.
Hugh
You absolutely right..sometimes the bass is so loud that it literally vibrates on my floor under foot, on my windows, and even on the arms of my wooden chair! It's very irritating as you can imagine never to have any peace or quiet. I get headaches from it and stressed out. If I bang on the floor she will turn it down but then it goes back up again the next day.
So I've been thinking along the lines you suggested, rather than recording the actual noise, I need some way just to record the frequency and vibration. grab suggested a meter, so that is something I will look into it. If I can get it calibrated and stamped by the supplier and film it, that might just do the trick!
techmonkey
perhaps a seismograph?
Do you have a university with a geology dept nearby? Perhaps you could get some students to come and take measurements in your flat, and get it on the local news (particularly if you could somehow incorporate a roller-skating duck).
ramthelinefeed
May we ask which local council it is?
ramthelinefeed
feline1 wrote:Another solution, featured in the BBC documentary 'The Day Today', is simply to go round to your neighbour's flat, smash in the door and unleash a TIGER.
BEST STORY EVER. :D
Oh so true, they are utter idiots! You know the worse thing is.. this tenant has breached half a dozen of the tenancy agreement conditions (drugs on premises, sub-letting/multiple friends living there, dog in the flat on 2nd floor, anti-social behaviour, drunken fights with her bf every weekend and often during the week that go on for hours and hours 11pm onwards! Like I said, neighbours from hell. She doesn't work and just sits in the flat smoking cannabis playing loud music all day. There's nothing wrong with her as I can tell apart from being bone idle and morbidly obese. It's so annoying when I'm trying to work and earn a living upstairs, while studying for a degree with the OU.
Here's how stupid the Council are.. I tipped them off the tenant was probably claiming full housing benefits and not living at the flat and was only visiting it for maybe 2 hours once a month last year (this continued for 2 years) and even offered them CCTV evidence.. they called and got no answer.. so wrote asking her to contact council within 14 days and she didn't as she wasn't there..so they served a "notice to vacate" with a deadline.. the deadline past and she contacted them with some excuse..so they canceled it and let her stay!! This despite all the dozens of complaints and breaches of the tenancy I mentioned. Perfect chance to get rid of her and save themselves a fortune in housing benefit claimed on an empty flat.
When I mentioned I had CCTV and was gathering evidence for a legal action against them (the Council) they tried to take legal action against ME to stop me using CCTV! I used a Freedom of Information Request to get all my case notes and their internal communications...they fought hard to deny it but my solicitor persuaded them to comply. I was shocked to see them discussing me with their legal department, to see if they could stop me using CCTV and whether I might be harassing the tenant!
techmonkey
feline1 wrote:May we ask which local council it is?
Redditch Borough Council
techmonkey
feline1 wrote:perhaps a seismograph?
There's an idea! I'm determined to shame the Council up if this does go to court.. it will be all over the newspapers.
techmonkey
narcoman wrote:You live in a flat?
The Council owns the building and the flats. I actually have been wanting to buy my flat for the last 3 years and hurry up and sell to move somewhere better..but I'm hesitant with this nuisance neighbour as the Council have this stupid rule that you can't sell for 5 years. I asked if they would make any exception for my situation if the problem with my neighbour escalates and they said no, no exception.
techmonkey
techmonkey wrote:When I mentioned I had CCTV and was gathering evidence for a legal action against them (the Council) they tried to take legal action against ME to stop me using CCTV! I used a Freedom of Information Request to get all my case notes and their internal communications...they fought hard to deny it but my solicitor persuaded them to comply. I was shocked to see them discussing me with their legal department, to see if they could stop me using CCTV and whether I might be harassing the tenant!
Dreadful!
Well, here is their complaints procedure:
http://redditch.whub.org.uk/cms/council-and-democracy/complaints-procedure.aspx
Have you not gone through that with them?
Once you've gone through that formal process with them, you can escalate things to the local government ombudsman.
ramthelinefeed
feline1 wrote:PS I am also slightly perturbed that your solicitor was not aware of the Local Government Ombudsman. But then I dare say they'd prefer you to pay them to take the matter to court instead...
That's the situation I'm at now.. my solicitor is just writing letters for me at moment so it's not costing me much..but it's certainly got the Council's attention! They came out last week and visited the tenant and started some dialogue with me. My solicitor gave them 28 days to take action to remedy the situation and offer alternative housing if need be, or face court action. And so I decided to try the Ombudsman now as a last resort before court.
This is what happened last week.. the Council made an unannounced visit to the tenant and asked her to put the stereo on while they watched.. they said she never touched the volume and it was "a reasonable level that wouldn't cause a nuisance". She told them she never puts it past that level and so it must be another flat. She also denied having a dog in the flat and said shes never had one there.. despite it staying there every few weeks. They took her word for it and said there's nothing else they can do. The very same day, she had the dog in the flat again brought by her bf and kept several days.. and also the loud music back on.
It seems the only thing I can do is to get solid evidence and show the Council and then if they still don't lay down the law with the tenant, it will have to be up to a judge to decide.
techmonkey
I took it all the way with the internal complaints to the top, and was speaking to the Director of the council. She assured me it would be dealt with and all her departments would have a meeting and work together, including the local anti-social behaviour officer.. she wrote back and said having reviewed all the case history, they have determined that no noise nuisance exists and the Council have acted appropriately.
techmonkey
