To all fellow guitar enthusiasts,
I like everything about Guitar Rig. I have to ask, because I've checked many times, is it possible for it to be multi out? I do this with Spectrasonics Omnisphere to save on cpu. I understand I can route different tracks to the single instance of guitar rig and overdub different parts, but the same patch is applied to them.
tl;dr: Can different patches from guitar rig be applied to different tracks whilst only using one instance? If there is anything similar, a program, or set of actions I must do to achieve what I am asking, please do share.
Thankee
- The Ark.
Guitar Rig Multiple Instances
Re: Guitar Rig Multiple Instances
Nope, it's a serial plugin, so you need one new instance for every non-summing signal you want affected.
Use as a send or group to affect multiple signals together with one summed output.
Use as an insert on every channel you want to keep separated.
Composer;
http://www.ogonline.org
Well yes, Oggy is right that generally Guitar Rig is used as a single-channel "insert" plug in... when being used as a guitar amp sim plug-in, certainly.
To expand a little on what he has said: if you are using one of GR's reverb or delay effects, you can also use it as a Send/Return effect. I sometimes do this for the Space Echo emulation on it.
To do this, you put GR on its own channel, insert your reverb/delay, and route any tracks in any quantities you like, to that channel.
The other thing is that you could stick GR on a guitar track, then "freeze" the track, with the effect on, and move the plug in to the next track. I would only do this if I was short of CPU though.
- Richard Graham
Posts: 1800 Joined: Mon Apr 10, 2006 12:00 am
"If a nail is bent, stop hitting it."
Richard Graham wrote:if you are using one of GR's reverb or delay effects, you can also use it as a Send/Return effect. I sometimes do this for the Space Echo emulation on it.
Very true, so do I actually(!), but what I meant was it can only run the effects inside it on one signal, however many channels contributed to that signal.
Composer;
Caveat first!!!.... I havn't tried this but...
Guitar Rig accepts a stereo input, so with careful use of the splitter component, you might be able to construct a dual mono rig where L is one rig and R is another. It'd all be one patch, but you might be able to get two different chains set up in one instance. Then send the L and R to their own mono tracks.
I will have a play tonight!
- Moroccomoose
Frequent Poster - Posts: 568 Joined: Tue Apr 12, 2011 12:00 am Location: Leicester
Yip, that works, provided your DAW lets route to a particular channel of the track with the source.
In my case; in reaper, no problem, in my aged copy of Cubase 4 AI - not possible, a mono track can only be routed to both channels simultaneously of a stereo track.
- Moroccomoose
