SM58 / Pre Amp - input requested
Post by Madman_Greg »
I am going to try out the options I have. But wanted get some input as to what to consider.
Problem, my interface (Mackie Satellite) does not have sufficient gain to work effectively with my Shure SM58. I end up virtually winding the gain all the way up.
Now I know I need a pre amp to raise the level of the gain, then to feed into the Mackie at line level. All I need is to increase the gain. I am not interested in adding colour to the sound etc….
So I am looking at low cost options to resolve this.
I have a Yamaha FX500, which I dusted of and tried and it works OK, but have not tried critically yet. The A2D and D2A are 16 bit, so assume I would potentially suffer with increased noise floor.
I also have a Tascam 424 Portastudio, which I am going to try for this. Unsure on the quality of the electronics and the likely hood of noise. But will give it a go. Its quite old !!
There are a number of low cost microphone pre amps on the market. Are these worth considering.
Thanks in advance for any help / input.
Madman_Greg
Posts: 534 Joined: Thu Dec 07, 2006 12:00 am Location: The back of beyond
Madman_Greg
Re: SM58 / Pre Amp - input requested
Post by Sam Inglis »
Madman_Greg wrote:I am going to try out the options I have. But wanted get some input as to what to consider.
But do you get sufficient gain when you do this? If you do and the signal is not noisy, then surely there is no problem -- the reason the preamp has the range it does is to cope with mics of varying sensitivities. Also, many budget preamps have much of their gain range bunched up in the last few degrees of travel, so it's quite normal to need to turn the knob pretty much right up with dynamic mics.
Sam Inglis
Posts: 3228 Joined: Fri Dec 15, 2000 12:00 am
The mic gets microphonic if that the right term and there is little precise control at that end of the gain knob
Madman_Greg
Madman_Greg
The mic is supposed to be microphonic! I'm not quite sure what you mean -- do you get hiss or other noise on top of the signal?
Unfortunately you are unlikely to get more precise gain control with any other budget preamp. You could perhaps use a fixed-gain inline preamp like the Cloudlifter.
Sam Inglis
Thanks, reading the clloudlifter blurb it talks about cable length
Is is worth trying a shorter cable, not sure on the actual length I have, but its one I used to use on stage, so is a reasonable length.
Madman_Greg
Madman_Greg
Cable length is unlikely to be an issue unless you are trying to send the mic signal a hundred yards, or something. I'm still not exactly clear on what the problem is here -- in what way do your recordings not sound good?
Sam Inglis
Post by shufflebeat »
When you say microphonic do you mean there's a sound of interference? If there was a dodgy earth that might account for noise and a low output. Can you try another XLR cable?
shufflebeat
Looks like you have a problem somewhere as the Mackie preamps should be perfectly capable of working with an SM58. Yes, you may have to turn the gain control 3/4 of the way up to get a sensible level but that will be the same with any cheap preamp.
James.
Posts: 16986 Joined: Mon Sep 10, 2001 12:00 am Location: The wilds of Hampshire
Madman_Greg wrote:Problem, my interface (Mackie Satellite) does not have sufficient gain to work effectively with my Shure SM58. I end up virtually winding the gain all the way up.
There's nothing fundamentally wrong with having the gain all the way up.
So what is that actual problem?
What are you trying to achieve?
What is the source and whreer have you placed the microphone relative to it?
If you are recording, what peak level are you achieving and why do you think it is inadequate?
Posts: 43690 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Madman_Greg wrote: The mic gets microphonic if that the right term
Probably not the right term -- Do you mean the mic becomes very sensitive to external mechanical vibration -- handling noise etc? Do you mean it becomes very hissy? Do you mean it picks up a lot of ambient room sound?
This is quite normal with the vast majority of budget and mid-price preamps, as others have said. Most of the gain appears in the last 10 of 15 degres of control rotation, so precise control will always be difficult.
First let me say thank you to those that replied, or read and considered replying. And let me apologies if I have wasted your time.
As I do not have a problem
Not used a lot of my gear since late 2010, due to being a bit ‘Moby Dick’ and taking a while to get to the point where I can confidently make music again.
Basically unplugging and replugging everything improved the situation, but I still need to wind the gain up a long way, but this is expected. But not all the way now !
And to reply to some of the comments
Do you mean the mic becomes very sensitive to external mechanical vibration Do you mean it becomes very hissy? No
Do you mean it picks up a lot of ambient room sound? Yes
This is quite normal with the vast majority of budget and mid-price preamps, as others have said. Most of the gain appears in the last 10 of 15 degrees of control rotation, so precise control will always be difficult. – Yes this is the case
Madman_Greg
Madman_Greg
A few numbers OTTOMH Greg,
If I try to record acoustic guitar with my NI KA6 I need the gain knob on the end stop using an SM57 at about a foot. For picked notes this puts the level just about perfectly at -20, -18dBFS.
If I be quiet(and my "playing" demands that!) the basic noise floor is around -75dBFS. If I replace the mic with a 150R load in an XLR plug noise is -80dBfs. Conclusion? My "system" is 5 dB or so quieter than I can ever get my room!
Re 16bits. I always run 24bits but a really good 16 bit device such as my A&H ZED10 is still way better than neg 75. I have not tried it (will if you like) but I doubt the same recording setup via the Z and a 57 would result in a worse noise floor. Also, for ac'git the pre amp gain on the mixer has to be pretty well advanced tha' knows.
Madman_Greg wrote:And let me apologies if I have wasted your time.
never a waste of time -- I'm sure others reading this thread will have picked up some useful pointers too...
Pleased to hear it! ;)
The SM58 is a relatively insensitive mic, and is designed to be placed very close to the source. So if it's picking up a lot of ambient room sound you are probably placing it too far from the source and thus having to use too much gain.
hugh
Post by Jim Lockhart »
Another thing you could try in order to reduce pickup of room ambience would be the use of a portable acoustic screen (e.g. SE Reflexion or Realtraps Portable Vocal Booth), perhaps along with hanging some duvets. See Sound on Sound October 2012 in the Q & A section.
Jim Lockhart
Posts: 49 Joined: Tue Jun 03, 2003 12:00 am Location: Menlo Park, California
The Sound Physicist
