2 x Monitors on i7 Macbook Pro Thunderbolt?
Post by Pitchfork »
Is this possible?
I have a Dell 1908Fpt DVI Monitor (with a Thunderbolt to DVI adaptor) and an older 20" Cinema Display with DVI.
I have the Macbook Pro i7 with just a Thunderbolt socket.
Is there anyway to have both monitors playing and connected as well as the Macbook Pro screen open?
Would I need a Thunderbolt to double DVI sockets?
Pitchfork
Posts: 724 Joined: Wed Jun 25, 2003 12:00 am Location: London
Re: 2 x Monitors on i7 Macbook Pro Thunderbolt?
Post by porthoss78 »
As far as I'm aware the only way to officially get two additional monitors plugged in to your Macbook is to use a thunderbolt display as the first monitor in line, the second then plugs into its thunderbolt port (using the mentioned adapter).
There are ways to extend your desktop onto two monitors though, products like this for instance:
http://www.matrox.com/graphics/en/products/gxm/dh2go/digital... (although I think this may be Windows only).
The problem with using devices like this is that it's always a compromise.
Hope this helps
Cheers
J
porthoss78
Posts: 290 Joined: Thu Dec 20, 2007 12:00 am Location: Bristol
Post by Pitchfork »
Ok, I just have two DVI monitors and the MBP i7 with one Thunderbolt socket.
I just wanted to see if its possible to have two monitors plus the macbook screen open, but it maybe in vain?
Pitchfork
Post by Pitchfork »
Yes this is such a shame.
I just have two monitors that work fine with my MBP both are DVI and my MBP is thunderbolt
So i need somehting that takes 2 x DVI into one Thunderbolt - if it exists..
Pitchfork
Post by Bossman »
Bossman
Posts: 698 Joined: Mon Sep 30, 2002 12:00 am Location: UK
www.Lozjackson.com | www.audiowall.co.uk | audioshop.london
Post by Pitchfork »
Thats perfect, even though i tried every combination of DVi / Thundebolt in google! lol
Anyway thats US so I will try and look for one over here on eBay or similar? :)
Thank you :lol:
I think I have found one (and hope its the same) : But its still USA
http://www.ebay.co.uk/itm/mini-DisplayPort-DP-to-2x-DVI-I-Dual-Link-24-5-Converter-for-iMac-and-MacBook-/121124084265?pt=LH_DefaultDomain_0&hash=item1c338eda29http://www.ebay.co.uk/itm/mini-DisplayPort-DP-to-2x-DVI-I-Du...
Pitchfork
Post by Pitchfork »
Pitchfork
Post by Bossman »
Bossman
Post by chris... »
Be aware this sort of "spanner" device means the OS sees one huge display, which is split down the middle onto two physical screens.
Not quite the same thing as two native displays.
chris...
Posts: 2720 Joined: Wed Mar 12, 2003 12:00 am Location: Sunny Glasgow
