RME Fireface 400 to thunderbolt problem.
Post by 20flight »
I have a problem!
I have just invested in a brand new iMac to use with my RME fireface 400. I have previously been using it with an old MacBook that has been coping very well considering! The connection on the MacBook was/is FireWire 400 to 400. The new iMacs have decided not to have a FireWire port at all so I have had to buy a FireWire 400 to 800 lead then an apple converter to make it thunderbolt. When I first plugged it in it wasn't working at all. After some research I found that I had to power the RME independently via a power supply. This seemed to fix the problem and I am now hearing sound through my speakers again. The problem I have now is every so often the music is interrupted by a loud beeping noise. A bit like white noise but more solid and urgent sounding. I have changed the power supply and re installed the drivers for the fireface. I'm at loss as to why it's not working and would welcome any thoughts anyone may have.
I have included an mp3 link of the sound that is made below.
My worry is that the FireWire to thunderbolt chain is just not efficient enough and will never work.
My new imac is 2.7GHz quad-core, 16gb ram and 1TB fusion drive. It is vastly superior to my old MacBook (white version) and everything worked fine with the old set up.
https://soundcloud.com/twenty-flight/mac-beep
Any help would be most welcome.
20flight
Posts: 12 Joined: Wed Nov 06, 2013 12:00 am
Re: RME Fireface 400 to thunderbolt problem.
Post by Richie Royale »
I presume where you say you have re-installed the drivers, that you have the latest ones from the net and not ones supplied with your FF?
Thunderbolt is much more powerful than FW and there are other users who have FW devices running via TB into newer Macs without trouble. Have you tried a different FW cable? Otherwise, I can't think why it wouldn't be working. What OS does your new iMac have?
Richie Royale
Posts: 4551 Joined: Tue Sep 12, 2006 12:00 am Location: Bristol, England.
Post by Exalted Wombat »
Your sample doesn't sound like a digital connection breaking up. More like a system sound, or even a demo version of a plugin reminding you it IS only a demo!
Apple's design philosophy seems to be to make the basic computer as elegantly minimal as possible, but then require a mess of adapter cables when you want to actually CONNECT anything. Compare certain over-styled audio interfaces which are too compact to mount a standard jack, let alone a microphone connecter.
But enough of Why I Don't Like Apple :-) If this doesn't sort out, you'll get expert advice at the RME forum:
http://www.rme-audio.de/forum/
Exalted Wombat
Posts: 5846 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Post by 20flight »
Richie Royale wrote:I presume where you say you have re-installed the drivers, that you have the latest ones from the net and not ones supplied with your FF?
I have downloaded the new updated driver from the rme wewbsite. I've even changed the thunderbolt connector and its still making the same noise. I'm on the new Mavericks osx but i was running that on my old macbook too, without any problems.
I'll keep searching!!
20flight
Post by 20flight »
Exalted Wombat wrote:Your sample doesn't sound like a digital connection breaking up. More like a system sound, or even a demo version of a plugin reminding you it IS only a demo!
It makes that sound through iTunes, spottily, garageband, logic. and web based music. Can't think of any explanation apart from the signal chain is too long and apple haven't considered that people would want too use firewire still!! Very annoying.
I'll try RME, thanks
20flight
Have you checked whether the noise still appears with the RME disconnected?
Richie Royale
20flight wrote: It makes that sound through iTunes, spottily, garageband, logic. and web based music.
Check one thing. Take the RME away and listen through the computer's internal speakers. Has the sound gone away?
If not, what's running in the background? Mail, a messaging service, Skype? Could it even be your hard drive warning of a S.M.A.R.T. error? Not unknown on brand new equipment.
Exalted Wombat
Post by 20flight »
Richie Royale wrote:Have you checked whether the noise still appears with the RME disconnected?
The noise doesn't seem to happen when the RME is disconnected. Unfortunately.
20flight
Post by 20flight »
It doesn't beep when not connected to the rme and when it is connected i can just have iTunes open and nothing else and it will still have the same problem.
20flight
Post by 20flight »
Thanks for your replies tho guys. I think I'm snookered on this. I think I'll have to return the mac and buy one with a FireWire port in.
20flight
Post by John Willett »
Have you fully discussed this direct with RME?
It could very well be a bug they need to fix - and if they don't know about it they can't fix it.
John Willett
Post by mjfe2 »
John Willett wrote:Have you fully discussed this direct with RME?
I agree. RME are very good at replying to personal emails, as well as providing forum support.
mjfe2
Posts: 632 Joined: Sun Oct 11, 2009 12:00 am Location: UK
Eastwood Records
20flight wrote:Thanks for your replies tho guys. I think I'm snookered on this. I think I'll have to return the mac and buy one with a FireWire port in.
You're certainly not snookered until you've contacted RME. Their people respond very quickly to this sort of thing on the forum I mentioned a few posts ago.
Exalted Wombat
Post by 20flight »
HI guys,
I have spoken to RME thanks, and there were very quick to respond. The chap thought that all new iMac seem to have a problem with the thunderbolt to firewire converter and theres nothing we can do! I'm a little devastated to be honest but it just means the iMac has to go back.
I appreciate everyones input though. Sadly on this occasion i may be thwarted.
20flight
20flight wrote:I have spoken to RME thanks, and there were very quick to respond. The chap thought that all new iMac seem to have a problem with the thunderbolt to firewire converter and theres nothing we can do! I'm a little devastated to be honest but it just means the iMac has to go back.
Blimey! I know Apple like to lead, we are meant to follow, but have they really just made all Firewire audio interfaces obsolete?
Exalted Wombat
Exalted Wombat wrote: Blimey! I know Apple like to lead, we are meant to follow, but have they really just made all Firewire audio interfaces obsolete?
No.
http://global.focusrite.com/answerbase/will-the-apple-thunderbolt-to-firewire-adapter-work-with-my-firewire-saffire-interface
The testing confirmed that there are no problems using one of these adaptors to connect your Saffire and that the hardware and software works in exactly the way it should.
http://www.presonus.com/news/press_releases/PreSonus-FireWire-Interfaces-Compatible-with-Apple-Thunderbolt-Adapter
PreSonus has confirmed that its FireWire interfaces, including the StudioLive-series mixers, are fully compatible with Apple’s Thunderbolt to FireWire 800 adapter (Apple part number MD464). Interface users can expect performance to at least equal, if not exceed, the performance with a regular FireWire 800 port.
http://www.soundonsound.com/forum/showf ... er=1015237
The MOTU Traveler, both the original and the Mk 3, work very well on my Macbook Air using the FW-Thunderbolt adapter.
We're using MacBookAirs with Thunderbolt-to-Firewire adapters and have had zero problems running an ancient Edirol FA66 FW interface and various MOTO FW interfaces. Very impressed.
I use a MOTU Ultralite. It's connected to my MBP via a firewire 400 to 800 cable, plugged into the Apple thunderbolt to firewire adaptor.
Thunderbolt has been on Macs since 2011 too.
Richie Royale
No.
Good! But the quotes you found seem to be from a year ago. Macs have had a new os since then, and hasn't there also been new hardware very recently? If the iMac in question HAD a Firewire port, this thread wouldn't exist.
If this IS about very recent hardware, running a very new os, there's a chance Apple will sort it out. But if we're thinking of "returning within 7 days of purchase" waiting is risky. Tough call. I suppose Apple can hardly argue about incompatibility with FW being "unfit for purpose"?
I don't see a flood of complaints on the RME forum. But if an official RME source said there are problems...
Exalted Wombat
I saw two others with issues on the RME forum. It seems to be a Mavericks specific issue.
There are other things that are working though, including Focusrite FW interfaces.
http://www.dawsons.co.uk/blog/osx-10-9-mavericks-compatibility
Richie Royale
I'd love to know just who he talked to at RME and exactly what was said. If RME were aware of an issue, it's uncharacteristic for them not to announce it openly (though they remain in denial over the quality of some of their connecters and breakout cables :-)
Exalted Wombat
Post by Matthew Ottewill »
You've probably already checked this but is you device setup correctly with the OSX Audio MIDI utility?
The beep sounds like a system alert telling you there is a conflict in a setting. It might be worth trashing the preference file and configuring the utility again.
Matthew Ottewill
Posts: 20 Joined: Mon May 14, 2007 12:00 am Location: London
Post by 20flight »
I can't remember what the mans name was from rme but I emailed them and they rang me back that morning. He 'thinks' there is a problem specifically with new iMacs. Not any other macs, Mac Pro MacBook Pro etc. and only new ones (late 2013) It's not the thunderbolt connecter specifically. It's the communication between that and the mac.
As for mavericks, my 2009 MacBook (white one) is running the new osx and it all works perfectly. I can't speak for other FireWire devices as I have only tried the fireface with the new iMac. Apple still haven't gig back to me after passing all the details if their 'technical team' but if they do I will update the post. They did admit that some people have been having problems with the new fusion drive tho. Dropping sounds ams making click sounds. But not like the beep I've experienced. The pro apps team I spoke to hadn't heard of this problem before.
20flight
Post by 20flight »
Matthew Ottewill wrote:You've probably already checked this but is you device setup correctly with the OSX Audio MIDI utility?
Whilst talking to the pro apps team from apple I completely reset everything and re installed the drivers etc. The beep then happened within 10 seconds!! Very frustrating.
20flight
Post by 20flight »
I'm starting to think they don't really care that much and just expect everyone, including the Audio companies to upgrade their systems to thunderbolt. The first apple guy I spoke to was trying to tell me how much faster thunderbolt was. Even after I'd explained how it wasn't actually working and the speed was therefore irrelevant.
20flight
Post by 20flight »
It seems both sides are blaming each other. Apple have said its a third party issue and RME have said its the new iMacs. I therefore have no choice but to return the Mac. Very disappointed with this outcome.
20flight
Post by G-Doubleyou »
I've seen several posts at different forums, about issues with new macs with the Fusion Drive.
The fusion drive uses firmware to determine "Frequently Used Files", and stores them in flash memory for quick recall.
At this point nobody KNOWS the time period needed for a file to become "Frequently Used".
There is also speculation that the rotational speed of the the hard drive portion is 5400rpm, yet to be confirmed.
In my opinion the Fusion Drive, is only suitable as a System drive.
It also may not be suitable for DAWS.
It's firmware, you can't cut it off, it will always be looking at the files on the hard drive.
Not suitable for recording to itself.
Open an existing project, some audio files are on the flash part, some on the hard disk.
How does that work?
What happens when a file becomes "Frequenly Used" when your project is open?
Here's a thread about the issues on Gearslutz.
http://www.gearslutz.com/board/music-computers/877537-potential-audio-problem-new-imacs.html
:lol:
G-Doubleyou
Posts: 972 Joined: Fri Feb 10, 2006 12:00 am
2.3 GHz quad-core i7 Mini
