wireless in ear monitors - any reason this is not possible?
Post by LimitedHeadroom »
I would like to put many (up to 40!) sets of wireless headphones receiving the same signal. Is there any reason this can't be done using one transmitter and all the receivers set to the same channel. There is a budget issue with this so I was thinking of using this as it is the cheapest option I can find.
Thanks
LimitedHeadroom
Posts: 64 Joined: Sun Sep 07, 2003 12:00 am
Re: wireless in ear monitors - any reason this is not possible?
Post by Sam York »
Low power FM using an iTrip or similar?
Sam York
Posts: 119 Joined: Fri Aug 25, 2006 12:00 am
Post by Parker Fly »
LimitedHeadroom wrote:I would like to put many (up to 40!) sets of wireless headphones receiving the same signal. Is there any reason this can't be done using one transmitter and all the receivers set to the same channel.
Nope, none at all, and that's exactly how most West End set-ups work. The leads will have their own channel, to give them "more me", which the rest will have a summed mix.
The largest set-up I've used myself in this manner probably had 12 receivers, and there were 2 stage transmitters for better coverage.
Parker Fly
Posts: 296 Joined: Sun Feb 24, 2008 12:00 am
Post by dmills »
IIRC 854Mhz is outside the license exempt band in the UK, so you would need to talk to JFMG about licensing some spectrum.
Regards, Dan.
dmills
Posts: 1533 Joined: Fri Aug 25, 2006 12:00 am Location: High Wycombe, UK
Audiophiles use phono leads because they are unbalanced people!
Post by John Willett »
Yes, it's all possible.
However, the item you linked to is illegal in the UK (or only legal on a site specific co-ordinated licence from JFMG).
But - THIS is the same thing on a UK de-regulated frequency that you can use anywhere in Europe licence-free.
To be licence-free and legal you need to be between 863 and 865 MHz.
BUT! - You will notice that it's reception range is only 10m (as opposed to 100m for the Sennheiser ew 300 IEM G2 system) and I can't see any mention of a matching transmitter for it. :headbang:
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Thanks for all your help. The reason we want to do this is for a show (still only in the development stages so not definite yet). But as it is not your regular show the only way fr the audience to experience it is through headphones, but we want them to be able to move around freely as it is not taking place in an auditorium.
The itrip idea would be another possibility that I hadn't thought of, we could just supply audience members with standard radios!
LimitedHeadroom
LimitedHeadroom wrote:The itrip idea would be another possibility that I hadn't thought of, we could just supply audience members with standard radios!
Illegal I think.
The little transmitters on the broadcast band have a minuscule range and are designed only to transmit from your iPod to a car radio in a sealed metal box that won't disturb other users.
Using it as you describe is illegal and most users will be too far away from the transmitter to receive anything.
John Willett
You could use something like THIS with lots of extra headphones.
One transmitter and many headphones.
John Willett
Or you could hire an infra-red system.
John Willett
Thanks John,
that sennheiser thing looks perfect! Really reasonably priced as well, although strangely the headphones on their own without the transmitter cost more that the whole system together by £10 (at least on Amazon, not looked around yet)
LimitedHeadroom
LimitedHeadroom wrote:that sennheiser thing looks perfect! Really reasonably priced as well, although strangely the headphones on their own without the transmitter cost more that the whole system together by £10 (at least on Amazon, not looked around yet)
The headphones are about half the price of the set - but - you are likely to get discount off the set because loads are sold, but not off the headphones as they would probably be special order.
Try contacting Sennheiser sales direct, you may get a special price as it's for trade industrial use.
John Willett
Post by chris... »
Illegal I think.
As I understand it, these things were legalised in the UK (for in car use) a year or so ago.
http://www.ofcom.org.uk/media/mofaq/rcomms/itrip/
Seems like a backwards step to me - why should the airwaves be needlessly polluted, at a time when car stereos with a line-in or pod-dock etc are becoming increasingly ubiquitous.
As you say, the range will probably be insufficient for the OP's application.
chris...
Posts: 2720 Joined: Wed Mar 12, 2003 12:00 am Location: Sunny Glasgow
Chris Edwards wrote:
Illegal I think.
Exactly as I said.
For car use, where the transmission range is a metre at most - and - it's all in a metal "Faraday cage" box it's OK. It's also OK to enable you to play your iPod through a home radio, where you are far away from anyone else.
Not for other uses - where it would not work anyway due the the increased transmission range.
John Willett
