Best workhorse condenser microphone?
Hi,
I am looking for a good `all-round` workhorse microphone recording acoustic instruments (strings, percussion, wind/brass).
Small or big diaphragm condenser.
Currently creating a small portable recording kit (4 track pre amps, 4 microphones), so it would be great if the microphones are built to conveniently suit this use.
Cheers,
Cheers,
Re: Best workhorse condenser microphone?
Budget?
Do you need multi-pattern?
A good all rounder is a Neumann u87. I know people who wouldn't settle for anything less than a Brauner though.
In the lower end of the price range, if you want a simple good quality cardoid mic, then the AT4033 has been a good 'go-to' mic for years.
In the middle there are things like 414s .. good all rounders with multiple patterns for under a grand.
All good suggestions, but if you need to operate at slightly lower down the food-chain
then the Audio-Technica AT2020, the Rode M3 and the Rode NT5 are all worthy of consideration. The advantage of the M3 is that it can run on batteries if there is no phantom-power available.
(You'll find reviews of all of them on the SoS website.)
- Mike Stranks
My earlier post seems to have disappeared. Without budget restrictions I'd be suggesting a pair of MKH8050 super cardioids or 8040s cardioids for duties you mention and portability (do you mean location recording?) but really, it's all to do with budget.
- Bob Bickerton
Longtime Poster -
Posts: 5641 Joined: Fri Dec 20, 2002 12:00 am
_ Six _ wrote:I recently picked up an AT4033a on The Bay for £100. Everything I point it at sounds great.
There's a reason for that - for the price it's a remarkably good mic. Without knowing the budget (so being conservative on price) I'd say AT4033a if vocals are likely, Rode NT5 or NT55 if not.
- ConcertinaChap
Jedi Poster -
Posts: 15240 Joined: Wed Jul 20, 2005 12:00 am
Making music: Eagle Alley
Multipattern is ideal, gives me flexibility.
In terms of price range I`m thinking somewhere between akg 414 and the neumann u87.
Going to use the microphones as a part of a recording kit which I will travel with in a pelican case or something similar.
The recording is probably going to be done outside the typical studio environment; outside/inside
Going on DV247 prices, £2k gets you a single U87, £1600 a pair of C414 XLS, £1700 a pair of XLIIs.
If it were me, I'd go for the pair everytime - there are many more uses than just the single. I'd be very tempted to go for the 2x C414 XLS, and something like a pair of the rode NT55s - not quite in the same quality bracket as the 414s, but still bloomin' good mics by anyone's standards. All for the same price as a single U87 - I'd prefer to have 2 stereo pairs (and the options that brings!) any day.
- Stef Andrews
Regular -
Posts: 438 Joined: Wed Jul 04, 2007 12:00 am
Just one microphone? No stereo recordings?
If it were me I'd aspire to a pair of C414 as a flexible travelling rig, but for something less bulky my first choice would be a pair of NT55.
Oops - Stef beat me to it. It seems we are of one mind, mate!
DAYUM! You got a bargain there. Think I payed about £250 for mine, second hand.
- chew_rocket
Regular - Posts: 332 Joined: Wed Oct 21, 2009 12:00 am
Lennart wrote:Multipattern is ideal, gives me flexibility.
In that price range... the world is your oyster!
- chew_rocket
I'd go for a pair of 414 XLSs too. Not boutique-y but solid in all configurations and there's not much you couldn't do with that pair. As Stef says, if you have a pair of NT55s as well, you're covered for 99% of location recording needs and you even have a plan B if some goon runs over one of your 414s just before you put it up in a stereo pair to record. Always nice to have plan B when you're out on location.
Any money left over you can spend on some serious stands so you can put the mikes where they actually need to be. That'll generally make more difference than spending more on the mikes themselves.
chew_rocket wrote:_ Six _ wrote:I recently picked up an AT4033a on The Bay for £100. Everything I point it at sounds great.
...which is nearly five times what I paid for mine second hand
Personally, I'd be going for a pair of 414s... a second hand B-ULS would be circa £400-450 each. They're nice and compact, and the carry cases are small too, all of which makes them nice and portable. The low end is nice and clean on these, and the switchable patterns should come in handy in this sort of setup. The M3 advice is also good if you need battery power.
If you only need cardioid, then maybe consider something like an Microtech Gefell M930 or two. If budget's not so restrictive, maybe also take a look at the UM930
- Matt Houghton
Frequent Poster - Posts: 1603 Joined: Wed Aug 08, 2007 12:00 am
SOS Reviews Editor
Matt Houghton wrote: If you only need cardioid, then maybe consider something like an Microtech Gefell M930 or two. If budget's not so restrictive, maybe also take a look at the UM930
Or if it is - the UMT70S (3-pattern and about one-third cheaper than a U87)
- John Willett
Longtime Poster -
John Willett wrote:Matt Houghton wrote: If you only need cardioid, then maybe consider something like an Microtech Gefell M930 or two. If budget's not so restrictive, maybe also take a look at the UM930
+1. Bilbo says, "Microtech Gefell mics are made by the Elves, you know."
Also consider AT 4050 or Shure KSM44 for multi-patterns, along with many of the other suggestions above.
- sdelsolray
New here - Posts: 4 Joined: Sat Apr 10, 2004 12:00 am
Sturdy, workhorse... surely we must be talking about a couple of 414s here? Especially as you're budget will allow it and the sources you intend to record.
- SleepyHollos
- Posts: 2 Joined: Sat Apr 26, 2003 12:00 am
While working at a pro studio these were my workhorses: AT4040, AT2020 (if really on a tight budget), KSM32, AKG414 although the switches on these are prone to breakage. My all rounder was the AT4040 - most neutral of the ones listed and picked up really close to what you're hearing, maybe just a tad dull. The AT2020 is pretty much the same, I am using that one in my home studio mainly on vocals and percussion and I can't be happier.
- 4TrackMadman
Posts: 1114 Joined: Wed Oct 30, 2002 12:00 am
