Hi,
I've acquired a Philips LBB 9105/05 and can't seem to find any information at all about it online. It's got a brushed steel outer casing and is "small diaphragm-esque"/pencil shaped rather than large diaphragm like in it's design. It's also got a selection switch on for "M" OR "S", which I presume refers to a "Middle"/Cardioid pattern or a "Side"/Bi-directional pattern.
I just wondered if anyone could answer the following questions:
- Is it a condenser? If so, will standard +48V Phantom Power do the job? - I don't want to test it for fear that the wrong voltage might damage it...
- Does anyone have any experience of using it and if so, any preffered micing set-ups (instruments? distances etc?)
Any help would be greatly appreciated.
Cheers,
Ben.
Help with a Mic!
Re: Help with a Mic!
benhs wrote:It's also got a selection switch on for "M" OR "S", which I presume refers to a "Middle"/Cardioid pattern or a "Side"/Bi-directional pattern.
I suspect it's more likely to be Music or Speech -- the latter applying a high-pass filter.
Unlikely. I'd bet it is a dynamic mic.
hugh
- Phil Reynolds
Regular -
Posts: 184 Joined: Sun Jun 11, 2006 12:00 am
"We knocked on the doors of Hell's darker chambers..." But no-one answered, so we went to the pub instead.
aaahhh... Thanks Hugh. I'll try the fella without any phantom power and see!
Cheers for the info. link Phil - the Mic I've got looks nothing like the one on the image though... Unless they've completely redesigned the outer casing since that image was taken...
Thanks again!
Ben.
Thanks again!
Ben.
It's a DIN connector... a pretty standard connector at the time that mic was made.
hugh
hugh
