MOTU 828 Mk ii buzzes like a bumble bee.
Post by Kolakube »
Hi all,
Just got an 828 mk ii second hand of Ebay.
When plugged into the mains with no other connections (so not a ground loop or anything audio) it buzzes. Its about as loud as a blue bottle fly trying to get out of the window. So not defining but defiantly annoying considering no fans inside or working parts.
Is this normal? Anyone else got one they can check out?
Kolakube
Posts: 1303 Joined: Tue Dec 01, 2009 12:00 am Location: Geordieland
Re: MOTU 828 Mk ii buzzes like a bumble bee.
Post by 2M »
I got one, and it is absolutely dead silent. Perhaps the power supply is faulty?
2M
Posts: 37 Joined: Sun Aug 08, 2004 12:00 am Location: Belgium
Post by Kolakube »
Hi, thanks mate.
Ill contact the seller and see whats what re a return. He seems a decent guy.
Hopefully he'll be just as decent at aftersales.
Kolakube
If you're talking about an acoustic buzz, it's probably the mains transformer laminations rattling, which is anoyingly common.
hugh
Posts: 43689 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by Magic Matt »
My HiFi amp started doing that after I moved - I figured maybe it had been knocked or bumped and we'd just not been careful enough... it was like it for about 2 months and when I was eventually looking at replacing it, it just suddenly stopped buzzing and has never done it since.
Just saying it's possible it may have been fine before being posted and it's a result of something happening during transport/shipping...
Is it possible this kind of thing could be a loose screw or a dead easy fix?
Magic Matt
Posts: 99 Joined: Fri Sep 17, 2010 12:00 am
Post by Kolakube »
Thanks guys, yes he's took the return so all good.
Kolakube
You know I would have put money on MOTU using a SMPSU?
But no, a (very!) careful perusal of the manual shows they are supplied in 100-120 or 230V format indicating a 50/60Hz supply.
Rattly mains traffs really should not happen these days, especially in such low power, high'ish end gear. If the "re owner" is looking in I would task MOTU to repair the unit free of charge and then bounce the transformer back to their suppliers for a report.
There ARE some advantages to line lumps!
Posts: 19142 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
