I'm always biased against people who are asking for my money who can't/won't use proofreaders, so maybe I'm being unfairly cynical. Can someone who actually knows this stuff please tell me what they think about this?
Thanks!
http://kaoticaeyeball.com
The Eyeball is an acoustic treatment device designed to channel sound directly to a microphone, capturing every tone and frequency emitted by your voice. This allows the artist to hear their pure vocal tone for the first time and produce a professional level recording every time. The Eyeball minimizes the need for sound re-enforcement (sic) while also complimenting (sic) any acoustically treated space.
Control Your Sound
Specifically engineered to channel the sound of your voice without any coloration, ensuring that your pure vocal tone is captured
Take the Eyeball Anywhere
Be inspired to record anywhere; the Eyeball is small, durable and practically weightless
Integrated Pop-Filter
Our premium blue pop-filter reduces plosive consonants and sibilance without affecting the overall recording quality
Reduce Ambience and Reflection
The Eyeball eliminates the external environment. So no matter where you are, your tracks will always sound as if they were recorded in the same place
The Eyeball channels sound directly into your microphone. This means that all of the low and high frequency information contained within your voice can now be captured, allowing you to truly hear yourself for the first time. The Eyeball accurately portrays every aspect of your voice, without adding any colouration, producing a vocal track that is clear and defined every time. The design prevents your microphone from capturing ambient noise and room tone, while reducing any potential phase cancellations.
The Eyeball reduces the need for sound re-enforcement in your home studio space, while perfectly complementing any acoustically treated environment. It is practically weightless, small and durable allowing you to take it anywhere, meaning your tracks will always sound like they were recorded in the same place.
Based upon the volume levels indicated by the RMS and DBSPL readings, sound is louder inside of the Eyeball. The louder volume level has many distinct advantages. First, it will increase the Signal to Noise Ratio (S:N Ratio) of your recorded track.
The Eyeball is not actually amplifying the sound. The reason for these amplitude increases is because sound is not being allowed to disperse through air, but is being channelled directly into your microphone.
Re: the graph - wouldn't this property of "maintaining the sound longer" mean it's adding some kind of reverb quality to the signal?
Within the Eyeball we see a smoother, slower, and more linear decay pattern, while the envelope of the sound without the Eyeball decays much quicker. This shows us how quickly sound is dispersed through air, and how much longer the sound is maintained inside of The Eyeball.
Technical specs:
Frequency response: 0Hz - 30KHz +/-1.4dB
THD: 6.789%
Max Peak: 140dB
TL: 3.73dB (average)
Polar Patterns: Cardioid is recommended, but all types of polar patterns can be used with the Eyeball
Maybe Hugh can review this in SOS!
