how to connect two audio interfaces to each other
Post by azurmai »
Hi.
Does anyone know how to connect two interfaces?
I have Focusrite Saffire 56 and Roland FA66, both have firewire 400 port and digital i/os.
Thanks..
azurmai
Posts: 22 Joined: Mon Sep 26, 2011 12:00 am
Re: how to connect two audio interfaces to each other
Post by tacitus »
In what way? Just co-existing or sending audio out of one and in to the other? That sounds to me (and I'm not fully awake yet) as useful as getting both legs down one side of your trousers.
tacitus
Posts: 1471 Joined: Mon Feb 04, 2008 12:00 am
Post by Richie Royale »
You can connect them to each other via the analogue connections or by the optical digital ones.
If you want use both together you will need to set up an aggregate device on Mac and then clock them together.
No idea about PC, but this article covers matters, which I presume are still relevant.
http://www.soundonsound.com/sos/feb06/a ... sician.htm
Richie Royale
Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Post by tim_obrien »
Best solution: Sell both and get an interface with more i/o's.
Trying to cobble together boxes is problematic at best.
You can really only count on doing it if its the same maker and they are made to run under one driver instance.
tim_obrien
Posts: 148 Joined: Tue Jul 04, 2006 12:00 am
Post by azurmai »
thanks a lot indeed. ill just have a look now.
azurmai
Ah, thanks for posting that link to my 'Using Multiple Audio Interfaces Together' feature 8-)
Most of what I said back in February 2006 still applies ;)
Posts: 22111 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
