Logic - can you teach me?
Re: Logic - can you teach me?
Start off with Garageband, spend a few quid on a couple of books from Amazon, check out stuff on YouTube, post on forums when you hit a brick wall and maybe try to explain what's in it for someone else to spare you the time. I think you need to improve your sales pitch.
- Fen_Tigger
Poster - Posts: 30 Joined: Fri Mar 23, 2012 12:00 am Location: Below Sea Level
"Playing the right notes, but not neccesarily in the right order"
Contact Eddie at www.samplecraze.com and see if he is interested in that rate.
- RegressiveRock
Frequent Poster - Posts: 1495 Joined: Wed Sep 01, 2004 12:00 am Location: Buntingford, Herts
Smoking Goats
https://www.facebook.com/SmokingGoats
Start by reading the manual…’RTFM’…?
It’s a good start,and there’s lot of information about what you can and what you can’t do with it.
BTW,I’m a newbie too and managed to use it everyday…
Good Luck for your projects!
Cheers!
Cheers!
I think you are better off staying with Cubase as you have been using that for sometime now and Logic doesn't offer anything significantly different to Cubase. You will have to learn it all from scratch, although you will find many similarities in them.
- Richie Royale
Frequent Poster - Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Richie Royale wrote:I think you are better off staying with Cubase
+1 Why have you suddenly decided to begin the learning process all over again?!
Hey you remembered me!
It took a long time to find the wonderful James Mulvale so thought I'd get an early start! I may swing back to Cubase but I've arrived at a stumbling block in that Cubase doesn't have loops. I'm not a musician.
However - I may well stick with Cubase now as I find (fresh back from Apple Centre in Southampton) audio autotune not so great and no Tango drum loop (for example) - loops galore but drums have strange names...
James doesn't have V6 and could still help with a lot but I need to get them loops in - currently hoping to raid midi loops from 'band in a box' but previous post about that yeilded nothing.
Thanks to all who responded.
nerdle wrote:currently hoping to raid midi loops from 'band in a box' but previous post about that yeilded nothing.
What did you need to know? Set up a pattern in BiaB, export a MIDI file, drop it into Cubase.
Cubase doesn't actually do independent looping, but it's trivial to emulate it by any of several methods of copying a segment as many times as required.
- Exalted Wombat
Longtime Poster - Posts: 5843 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
nerdle wrote:I've arrived at a stumbling block in that Cubase doesn't have loops. I'm not a musician.
What do you mean by 'doesn't have loops'?
Import a bar of drums into Cubase and repeat it 99 times... bingo - a 'loop'! Cubase will let you tempo-match, slice, quantise and otherwise manipulate a loop. The audio browser will even tempo-match loops while you audition them.
Yo nerdle, sup?
Hello Mr Elf and thank you for your response (as always)...
Import from where?
I'm told there are zillions of free ones on the internet - even in a lesson with a teacher I couldn't do it.
A Tango drum track would be good - with some fills etc etc
Import from where?
You've got Band in a Box? Choose the Tango style. Set up some a and b markers so you get all the possible fills as well as some bars of plain a and b. Turn off all instruments except Drums, send a MID file to Cubase. Chop it up and "loop" as you wish.
- Exalted Wombat
>Skiving off work for a year to try composing - I'll need some good luck.....
Well, yes you will, if you don't know music and you arent too quick with computers
But good luck!
I'll find you the odd hour on Skype for £20! I'm not THAT busy with other work, and I'm not too proud to admit it
You'll have to stick to Cubase and tolerate my PC. And my complete lack of interest in the loops-and-samples sort of music. I know how to work Cubase though!
- Exalted Wombat
In conclusion
No longer having to drop Cubase in favour of Logic. Lots of Mac snobbery around I find. Mike McMenemy at the Apple store wonderful yesterday showing all logic pros and cons - a few more cons than I thought.
Knight in Shining Armour upon his Skypy Steed (Mr Wombat) rescued this damsel and showed her the way forward via Band in a Box midi files and how to copy then into Cubase.
Happy!
...until I get stuck the next time.
Happy!
Good. You are better off sticking with one thing and really learning it.
- Richie Royale
Re: In conclusion
nerdle wrote:No longer having to drop Cubase in favour of Logic. Lots of Mac snobbery around I find. Mike McMenemy at the Apple store wonderful yesterday showing all logic pros and cons - a few more cons than I thought.
Happy!
She's more of a musician than she likes to admit. Should be using BiaB etc. to help her analyse the drum patterns for various styles, then writing her own from scratch.
- Exalted Wombat
Re: In conclusion
Nothing useful to post: just wanted to mention that I really like the fact that people on this forum are being so helpful.
And yes, while I'm a logic user myself, I'd advise with sticking to something and thoroughly learning it. Then go and have some fun with other tools.
Just a piano and some sketch paper please...
Re: In conclusion
Out of interest, what were the Logic "cons" that the Apple Store showed you?
But yes, ultimately, the tools don't really matter, it's the result that matters. At this level, generally speaking, all the tools are equally as good until you start getting into nit-picky things (which can of course be very important for some folks).
Re: In conclusion
desmond wrote:Out of interest, what were the Logic "cons" that the Apple Store showed you?
Having to buy an entire new computer?
- Exalted Wombat
Re: In conclusion
Exalted Wombat wrote:Having to buy an entire new computer?At least they were honest.
Don't you start...
Re: In conclusion
Exalted Wombat wrote:desmond wrote:Out of interest, what were the Logic "cons" that the Apple Store showed you?
buy a new computer?.. well only if you don't already have a mac.. the same as if you don't already have a PC and you want to use Sonar (or some other PC only program).. I don't really get your point
www.Lozjackson.com | www.audiowall.co.uk | audioshop.london
more Logic stuff
The cons were... no autotune - need it with a voice like mine, the loops were good but all designed to make 'instant composers' out of 'have a go' people. They might have been good but the drums didn't have proper names to describe them - couldn't find 'tango' for example. Band in a Box will do for now. Best to leave loops alone until happy with strong composition - then adopt, adapt and improve (sounds like the Round Table motto)!
Great plus is for £80 (and buying a mac+software) unlimited tuition for a year. The guys in there are so motivated and eager to help - refereshingly good quality customer service.
If I could go back in time I'd get a mac (after 12 years in photography) - but I'll stick with Cubase and hope it won't seem like such a foreign language one day soon.
Re: more Logic stuff
nerdle wrote:The cons were... no autotune - need it with a voice like mine
Well that's incorrect, Logic does have an auto tuning plugin that's almost an exact duplicate of Autotune.
One of the problems with Apple Geniuses is that many of them think they actually are. There's been more than a few times I've been stuck in the genius queue, probably trying to replace my defective batteries or optical drives for the fifth time, listening to a guy consulting with an Apple Genius about Logic, and my temptation has been to kind of say "Uh, dude, no. *Here's how to fix your problem, don't listen to the Apple guy, he's clearly winging it..." but instead I bite my tongue and try to ignore it.
nerdle wrote:the loops were good but all designed to make 'instant composers' out of 'have a go' people.
Well, loop content is loop content. I don't personally have a use for it in general, although I might through some things in sometimes. How you use it or not) is up to you. And Logic comes with more loop content than pretty much all other software.
nerdle wrote:They might have been good but the drums didn't have proper names to describe them - couldn't find 'tango' for example. Band in a Box will do for now. Best to leave loops alone until happy with strong composition - then adopt, adapt and improve (sounds like the Round Table motto)!
Indeed. Rather than using canned stuff, you should really learn what makes a "tango" a "tango", and be able to compose in that style. Your ears, brain and hands are the correct tools for this.
But if Band in a Box does it for you and you need that kind of help, you're probably not ready to compose from scratch yet - and I'd suggest spending a lot of time learning and making music before thinking of trying to earn a living from it just yet. At the same time, you might also be fantastically talented and be already making brilliant music in your own way, so who knows..?
So much for the cons in Logic, then, eh?
