Upgrading Nearfield monitors
Hi everyone,
Faced with trying to get a good orchestral sound from samples, I think my current monitoring setup is not helping. I use Dynaudio BM5 (mk1 version) driven by a Malcolm Hill Chameleon Class A amp; the sound is OK but there's not enough detail or stereo imaging. I've just ordered some Studiospares acoustic panels to put between the speakers, and the room is quite large (5m x6m x 4m high), carpeted and dead sounding, perhaps too much so.
I also have a pair of PMC FB1+ driven by a monster boutique HiFi amp called LSA which sounds more accurate though it's a HiFi system rather than studio monitoring.
What I'm really asking is, how much do I need to spend on nearfields to hear a worthwhile difference? I notice that nowadays most monitors you read about are active, but I'm not convinced that the amp, which cost way more than the speakers in its day, is a problem - are there still good passive designs about? Otherwise the KH310As look ideal, but rather beyond my budget. I'd prefer to be looking at around the £1K level. Would something like Adam F7 be a worthwhile improvement?
By the way, before you tell me to audition lots of speakers, bear in mind that in this internet age there aren't any shops you can go and listen to this kind of stuff any more, they've all closed!
Thanks in advance for any suggestions
Vyv Cubase 11 Win10 Pro 64bit ASUS Z97 Intel Core i7 16Gb Audient id22 Focal SM9
Re: Upgrading Nearfield monitors
The PMC FB1s are basically just a floor-standing version of the TB2 (with a slightly longer ATL), and there is negligible difference tonally between the two models. So although they are wood veneered and sold into the hi-fi market, they are perfectly appropriate to use as monitors if that is practical in your situation.
I'm not familiar with the Chameleon amp, but if you want to hang on to that and you like what the PMCs do, then the obvious solution would be to pick up a second-hand pair of passive TB2s. There are some on ebay now for £600 -- although I can't vouch for their condition or the seller's veracity -- and similar items come up quite often.
Posts: 43684 Joined: Fri Jul 25, 2003 12:00 am
Thanks for this, I hadn't realised the equivalence between the two PMC models, it also helps show what territory I'm in budget wise (1-1.5K for equivalent quality to the FB1s). But perhaps I didn't make clear these two systems are at opposite ends of the same room, so I don't really want to double up. I actually quite like the warmth of the Dynaudios but I think they tend to "invent" bass that isn't really there; I need something a bit more analytical.
Do you really need two systems? Why not use your PMC's for monitoring? In days gone by hifi speakers often found their way into studios while small studio monitors found their way into hifi systems.
Posts: 16984 Joined: Mon Sep 10, 2001 12:00 am
Definitely need one system aimed at a sofa for - er - leisure listening to CDs etc and a work system for staring at a computer screen and tearing my hair out. The PMCs are effectively my full range monitors.
Just looked at the SOS review for ATC SCM25 A's. 7 grand. Ouch. But there's a pair of passive SCM10's on ebay ...
Are you listening in a treated room?
Controlling reflections, and the low end can improve clarity.
- G-Doubleyou
Posts: 972 Joined: Fri Feb 10, 2006 12:00 am
2.3 GHz quad-core i7 Mini
No, the room isn't treated, as I said in the OP I'm getting some acoustic panels to go between the speakers and may get some more if this improves things. It's a large carpeted and curtained room with lots of shelves and stuff to break up reflections, If anything I find it a bit too dead sounding.
There are good-sounding rooms, nasty-sounded rooms ... and there are "treated" rooms. They sometimes can be very strange to work in
- Exalted Wombat
Longtime Poster - Posts: 5846 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Vyv wrote: By the way, before you tell me to audition lots of speakers, bear in mind that in this internet age there aren't any shops you can go and listen to this kind of stuff any more, they've all closed!
There are still a few good shops in the UK (eg: KMR, Funky-Junk, studioXchange, etc...) and the good manufacturers will have demonstration units to loan out.
I am taking a pair of the Geithain RL901K up north for a home demo shortly and the RL906 are going somewhere else.
I know PMC certainly have loan/demo units to do this as I borrowed a pair several years back.
ATC I think do the same and I am pretty sure Sennheiser UK have demo sets of the Neumann KH120A and KH310A.
PS - it's good if you can add your location to the left-hand panel - it helps us all help you better knowing in which Country and Region you are.
- John Willett
Longtime Poster -
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am
Location supplied, cheers.
Vyv wrote:Location supplied, cheers.
OK - so you are UK based.
As Hugh said - your existing PMCs should be fine and I would say probably better than the Adams.
But if you want to buy active monitors then the best around the £1k mark are probably the Neumann KH120A. The RL906 I mentioned before are around the £2k mark.
If you want PMC actives and keep your existing units for the living room, they are also worth considering.
But, as I said, KMR have a good monitor range on demo and so do Funky Junk and many of the top manufacturers/distributors may be able to arrange a home demo.
- John Willett
Longtime Poster -
Thanks for the info, John. I will get in touch with these dealers.
Vyv wrote:Just looked at the SOS review for ATC SCM25 A's. 7 grand. Ouch. But there's a pair of passive SCM10's on ebay ...
I'm still using my SCM10's bought in 1997 and am very pleased with them
They are built to last
Re: Upgrading Nearfield monitors (SOLVED)
Just in case this is of interest to anyone, I ended up blowing my budget entirely and getting a pair of Focal SM9's. Thanks to Stefan and the team at KMR for letting me borrow a pair after I'd checked out a few alternatives at their showroom. I also spent a few quid on acoustic foam tiles from http://www.acoustic-foam.co.uk/ which were a lot cheaper than the Auralex equivalent.
Result: amazing increase in detail resolution, stereo image solidity etc. The bass goes all the way down, and the treble is sweet and unfatiguing thanks (I'm told) to the Beryllium tweeter. Some people have criticized the SM9 for being a bit flattering, I suppose it depends on your ears. I've always found hihats and brass tiring to listen to, even live, so the SM9 sweetness is a definite advantage to me.
Sound is not unlike the much cheaper Focal Solo 6 but with a lot more welly. I also tried the Neumann KH310 and KH120: the 310 had a slight bloom to the lower mid which I found distracting, but very open bass. I almost prefered the much smaller KH120, but found it hard to justify spending all that money on boxes slightly smaller than my existing setup.
I can vouch for making acoustic screens at a fraction of the cost of the foam equivalent. If you need more treatment I'd check out some of the demos on here. Made a heap of difference to my humble setup and my crappy-sounding room! Enjoy your new speakers.
- maskedwarrior
Regular - Posts: 140 Joined: Sun Feb 19, 2006 12:00 am
[Type your personal signature here]
Vyv wrote:Thanks for the info, John. I will get in touch with these dealers.
There is now a new dealer opening in London - with an excellent pedigree and highly recommended:-
The Studio Shop
Certainly the equal of KMR and Funky-Junk and should also be seriously considered.
- John Willett
Longtime Poster -
