What guitar amp?
What guitar amp?
I am looking for a guitar amp for my studio that is capable of a delivering a wide range of sounds for use by guitarists who may not have 'right' sounding gear suitable for what they are after.
I presume some sort of digital/valve hybrid but I am not really up on these things?
Or should I go for recording the guitar clean and playing around with amp software, not something I am keen on as I much prefer using the DAW as my 'recorder plus outboard' rather than a sound creation tool (hope you get what I mean).
Ta in advance.
Ta in advance.
- GreenManSwaler
Poster - Posts: 59 Joined: Wed Sep 12, 2012 12:00 am
Re: What guitar amp?
What's the budget? And what sort of bands do you work with the most? Can you make unlimited noise? Do you already own a good cab? Are we talking demos for local bands or do you need these sounds to compete at 'any' level?
- Jack Ruston
Budget......depends on how close to my/the ideal we can get.
Bands.....just getting going so can't really tell.
Unlimited noise.......we can certainly turn up without an issue.
Cabs.....not at the mo, part of the next question really!
Any level...........just having built my studio were 'roots' at the mo! But that's no excuse for complacency regarding quality of sound.
- GreenManSwaler
Greenmanswaler wrote:Or should I go for recording the guitar clean and playing around with amp software, not something I am keen on as I much prefer using the DAW as my 'recorder plus outboard' rather than a sound creation tool (hope you get what I mean).
Regardless of what amp you get, you should consider DI'ing and getting something which will allow re-amping. It gives more flexibility and lets you continue to be a 'recorder plus outboard' system.
In terms of a good, flexible amp I would suggest starting with the Blackstar HT range. It allows for quite a variety of tones and there are now output levels to suite all sizes. But equally a valid criticism is that it would not be the same as having a Deluxe and a JTM45 so depending on the level you are working with this might be an issue.
Another option might be to get a good quality clean amp and then get some nice pedals to stick in front of it.
If you do consider software, then take a look at the Scuffham amp software... it's really rather good.
Dave B wrote:Regardless of what amp you get, you should consider DI'ing and getting something which will allow re-amping. It gives more flexibility and lets you continue to be a 'recorder plus outboard' system.
+1
Dave B wrote:Another option might be to get a good quality clean amp and then get some nice pedals to stick in front of it.
This is one of the most used options here, and I've never regretted buying the Roland JC-120 I use for this. I pull in a crusty old Marshall plexi-valve-jobby for when I really need dirt, but the JC-120 wins more often than not. The beauty of the JC-120 is that it lets you hear the pedals doing their thing without adding much colour of its own.
OK, the end game of this scenario is that you will probably have two or three amps covering certain bases, in order to provide people with the sounds they hear on the records they buy. Those bases can't be covered by a single 'versatile' amp, because a big part of each sound is to do with the cabinet (whether a combo or a cab) and the speaker. It's not as simple even as having a cab with a variety of heads for the same reason. Some amps cover quite a lot of ground, and end up being useful across a variety of genres...EG a good Fender Deluxe type amp is good for cleans of all varieties, but it's also good for rock stuff, especially as a second guitar vs something more high gain. An AC30 does quite a similar sort of thing (although AC30's are tricky in the studio because they don't always record very well...depends on the speakers). So, if I were you I'd look for a Fender type combo to start off with. There are some nice ones that Fender do, or if you want to go up in quality a bit there are things like the Lazy J 20 which is basically a very high quality hand-built deluxe. To that you could look to add a decent cab of some sort...say an Orange 412, or perhaps an older Marshall 412, and a high gain head like a Peavey 6505 or whatever that one is that works really well for metal and heavier rock. The gap in the middle is then probably something vox'y but you can do a lot of that sort of stuff with pedals and the Fender. It's different though. There are some awesome Vox type amps which work well in the studio from the likes of Divided By 13 and Audio Kitchen etc.
What I would definitely not do is...use amp sims. You can make noise, so for God's sake differentiate yourself from all the millions who can't. Software doesn't come close to good amp and you should take advantage of that important string in your bow. I would also definitely not buy one amp expecting it to do everything.
I would budget for some pedals, a really good quality splitter (the gig rig one is affordable) and a reamp. Sometimes players just want to use their own amp. If you really don't like it you can run to two amps and blend in a bit of something you prefer (or whatever)
J
J
- Jack Ruston
A third option would be decent modelling FX kit. Reviews of the Pod HD suggest they're pretty close to indistinguishable from the real thing (if anyone has one, please comment - I'm seriously considering getting one and DI-ing). And the SoS review of the Kemper suggests it *is* indistinguishable.
This might not be the perfect option, and it's not as cool. But a Pod is probably something you're likely to keep using, even if it's only to rough out ideas for tone which you can fine-tune later with some boutique FX or PC-based processing.
The best range of tones i've been able to get out of one rig is a J-Station running through an old 60w valve hifi amp into either a small bass cab, a single 8" speaker, or a 4x12 depending on the need.
I have had some funny looks from the small handfull of guitarists that have been through here, but i get some great sounds.
Like the idea of the Jazz Chorus though, always fancied one.
I've also got a small valve combo, a little 10w practice amp with a 6" speaker, a smokey practice amp and some other ones in bits.
I would say that whatever i use i always mic it up, just don't seem to be able to get any air in the sounds when DI'ing.
Get a range, one rig is hard if you're after loads of sounds.
If a guitarist is really fussy they will bring their own amp. Cabs make a lot of difference so some options there will help.
It's one of those 'how long is a piece of string' questions. But it's worth helping you start to unravel it and find the ends.
When it comes to a studio it's all about getting the best value for your budget. You can't always second guess what sounds guitarists (and bassists) are looking for, but it is very easy to make a list of things that guitarists economise on, think they can do without, or just don't need for gigging so would never even think of buying. Amps actually come a long way down the list.
It's no coincidence that someone with as much experience and skill in this area as Jack only mentioned one piece of hardware. A good cab. Give a guitarist a budget of £1000 to buy an amp, and the odds are he'll spend every penny, or more, on a great head and then realise he needs a cab and scrape together a few pennies for the cheapest piece of rubbish he can afford. And he will probably get away with that live but in the studio it will cause no end of problems.
Top of the list. At least one great cab, ideally more. In previous conversations Jack and I have both rated a 70's Orange 4x12 as our 1st choice. But something equally big and heavy (and expensive - at least when new) is a good candidate. And think about alternatives to the 4x12 too. An open back 2x12 is a classic, as is a 4x10 (the old Session 4x10 is a nice bass cab but it works really well as a guitar cab too). Not only will good cabs solve a lot of problems, but you will learn how they sound in your room. And that means you will quickly work out some reliable micing techniques that are repeatable.
Next things guitarists skimp on are batteries and leads. Guitarists will turn up with a row of dodgy stomp boxes with flat batteries, no spares, and the rattiest road worn patch cords. Get some decent guitar cables and patch cords (make them girly neon pink or label them 'stolen from.....') and take care of them, and don't forget some decent speaker cables for the heads/cabs because some guitarists will be using a cheap guitar cable instead as well as their cardboard 4x12. Get one or two power bricks for stomp boxes from the likes of Dunlop/TRex with a range of different voltage ratings and a selection of adaptor cables. Buy a box of 9V batteries for stock and sell them (and you might consider a deal with a local guitar shop to get a few boxes of strings too, you know that plenty of players will turn up with strings old enough to be served in a pub).
Dave's point about DI is important too. Re-Amping gives you a lot of options for mixing, but it also expands your client base too. Clients can record at home, monitor through a modelling amp and headphones while recording a DI, and then you can re-amp that DI in the studio. So as well as good DI boxes suitable for guitars, I would look at dedicated re-amping tools from the likes of Radial. And I would also look at splitters so you can drive more than one amp at a time, or DI boxes that off that facility.
Next up are stands. Not just enough mic stands to mic 3 or 4 cabs with multiple mics at various distances, but amp stands. Whether it's a heavy duty amp stand or a solid riser, you need to ensure those guitarists have their combos pointed at their ears, despite our best efforts we guitarists have repeatedly failed to evolve ears in the backs of our knees.
And finally, we can get to amps
Guitarists who are very fussy about their sound will have already sorted out quality amps and FX. They will bring their own and what you need to do is practice your people skills and get to know them. These people spend a fortune on gear and have a lot more at home. Encourage them to bring in a selection of their amps. Notionally this is so you can experiment with different options once you've got the main tracks down. But the real reason is to find out exactly what amps they have and how they sound/record in your room, so after a few months you will have a list of really nice amps that you might be able to borrow for a recording/re-amping session. Or maybe hire, or do a deal on some studio work. And as these players tend to tinker constantly with their rigs they often sell old gear to fund new purchases, so you get a chance to pick up good second hand amps that you know well and record well in your room.
Next up are guys who aren't too fussy, they just like to plug in and play. If their gear is better than yours, they will use their gear. If your gear is better they will use yours.
Finally you get guitarists who just can't afford decent gear. And what they generally need are good amps that deliver the basic/classic sounds without any fuss. Easy to understand controls so someone used to a cheap amp can leap in and dial up a sound they like. And for those I would look at a second hand Marshall DSL50 head (remember, you will already have bought a nice selection of cabs) and a second hand Fender DeVille 2x12 combo. That covers vintage and 80's Marshall and clean and dirty Fender.
A line 6 POD (or equivalent) would be handy. The rackmount versions have excellent connectivity and can be really handy for sketching out parts for re-amping later while monitoring on the modelled sounds.
Further down the line, baby boutique amps might be useful. And something like the Kemper modelling amp if you really want to push the boat out. That would enable you to make maximum use of the amp collections of your regular tone hounds
Remember, your job is to provide things that guitarist wouldn't otherwise use, the things they should use but don't consider, the things that they don't maintain, and the things that they skimp on.
Andy
Andy
LOL... you can see how long it took me to write this, by the number of other replies since Dave B's !!
Andy
Andy
WOW........a lot to digest....and it's not yet tea time.
To touch on odd points, yes I intend to split the signal so as to enable reamping.
A pod is already kicking around as is an original hand wired Sansamp pedal, which I really get on with.
Having a selection of heads and cabs makes sense......lots of combinations to try.
I totally agree about not using plug in amp sims as well.
I will go away and ruminate on the replies....cheers.
- GreenManSwaler
Re the PSU's...I've had a lot of problems in the studio with those things...even expensive isolated TRex Fuel tanks etc. I've found that batteries seem to be better for most pedals and if you can I'd just get a big box (take them out of clients pedals when they leave!). I'm not sure what the issue is, and it's not one of those 'batteries sound better' type things...it's noise.
J
J
- Jack Ruston
Nice link Goddard!
Nowhere near as informative as Andy's 'War and Peace' post, but then we wouldn't expect that would we?
Martin Walker wrote:Nice link Goddard!
Now, if we can just get Count Arthur Strong for the Talking Book version...
Andy
Quite agree about going for batteries instead of PSUs where complex hook ups might be the case.
CPC e.g do a box of 10 Duracells for 20quid and 12 bog S alkalines for 15 (+VAT) and if you are buying in the latter especially, bit mean grabbing them back?
Speakers? +1. There might be said to be two "standards"? The Celestion Vintage 30 (rated at 60W!). Hard rock sound most folks say, punchy mid range but plenty of bottom urge. Celestion Greenback. Various marks and power levels 20-30W. A smoother, less inyerface sound well suited to jazz. The 55Hz version has a bit of extra "reach". A pair of 2x12 cabs so loaded will cover almost any style.
Amps? Well I musn't must I?!!
Oh go on then........
Pleeeeeze
- GreenManSwaler
Just a thought leading on from one of the replies......what do people think about pedal, then valve pre, then clean amp, then cab?
- GreenManSwaler
Pleeeeeze
Ok, well check my profile then the website and pick something to talk about!
BTW. How do I edit my profile please? I am no longer retired you see.
- Richie Royale
Frequent Poster - Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Wait, wait, I've an amp article by Tolstoy bookmarked someplace!
(had read that Verheyen article in the actual mag a while back, so had to employ my Hugh-like web searching prowess to track down the online version)
An Egnater Tweaker might well serve for studio recording amp duties.
I really can't be the only person on the planet to have one of these....
Hughes and Kettner Tubemeister 18 head!!
Excellent reviews in SOS, XLR line out (Red Box) (bet you thought that was a medical condition) power switching from 18 watts down to 5,1 and 0. FX loop
Retail about £400
What's not to like?
Retail about £400
What's not to like?
Mac Studio Ultra M2
64GB.
64GB.
Goddard wrote:An Egnater Tweaker might well serve for studio recording amp duties.
Just had a read about one of those. Sounds very suitable.
As does the h&k.......
- GreenManSwaler
