Microphone for recording at homestudio
Post by Iggor »
Hi, i have a homestudio without acoustic insulation. i will buy a microphone to record vocals and acoustic guitar too. i have tried to record with condenser microphone, and the record takes pick up the noise ambience too much , so i thinking to buy a dynamic microphone. what is your opinion ? some model to recommend ? thanks.
Iggor
Posts: 31 Joined: Sat Mar 17, 2012 12:00 am Location: Brazil
iMac 21, Logic X, Apogee Duet USB, Neve Portico, Alesis MKii
Re: Microphone for recording at homestudio
Post by Ben Asaro »
You should keep your microphone and do something about the room! There's a simple trick you can do with a couple of boom stands and a couple of blankets or quilts: form the microphone stand into a "T" and hang the blanket over it, and adjust the height so it's covering a good portion of the bare walls ... or you can place a couple of these around the performer and your mic; this will keep at least SOME of the room noise from getting into your mic and will clean up your recordings considerably.
Ben Asaro
Posts: 3483 Joined: Thu Feb 26, 2009 12:00 am Location: NYC
Post by molecular »
TwilightOdyssey wrote:You should keep your microphone and do something about the room!
+10
molecular
Posts: 1318 Joined: Sat Dec 13, 2003 12:00 am Location: Skye / Stroud / Seyðisfjorður
Anto mo Ninja, Watashi mo Ninja http://www.hectormacinnes.com
Post by ConcertinaChap »
molecular wrote:+10
Likewise. A dynamic mic won't solve your problem, but you would really be surprised how much change you make in a room just by hanging quilts around the place. Doesn't look very professional but who cares if the sound is better.
ConcertinaChap
Posts: 15234 Joined: Wed Jul 20, 2005 12:00 am Location: Bradford on Avon
Making music: Eagle Alley
Post by GlynB »
Or... along the same lines, create a temporary and dismantleable 'vocal booth' to keep the background noise out. Improvise! A large cupboard or wardrobe put the mic in it (with the doors open!), drape some blankets round... etc. use a mic with a bass reduction switch to keep out the low frequencies from passing lorries and cars etc.
GlynB
Posts: 334 Joined: Fri Sep 26, 2003 12:00 am Location: Lancashire, UK.
Post by paradigm203 »
Having the same problem with my room setup. I probably need some foam to cure it
paradigm203
Posts: 1 Joined: Fri Dec 20, 2013 12:00 am
Post by TheReson8or »
The duvet is king...or queen depending on the size!! :D
TheReson8or
Posts: 1569 Joined: Fri Apr 25, 2008 12:00 am Location: derbyshire uk
My head hurts!
Post by Guest »
Regarding room design, there's still something to be said for well-tiled bath. If you have a limited budget and a small equipment footprint - and don't expect anyone to start banging on the door with a nature emergency - you might try plugging faucet leak and setting up in the tub.
Guest
Post by Mixedup »
It's a myth that dynamic mics are inherently better at rejecting room sound. The only real difference is that a lot of people tend to perform closer to the mic, meaning the wanted to unwanted sound ratio is higher.
In other words, your mic is not the main problem. Put a polyester duvet behind the singer/performer. Also, put foam around the mic (eg. portable vocal booth, Kaotica Eyeball, SE Reflexion Filter etc). That should get you half way there if you're really not going to go all out for treatment (which, to be fair, can be a pain in the **** in rented accommodation). But it will still sound rubbish over your speakers if the room is untreated - so you need at least to get the mirror points sorted, or to listen on decent headphones.
Mixedup
