EDM Headphones
EDM Headphones
Post by Slash7 »
Hey guys
Which headphone type do you think is better for EDM:
closed back or open back?
Slash7
Posts: 113 Joined: Sat Jun 15, 2013 12:00 am
slash7
Re: EDM Headphones
Post by Bossman »
is this for music production?, mixing?, or just listening?
Bossman
Posts: 698 Joined: Mon Sep 30, 2002 12:00 am Location: UK
www.Lozjackson.com | www.audiowall.co.uk | audioshop.london
Re: EDM Headphones
Post by Slash7 »
for mixing and production
Slash7
slash7
Re: EDM Headphones
Post by Richie Royale »
You will want a flat ranged pair with open backs for monitoring. Budget will be another consideration. Some suggestions to look at would be the AKG K201, the Beyerdynamic DT880 and the Sennheiser HD650.
If you intend to record via microphone, you will want to consider a closed backed pair.
Richie Royale
Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Re: EDM Headphones
Post by Mr.MixAlot »
I'd definitely roll with the open backs so long as you're not using them for tracking live sources. If you're just mixing then you should be golden.
Mr.MixAlot
Posts: 19 Joined: Fri Jun 07, 2013 12:00 am
Re: EDM Headphones
Post by Slash7 »
So just the open backs, and sth that has a wide low frequency range I think...
Got it
THANKS
Slash7
slash7
Re: EDM Headphones
Try to avoid anything that has a hyped response (I'm look at you Dre) as you want something to reveal what is going on in the music not what sounds flattering.
Richie Royale
Re: EDM Headphones
Post by Slash7 »
YEH
THANKS
Slash7
slash7
Re: EDM Headphones
Post by Guest »
I think you just need some "headphones" rather than "headphones for EDM" :)
Guest
