How can I compare different D/A converters on sound cards?
Post by Johnny Stecchino »
Hi to all,
In the moment I have 3 sound cards and I wonder which program can I use to compare the differences between the D/A converters and get to see some parameters (a part of using my ears for the checking with my very average Yamaha MSP5 monitors...)
Cards are:
Pci - Terratec EWX 24/96
Firewire - Presonus firebox
USB - Sound Devices USBPre2
Software I own already (and maybe be able to use for the cause):
NI Komplete 6
Steinberg Cubase 5.5
Thanks in advance!
Jonathan
p.s. I know this is the recording forum but I thought that will be the right place to post though my question is the opposite way around :bouncy:
Last edited by Johnny Stecchino on Wed Dec 05, 2012 8:59 pm, edited 1 time in total.
Johnny Stecchino
Posts: 324 Joined: Mon Mar 19, 2007 12:00 am Location: Roma, Italy
Pro. violinist who likes some experiments...
Re: How can I compare different D/A converters on sound cards?
Post by Fran Guidry »
You might try Rightmark: http://audio.rightmark.org/index_new.shtml
Fran
Fran Guidry
Posts: 69 Joined: Fri Apr 23, 2010 12:00 am Location: Walnut Creek, CA, USA
E ho`okani pila kakou ma Kaleponi
www.kaleponi.com & www.homebrewedmusic.com
Post by Goddard »
Might find some helpful links here.
Goddard
Posts: 993 Joined: Wed Apr 04, 2012 12:00 am
Thanks Fran and Goddad!
Regarding the Rightmark software:
in the manual http://audio.rightmark.org/downloads/RMAA%206.0%20User%27s%20Guide.pdf
"This mode requires a high-quality reference sound card for recording test
signals. Before running the test, the examined sound card output must be
connected to the reference card input" etc.
I presume in the case of the SDUSBpre2 I should contact its own IN and OUT and let the sofware runs? Right?
Thanks again! Seems like i'm gonna got lots of work to do now on the case...
Johnny Stecchino
Post by Mixedup »
To measure D-A, you need a calibrated test system, including the hardware you use to record what's played out through the converters as well as the file(s) to be played out through the system — not just some software. Think in terms of Audio Precision analysers, or Lindos test measurement kits.
Mixedup
If I were you, I'd simply listen and pick the one that works the best for you -- both aurally and practically.
Modern converters are all extremely good, and the differences between the very best and the very average amounts to no more than 6dB of noise floor and THD distortion... and that just won't be audible to someone with typical home studio equipment and less-than-perfect monitoring conditions. I'd really not give it a second's thought!
Added to which, do make a genuinely useful technical assessment you'll need measurement equipment which performs itself significantly better than the thing you're trying to test. Finding high resolution digital test files to feed out through the D-A you're interested in isn't that hard. Finding a decent analogue analyser with a sufficiently low noise and distortion performance is... and your interface A-D won't come close!
Hugh
Posts: 43690 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Thanks Mixedup and Hugh,
Hugh Robjohns wrote:If I were you, I'd simply listen and pick the one that works the best for you -- both aurally and practically.
I see,
I was wondering for the test 'couse the USBpre2 sounds very open in the high end and I even took down the highs in my monitors because it disturbs me. I wonder if it is my hearing (which is very sensitive for some frequencies) or the device, hence why I wanted to check it, but after I read all what you wrote things are clearer.
Btw: will it be possible to have a review of the USBpre2? I know I already own it but just for curiosity, to see what the professionals think.
Thanks again, and thanks for putting things in proportion.
Jonathan
Johnny Stecchino
