I have a cheapie Toshiba satellite with 4gigs ram and a half a terabyte running Windows 8 64 bit and Sonar X2 64 bit. I am recording me and two friends' three piece band. I currently am using all of the soundcards I have ever bought simultaneously. They are one edirol pcr 1 (very old) and two alesis multimix 4 usbs. This gives me 6 tracks I can record at once.
The way I have been recording is to use each soundcards left and right inputs to record to a single track. The tracks are as follows, Drums, Bass Drum, Bass Guitar, Electric Guitar, Vocal Mic 1, and Vocal Mic 2. We only do live recordings and afterwards there is enought isolation in the tracks that I am able to effectively adjust each tracks level in comparison to the others. There is still plenty of bleed through on many of the channels with only the bass being recorded directly. Everything else is recorded with microphones. Vocal mics run to one alesis multimix and then to the pa. The bass guitar runs direct into the hi impedance input on alesis multimix #2 and to the pa.
I am using wdm drivers with the settings shown below. After making some recordings last night, I have noticed a popping sound everywhere except for during the silents bits between songs. When I export the audio, the popping sound is gone.
Does anyone know why I cannot listen to the audio in sonar without getting this popping sound?
I think when I record next, I will set the buffer size as large as possible as I am not concerned with latency-- at least I don't think I should be because I am not recording to a previously recorded track. I don't know if that would take the popping sound away since when I listen in Sonar since the exported audio has no popping.
Can anyone help me out with this popping noise, I want to be able to edit without hearing it. Also any other suggestions on how to make my setup better? All the tracks are recorded at proper levels, meter barely hits yellow with no red led light ever clipping. Also I am not using any of the mixers hi or low pass filters so that I can eq it in post production.
That is a lot of info, if anyone is brave enough to read all of this, I would really appreciate your input on how to make any aspect of my recordings better. Here's a snapshot of audio preferences in Sonar.
