jkielq91 wrote:So what kind of difference do you think there will be between the Audio Technica AT2020 and the Sontronics STC-2?
I've not used the STC-2 personally, but comparing the published frequency response plots for the two mics, the STC-2 appearas to have the typical, pronounced presence peak common to so many large-diaphgram mics. The AT2020 is, in comparison, far more flat and neutral -- the absence of a strong presence peak is why it tends to work so well with female vocalists, and what makes it such a good all-rounder -- it doesn't add a lot of its own tonality.
In the book he says that in a home recording environment with out acoustic treatment a mic around jkielq9100 is fine.
The three most important elements of a recording are the material, the musician, and the environment. You need good music, played well, and in an appropriate acoustic. If you have those, you can record it with a cheap portable cassette recorder and have somethign that people will want to listen to.
Without those, the most expensive recording equipment on the planet will only give you an accurate recording of rubbish that no one wants to hear.
So yes, a cheap mic really isn't the weakest link in a typical home recording setup -- the recording environment will probably be the weakest link, and that's why we spend so much time and trouble on our Studio SOS articles trying to help people address some of their room acoustic issues in a cost effective way.
Budget recording equipment -- whether we're talking microphones, preamps, mixers, converters, DAWs, plugins -- is generally of a quality that is comparable in most ways to the bespoke high-end equipment used at any time between the 1950s and 70s -- certainly in tersm of noise, distortion and bandwidth. So the recording equipment really isn't the limiting factor. Cheap 'monitor speakers' remain a weaklink to some extent, but room acoustics are the big issue, and that's why the professional recording studio will never die compeltely.
The AT2020 mic has been preferred over mics costing £3000 in some of our shoot-outs, and it will take a lot of improvements in the rest of your recording equipment and recording environment before you would have any validity in complaining that the mic is no longer 'good enough'.
