So the most important thing here is cheap. I'm looking for a very basic soundcard for my Mac, running the latest OS, basically so I can get two outputs out of the Mac, just need two outputs, no inputs and that's it.
When I say cheap I do want it to actually make some sound when plugged in but as long as it does that then I'm happy
Sorry if its a daft question but do you need two stereo outputs? Or is it just two mono outputs that you want, in which case you'll have that with the stereo out.
At least, I think so - not used a mac in ages. Last I did they were sticking to the single mouse button, so maybe they're stubborn mono fans.
Actually what I'm trying to do is use some djing software on the Mac which needs to have a main output for the main mix and a headphone output for the headphone mix, if that makes sense
schuey wrote: Actually what I'm trying to do is use some djing software on the Mac which needs to have a main output for the main mix and a headphone output for the headphone mix, if that makes sense
And the problem with the signal from the Mac soundcard is????
They are, one is the headphone mix, which for example might be a song from the right 'turntable' and the other will be the full mix which is both left and right turntable.
Native Instruments Traktor Audio 2 is less than €100.
It's hard to think of anything with 4 outputs for much cheaper than that.
The MixVibes U-MIX 44, a 16 bit device, is around the same price.
Actually the one you have posted is perfectly suitable.
You have 3!!! outputs on that sound card. There are 2 stereo outputs (so four mono outputs) on phono outputs and also a mini jack output for headphones, which will also be a stereo output.
However, having never used anything like that myself before, I have no idea whether the outputs are individually assignable.
If the design is there you will be able to get a separate mix in all three outputs, or if its a very basic design then it will just be one stereo audio signal feeding all three stereo outputs.
Dave
NO, I'M WRONG. PLEASE IGNORE MY TERRIBLE ADVICE.
Apologies here, yes it only has 1 stereo output and 1 stereo input. The headphone output will give the exact same output as the phono output.
I THINK you have to be a bit wary with macs and usb.AFAIK any usb AI works with PC but not always with mac....But you REALLY would do a lot better with an NI KA6!
I'd go for the Native Instruments KA 2 (great convertors, tight drivers) but that's around £80. Cheaper than that I can only really think of the Numark DJIO or the Alesis io2 for about a tenner less and whilst they'll do the job I'd still prefer to work with the KA2 due to the previously mentioned reasons.
