outboard compressor
outboard compressor
Post by georgeeboy »
Hi,
please help...i have connected my sta level retro comp to my daw and have it up and running great on any audio channel insert.When i use it as an insert on any vst instrument track.. it only compresses one side of the signal...but works fine on audio...any ideas would be greatly appreciated...drivin me mad. :headbang:
georgeeboy
Posts: 59 Joined: Fri Oct 15, 2010 12:00 am
Re: outboard compressor
Post by Jack Ruston »
It's a single channel compressor. It can't be used to compress stereo sources unless they are first summed to mono.
Jack Ruston
How do i sum it to mono on vst instruments...do i have to open an insert then use the send to an fx channel..cheers
georgeeboy
Post by Richard Graham »
I'm pretty sure Reaper has a stereo to mono plugin to insert after your stereo instrument, to sum it to mono Alternatively, THIS looks good.
Richard Graham
Posts: 1800 Joined: Mon Apr 10, 2006 12:00 am Location: Gateshead, UK
"If a nail is bent, stop hitting it."
