Any way to keep many MP3s from various sources so they all play back at same volume??
In these days of infinite everything and technology one thing really urks me.
I listen to MP3's on a PC or Apple or PS3 or anything and there all different levels. The louder ones are twice as loud as the quiet ones.
Back in the days of tape and vinyl you set your own recording level on the tape deck. So if you recorded 3 different pieces of vinyl to one tape you could get the levels similar and listening on a tape deck was way more consistent that ripping CDs to MP3 that basically all have different levels of volume.
Has anyone ever made a piece of software that turns up and down the volume level of tracks so they all match? Surely this cant be that hard? And surely I am not the only guy on earth that finds this annoying.
(Please note - I do not mean I want a compressor or limiter, something that achieves the above at the expense of zapping the dynamic range.)
Re: Any way to keep many MP3s from various sources so they all play back at same volume??
What you are almost certainly hearing is the 'perceived' loudness which is something we now have to contend with thanks to the loudness wars..
The louder MP3s are almost certainly more mordern masters which have been pumped to within an inch of their lives to sound louder (at the expense as you correctly say of their dynamic range).
This is a problem we are continuing to battle in TV land as advertising Tw*ts insist on pumping their adverts to be much louder than the programs.
Unfortunately there is no easy fix for this as as far as metering goes, they will appear to have the same peaks and most leveling algorithms work by analysing peak level.
There are a few intelligent algorithms starting to appear now from companies like Dolby and Junger to try to combat this but I have only seen them in high end(very expensive) broadcast gear
- Chevytraveller
Frequent Poster - Posts: 948 Joined: Sat May 13, 2000 12:00 am Location: Hastings
Soft: MBP 15", X-Station, LogicX, Mainstage 3, Korg legacy, Diva, Alchemy, FabFilter.
Hard: Mostly now all for sale.. but Akai MPC Live, Tasty Chips Gr-1, Roland Promars, AS Telemark, Eurocrack disease
If you're using iTunes and iOS devices, turn on the 'sound check' option which adjusts the loudness of each track to around -16dBFS.
Hugh
Hugh
Posts: 43692 Joined: Fri Jul 25, 2003 12:00 am
Cheers for the info Chevey.
In honesty I didnt expect a solution to be out there. How I wish there was though.
If im in the bath listening to my tunes (I love this, few candles on, dark room, hot water, bliss) one MP3 is half power the next is (or sounds) twice as loud then the next is ok.
The solution of course is to use my wet hands to change the volume manually. I was hoping someone could make some code that could do that for me.
Yeah I hear ya on the adverts on TV. But its counter productive I think. I mean I certainly just mute the ads because of this. Where as before I wouldn't have. So in our house there is less noise from adds than more.
In Foobar you can setup replay gain and Media Monkey will normalize tracks.
- Pete Kaine
Frequent Poster - Posts: 3217 Joined: Thu Jul 10, 2003 12:00 am Location: Manchester
Kolakube wrote:Yeah I hear ya on the adverts on TV. But its counter productive I think. I mean I certainly just mute the ads because of this. Where as before I wouldn't have. So in our house there is less noise from adds than more.
I was reading recently about a regulation which comse into force in 2014 to limit Tv & radio advert volume to a fixed percentage of the programme volume. I can't remember whether it was UK or US legislation though. It's the you tube adverts that irritate me most, although at least those of us monitoring through an external interface can mute them.
- Dynamic Mike
Longtime Poster - Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
Why do bad things mostly seem to happen to people who light up a room when they enter it?
I wrote a Windows program for this very purpose, although it only works on WAV files, but you can create MP3 files if you have LAME installed. It measures short sections of each file (by default five second sections) and calculates the RMS value filtered through a B weighted curve, and also the RMS of the entire file and you can select whether to amplify/attenuate based on the overall level or the level of the loudest section. It has a basic peak limiter to prevent clipping.
If you're interested it is at www.plompy.co.uk/software
Other options would be to get a player that supports ReplayGain, although your MP3 files have to be encoded with it.
- Rich Hanson
Frequent Poster - Posts: 3686 Joined: Sat Sep 06, 2003 12:00 am Location: Sort of near Rochester, Kent, UK
The legislation you are talking about is based around the ITU-R BS.1770 'loudness standards' which are being introduced in European TV broadcasters as the EBU R-128 standard, and in America under the CALM act using the ATSC-A/85 variation of BS1770 (which came into force last week.) Most European broadcasters will be using loudness normalisation based on these standards well before the end of 2013, and the Americans are already there.
The same standards -- albeit with a slightly different target loudness level -- will be introduced across radio, probably in 2014. The standards are currently being discussed.
Apple's iTunes includes a very similar system under he name of 'soundcheck' which measures the loudness of individual song files and writes some metadata into the file header to offset the replay level to ensure consistent loudness between tracks on playback.
I would encourage everyone to familiarise themselves with loudness metering -- it will become the default standard for all audio production within the next couple of years -- and it will finally bring an end to the loudness wars. Hurrah
Hairy Ears wrote:I wrote a Windows program for this very purpose
I would suggest that it would be well worthwhile re-visiting it and adjusting as necessary to make sure it conforms with the K-weighting filter and averging window times of the BS1770 standard.
hugh
Hugh Robjohns wrote:Hairy Ears wrote:I wrote a Windows program for this very purpose
hugh
Well, I never really wrote it with that sort of thing in mind. More to prevent my ear drums from being surprised when listening on shuffle
- Rich Hanson
Hello,
there's a software I used called MP3gain. It did a good job on that regard. Simple to use as well. Just read the manual, which is also simple.
http://mp3gain.sourceforge.net/
I've just watched a video on youtube explaining how to use it.
I think it's only for Windows. But once you get them processed, that's it.
Cheers,
Chico
Cheers,
Chico
Hairy Ears wrote:Well, I never really wrote it with that sort of thing in mind. More to prevent my ear drums from being surprised when listening on shuffle
I realise that... But it sounds like a useful program and it's not that far away from the new standard, so updating it would probably be fairly simpler and increase its usefulness and compatibility significantly.
Just a thought.
Hugh Robjohns wrote:Hairy Ears wrote:Well, I never really wrote it with that sort of thing in mind. More to prevent my ear drums from being surprised when listening on shuffle
Just a thought.
Well, I might consider it because it does need an update as some file headers cause it to sulk (I hadn't encountered BWAV when I first wrote it, for instance).
But right now, it will have to be a fairly low priority what with one thing and another.
- Rich Hanson
Rather annoyingly I thought I would make these adjustments to the code, so I looked on my work laptop where I had written it. I've only gone and deleted the source code! What's worse, somehow I managed to delete them from my backups too!!
So unless I can find the time to re-write it from scratch I'm afraid that Wave File Leveller shall remain bereft of K meter functionality!
- Rich Hanson
Ha! Found a mislaid memory stick!
I shall indeed now make a K-meter based version of the program, and hopefully sort out the sulking it does with files with certain less common headers.
- Rich Hanson
