Simple 2-buss transformer box
Post by Evie McCreevie »
I'm looking for a stereo, line level box with transformers - purely for the 'transformer sound' - to run mixes through.
I don't need multi-input summing, output to mic-input levels, compression or anything fancy... just +4 stereo line in and out through decent transformers (Cinemags, Lundahls etc).
Sounds simple, but does such a thing exist? Any suggestions?
Evie McCreevie
Posts: 445 Joined: Mon Sep 06, 2004 12:00 am Location: Dublin
Re: Simple 2-buss transformer box
Post by 77raymondo77 »
One here or if you're handy with a soldering iron get a pair of these 23-112 Lundahl LL 1540 Transformers, they work well as ground loop hum isolators but I'm not sure you'll get that full on analogue ABBA sound, even though they're made in Sweden. I wonder if el cheapos, mixed in parallel, would give you more 'character'.
77raymondo77
Posts: 5 Joined: Tue Jul 29, 2008 12:00 am
Thanks for the reply...
I've found a few similar DIY solutions online – but surely someone makes a ready-to-go box?
Evie McCreevie
Post by Exalted Wombat »
THIS is still my favourite. Nice big solid transformers. And you can't argue about the price.
It's much more about recording good instruments, played well, in a nice room though. You can always turn the treble down a bit for a nice "mellow" sound.
Edited by James Perrett to fix link
Exalted Wombat
Posts: 5846 Joined: Sat Feb 06, 2010 12:00 am Location: London UK
Hi Evie!
I know you're after a ready built solution, but have you read this entertaining thread on the DIY approach with plenty of examples?
http://www.soundonsound.com/forum/showf ... ber=897262
That Canford box could well be a little 'too' good if you want to add some flavour to your mixes - they quote '+/- 1.0dB, 40Hz-20kHz' and 'Better than 0.015% / 1% , 1kHz / 30Hz, +22dBu'.
I'd certainly be pushed to hear 1% of distortion at 30Hz in the context of a mix, and that's assuming that you can push the peak level up to +22dBu to achieve it :beamup:
Posts: 22577 Joined: Wed Jan 13, 2010 8:44 am Location: Cornwall, UK
Post by JonathanRace »
I know there was one made for the Api lunchbox which looked pretty good. Had switchable transformers as well for different 'flavours' can't remember the name of it atm though I'm afraid.
JonathanRace
Posts: 47 Joined: Sun Jun 22, 2014 12:00 am
I'd go with EW's ground loop isolator suggestion to start with - they're likely to be easier to saturate than a more expensive transformer though whether you like that sound is a different matter.
What design features would make a transformer easy to saturate?
Exalted Wombat
Transformer cores are far from perfectly linear and, in general, the smaller they are, the lower the current required to saturate the core. A decent pro-audio line level transformer is normally far larger than that Maplin box so I would deduce that the 2 transformers in there are fairly small and therefore saturate at a lower current.
As a youngster I remember messing around with small interstage coupling transformers from a cheap intercom - you could make some interesting sounds with them.
I must open up one of my Maplin units and see just what's inside. There's certainlt been no attempt to miniaturise. It may be absolute crap. It may just be than no-one told the manufacturer something competent deserved a higher price point.
It would also be interesting to test just what (if anything) is wrong with THIS. Don't forget we seem to be LOOKING for grunge, not a straight wire with ground lift.
Exalted Wombat
Not really looking for 'grunge' - this is the angle I'm coming from...
I have tried summing (including a pricey SSL setup) without being overly impressed. At the same time, number of equipment reviews have concluded that any sonic benefit from summing boxes can most likely be attributed to circuitry such as transformers, rather than the summing process itself. In other words, that processing a stereo mix (rather than a bunch of stems) is just as effective.
Back in 2006, the (largely positive) SOS review of the Audient Sumo said: "Personally I could hear very little difference between using the Sumo as a mixer and using it to process a stereo Logic mix. This being the case, perhaps there's a potential market for a two-channel unit for those of us who can't justify the cost of a Sumo? "
Eight years later, you'd imagine there'd be a few transformer-laden, 2-buss processing boxes on the market, promising to add all manner of 'weight', 'solidity', 'smooth highs' etc.
But where are they?
Evie McCreevie
Evie McCreevie wrote:Not really looking for 'grunge' - this is the angle I'm coming from...
But where are they?
It's unlikely that a gear-based magazine is ever going to QUITE come out and say "this is audiophool BS" (though, to SoS's credit they HAVE confirmed that most of us don't need master clocks and, whatever premium mic preamps may be about, they aren't much about detectable sonic difference when used "clean" - yes, my hobby-horse, but it obviously bears repetition.) They said "there might be a potential market...." Maybe the fact that there apparently wasn't should be telling you something...
Exalted Wombat
There are plenty of expensive 2 channel boxes with transformers but they tend to do other things like eq or compression as well. I doubt that most manufacturers would make a simple audiophile transformer isolator box at a sensible price either as the main market for such a device is people who would pay through the nose for the marketing BS.
However, there is one manufacturer that does make a sensibly specced transformer device at a sensible price. I'd suggest taking a look at the Orchid Electronics Dual Isolator.
Hmm? All seems a bit R.A. to me.
In any case the better the transformer the less you will"hear" it. The BBC et al did not use such expensive devices for their sound but because they had to!
Tell you what. Build the box with some nice Cineies' whatever then clank it onto the back of a handy guitar speaker. You will then get some nice even harmonics!
Post by Dr Huge Longjohns »
Can someone explain what this is to me? Cheers.
Dr Huge Longjohns
Posts: 3953 Joined: Thu Apr 10, 2003 12:00 am Location: Gallifrey
Certainly Huge...It's BOLLOXS!
Yeah sure, it's all bollocks... Check out Hugh Robjohns talking utter shite:
http://www.soundonsound.com/sos/feb10/a ... warmth.htm
http://www.soundonsound.com/sos/feb08/a ... 0208_2.htm
Evie McCreevie
Quite! A reasoned and in depth examination of the subtle effects of various non-linear devices on sound quality.
Not "Bolt any old traff onto your line outs and get superb, retro warmth"!
Or! Put it another way? COMPLICATED BOLLOX.
OK, thread back on topic...
Thanks for the suggestions so far, though it looks like some DIY/soldering is on the cards – unless anyone has any other ideas?
Evie McCreevie
Hi Evie,
It does look like DIY is the solution to me.
Why not add a post to that existing DIY forum thread I pointed you at earlier and we can discuss it further?
I've had an interest in doing this myself, but never got around to it. However, I HAVE amassed a good list of URLs with further info on other folk who have done it to good effect, with build details, examples of transformers used, and so on.
If you decide to post in that thread I'll be happy to provide you with my list.
Martin Walker wrote:Hi Evie,
Done!
Evie McCreevie
And my list of links is now finally in place too :crazy:
Hope it helps!
