Where the **** is the hum-balance on a Hammond?
I was servicing our A100 yesterday and I realised that it was getting a bit hummy lately, so I got the Oscar out to do a simple hum balance. I have done this hundreds of times in years gone by, when I was Captain Repair-Man and I have even done it to our A100. The only thing is, I haven't done it for a while, but I was expecting to see the hum-balance pot somewhere on the output amp, but no. Nothing. Not a sausage.
I know the thing is there somewhere, but where? Anyone? Hugh?
- The Red Bladder
Frequent Poster - Posts: 3907 Joined: Tue Jun 05, 2007 12:00 am Location: . . .
Re: Where the **** is the hum-balance on a Hammond?
R22 Hum balance control is a recessed screwdriver trimmer accessed through a hole on the AO39 power amp's top plate between the small output transformer and the output tubes:
hugh
hugh
Sound effect of penny dropping!
Many thanks, Hugh! Right now, we have a band in there all month, so my chances of getting in to do the hum-balance are remote. It'll have to wait, but at least I now know where the thing is. I thought I was going mad!
Now I have to swap out a defective patch-bay strip, but that only takes a couple of minutes.
As Basil Fawlty said, "This place would run all right, if customers wouldn't keep barging in and out all the time!"
- The Red Bladder
The Red Bladder wrote:we have a band in there all month, so my chances of getting in to do the hum-balance are remote.
Tiz but the work of mere moments! Whip the back off, short the amp inputs to ground, tweak for minimmum hum, remove the short, put the back on again. Job done in under five minutes.
hugh
If nothing else decides to break and she-who-must-be-obeyed doesn't need me to be somewhere, then there is that golden two or three hours in the morning, before the producer and his engineer are still recovering from their various hangovers. I'll do it then.
Ta!
Ta!
- The Red Bladder
Hugh Robjohns wrote:The Red Bladder wrote:we have a band in there all month, so my chances of getting in to do the hum-balance are remote.
hugh
Tempting providence aren't we?
I would always recommend allowing several hours for a five minute job - especially on old valve kit. I can just see it now...
Pot has not been touched for years and is partially frozen, so you give the screwdriver a bit of a shove and it suddenly frees and hits the end-stop. Pot now makes a disconcerting clicking noise when you turn it, and there is a dead spot exactly where you want the wiper to be - and I mean dead, as there is a bit of gunge stuck to the track which lifts the wiper away resulting in both valves cutting off (no bias current). You have indeed found the minimum hum spot!
- Folderol
Forum Aficionado -
Posts: 20887 Joined: Sat Nov 15, 2008 12:00 am
It would be an unusually stable (or criminally underused) Hammond if the pot hasn't been touched in years!
And, more importantly, HAPPY BIRTHDAY Folderol
Andy
Andy
Oh yeah! Happy Birthday!
hugh
hugh
Ta Muchly
P.S.
The B3 I had in mind was indeed criminally under-used. It was also stored long-term in an unheated room on the side of a village hall
P.S.
- Folderol
Forum Aficionado -
Folderol wrote:It was also stored long-term in an unheated room on the side of a village hall
As long as the village hall was dry, it probably better that than sat unused in an overheated lounge with the generator oil evaporating to leave a nasty sticky sludge!
Hugh Robjohns wrote:Folderol wrote:It was also stored long-term in an unheated room on the side of a village hall
Don't! Just ordered some more oil for mine - first time oiling and although it's in a warm lounge it does get used couple times a week. The run motor just seemed to sound/spin up a bit sluggish today.
- Matt_Moose
Regular - Posts: 300 Joined: Mon Oct 09, 2006 12:00 am Location: Cheshire
Hammond M162, XM1. Yahama CP70B, PF2000, P200, P50m, QY100. Roland RD1000, JV1010. Alesis SR16.
