Korg confirm new analogue MS-20 re-issue
Re: Korg confirm new analogue MS-20 re-issue
Post by fatbenelton »
Misread your post but the point is the same - MIDI an & out via USB?
fatbenelton
Posts: 708 Joined: Thu Aug 22, 2002 12:00 am Location: Liverpool, UK
Jonny
Post by Richie Royale »
http://www.korg.com/ms20mini
Just says MIDI in and USB connector.
Not that that defeats my post above, I would be using the MIDI in only.
Richie Royale
Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Post by muzines »
fatbenelton wrote:Misread your post but the point is the same - MIDI an & out via USB?
"The MS-20 mini provides a MIDI IN jack for receiving note messages, and a USB-MIDI connector that can transmit and receive note messages. You can even connect the MS20 mini to your computer and play it from a sequencer."
I interpret that to be - the keyboard can generate MIDI notes via the MIDI OUT (USB), and the synth can respond to incoming MIDI notes.
"What about MIDI? And what’s that USB jack for?
MIDI implementation on the MS-20 is bare-bones. Via MIDI DIN cable (the standard MIDI plug), you get only note values in. That works well for sequencing the MS-20 notes, but that’s it. Via USB, you get MIDI notes in and output from the MS-20 mini keyboard.
That’s all, though. The USB port doesn’t provide any further programmability or audio.
Indeed, the one criticism I’d have of the MS-20 mini is its MIDI implementation. It’d be hugely useful to be able to use MIDI control changes for some paramter control. And, indeed, there are other synths that do allow access to at least some of their parameters. Clarification: Note that “useful” or “nice to have” are not the same as “would have made sense.” The MS-20 as a result retains its original analog circuitry, which would need to be changed for MIDI parameter control, and that in turn maintains a simpler design."
muzines
If they had built in MIDI to control the functions, I expect the cost would have doubled.
Richie Royale
Post by johnny h »
Richie Royale wrote:If they had built in MIDI to control the functions, I expect the cost would have doubled.
No way doubled! Sticking a filter control wouldn't have been too much hassle at all really, but im sure there will be ways of hacking it.
johnny h
Posts: 4405 Joined: Mon Jul 24, 2006 12:00 am
johnny h wrote:Sticking a filter control wouldn't have been too much hassle at all really...
The Korg designers obviously thought so...
...but im sure there will be ways of hacking it
From where I'm standing, I can see that accepting external MIDI note data and using it essentially to operate the keyboard contacts remotely is a relatively simple and low cost thing to do, with zero impact on the audio circuitry.
However, translating MIDI CC control parameter data into the analogue domain is a whole different kettle of fish which would require a very major redesign of the original synth circuitry, and a lot of D-As and control circuitry would need to be included which would surely defeat the whole point of the reissue, and put the price up substantially.
The bottom line is that if the aim was to include external MIDI control of the MS20s operational controls, you wouldn't really start with the MS20s's relatively simple analogue circuit topology at all.
As designed, the MS20 can be 'played' from a DAW sequencer over MIDI, and you can play a note sequence into the DAW using the MS20 keyboard via MIDI over USB. But making it go zweeeee remains a fully manual exercise! ;)
Posts: 43684 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Hugh Robjohns wrote: But making it go zweeeee remains a fully manual exercise! ;)
I always knew you were a secret Acid House fan.
Richie Royale
Post by Chevytraveller »
Hugh Robjohns wrote:But making it go zweeeee remains a fully manual exercise! ;)
Presumably it retains the CV control inputs?.. Then there are a whole host of ways of making it go "Zweeeee"
:bouncy:
Chevytraveller
Posts: 948 Joined: Sat May 13, 2000 12:00 am Location: Hastings
Soft: MBP 15", X-Station, LogicX, Mainstage 3, Korg legacy, Diva, Alchemy, FabFilter.
Hard: Mostly now all for sale.. but Akai MPC Live, Tasty Chips Gr-1, Roland Promars, AS Telemark,  Eurocrack disease
Post by BillB »
Does anyone know if the MS-20 mini works to V/Oct or Hz/V system, and whether the incoming MIDI signal can be output as a CV. Could the mini patchbay readily interface with 'modern' V/Oct modular components like sequencers?
BillB
Post by DGL. »
BillB wrote:Does anyone know if the MS-20 mini works to V/Oct or Hz/V system, and whether the incoming MIDI signal can be output as a CV. Could the mini patchbay readily interface with 'modern' V/Oct modular components like sequencers?
If it's based mostly on the original circuitry then I would guess Hz/Oct annoyingly but there must be convertors around now.
DGL.
Posts: 2320 Joined: Fri Oct 28, 2011 12:00 am Location: Portland, Dorset
http://createdigitalmusic.com/2013/02/hands-on-with-korg-ms-20-mini-exclusive-review-qa-images-video/
The MS-20 mini uses Hertz-per-volt analog control voltage. This scales differently from the volts-per-octave scheme used on Eurorack gear (among others). So, no, you can’t directly plug a Eurorack module into the MS-20 mini and expect predictable control of pitch.
Richie Royale
http://trashaudio.com/2013/01/harvestman-english-tear-namm-notes/
Because of this impending instrument release, I announce with great satisfaction ENGLISH TEAR, the first in a line of small utility modules. This module features the expected “voltage processor” attenuverter and big offset knobs, but also includes a full set of functions for interfacing to an MS-20.
Richie Royale
Post by BillB »
DGL - yes, I would have *guessed* the same :)
Richie - thanks for the clear statement and link :)
It's a shame that the homage to the original prevented built-in V/Oct conversion. The patchable MS-20 mini could have made a great basis for a low-cost modular system, but notwithstanding convertors, it seems destined mostly to talk to itself. Not a bad thing in itself, but a little limiting.
BillB
I guess they wanted to keep it as original as possible with some minor cost saving short cuts such as the smaller jacks.
Richie Royale
Post by Guest »
And that is the joy of analogue.
See also : playing synths by hand instead of sequencing them, when recording them into my DAW....something I've got back into recently.
Guest
Post by BillB »
DGL, Richie, you are both quite right. If the patch panel uses the same "law" (Hz/V) throughout, then it would have been impossible to make it interface to V/Octave systems without completely redesigning the entire MS20 circuit. It is the fact that the mini uses the SAME circuit as the original which is its major selling point.
I just hope folks realise that the MS20 patchbay CVs in/out will only interface to other Korg gear, or via converters, like the one referred to above. Of course the note in/out MIDI interface is a big help, compared to the original :)
BillB
Post by baward »
Check my Korg website for MS-20 Tips and Techniques: http://www.korganalogue.net
Cute how Korg have even replicated the original user documentation and the cardboard box from the 1978 MS-20 :lol:
baward
Posts: 431 Joined: Tue Feb 04, 2003 12:00 am
Post by Stephen Bennett »
BillB wrote: I just hope folks realise that the MS20 patchbay CVs in/out will only interface to other Korg gear, or via converters, like the one referred to above.
Really? :bouncy:
Korg MS-20 with Doepfer Dark Time sequencer.
Korg MS-20 mini with Doepfer Dark Time sequencer
Stephen
Stephen Bennett
Posts: 367 Joined: Mon Oct 14, 2002 12:00 am Location: England
New: Galasphere 347 album 'Eponymous' Feat: Stephen Bennett, Ketil Vestrum Einarsen, Jacob Holm-Lupo, and Mattias Olsson
I think quite a few non Korg sequencers will work...
I believe the Sequentix Cirklon (with CVIO option) can be set to hz/V and the Elektron Analog Four can as well.
Both expensive but I'm sure similar functionality exists in other kit......
fatbenelton
Jonny
Post by BillB »
Well, OK... but apart from the Doepfer Dark Time, Sequentix Cirklon (with CVIO option) and the Elektron Analog Four, what have the Romans... oh, sorry, wrong issue there for a moment. :protest:
I take your points (and there may be more) but its helpful to distinguish between devices capable of interacting in melodic terms and those just capable of pushing the MS20 to make widdly noises. I have never tried to interface a Hz/V with a V/Oct system, but wonder if its musically controllable? Is it like a using a log pot, where linear is required (or vice-versa) with the result that your musical scale is all crammed at one end of the control pots? Or does it make no difference with continuously-variable pots on a CV sequencer? (Incidentally, the Dark Time could just go MIDI to MIDI, so no issue there anyway).
It is worth using this forum (which ranks well on Google searches) to let the unsuspecting know that there may be issues here. Lets face it, folks brought up on VSTs often ask for help about how to connect two bits of MIDI hardware. So someone who hopes to bag an SH101 or other V/Oct gear on ebay, to go with their shiny MS20 mini, may benefit from a heads-up.
:beamup:
BillB
I
I'll tell you when my MS-20 mini arrives - I have a Dark Time.
Regards
Stephen
Stephen Bennett
Post by DGL. »
Stephen Bennett wrote:
I
Regards
Stephen
See here for voltage control of ms20 http://www.doepfer.de/faq/ms2010__faq.htm
DGL.
Post by Guest »
Blimey, more analogue goodness from Korg :
http://www.dv247.com/news/Korg%20Volca%20Analogue%20Synths%20Announced/133438
This is going to be an expensive year :)
Guest
Post by muzines »
Yeah - people have wanted Roland to reissue the 202, 303 and 606 for years, and it was Korg that actually went and did it!
Well, not really, but kinda. Korg really seem to be cashing in on small, affordable and *fun* boxes that capitalise on the physical tweaking that people have often lost since moving to software. Good for them... They aren't ground breaking, but do look fun...
muzines
Don't they look cute.
Based on the Monotron sized knobs, I'm guessing they are about the size of a a 303/606? Hard to tell and I can't see the video.
I'm already tempted by the MS20 and one or two of these might be a nice addition to the studio (like I need anymore stuff).
Richie Royale
