neodymium vs ferrite magnets in loudspeakers
Post by AdiT »
Why the manufacturers of speakers/loudspeakers have not switched to production of speaker with neodymium magnets (especially, those for low freq). In the past two years, are producers who have won several international awards, some even innovation awards, with speakers that use ferrite magnets.
I know there are manufacturers who use neodymium magnet but represent a small percentage.
AdiT
Posts: 297 Joined: Fri Aug 29, 2014 12:00 am
Re: neodymium vs ferrite magnets in loudspeakers
If ferrite can generate the required flux density within acceptable size and weight constraints, why go to the expense of neodymium?
Posts: 43683 Joined: Fri Jul 25, 2003 12:00 am Location: Worcestershire, UK
Post by shufflebeat »
While we're at it, can we agree a pronunciation?
...of the N word, that is.
shufflebeat
Posts: 10109 Joined: Sun Dec 09, 2007 12:00 am Location: Manchester, UK
neo·dym·i·um \ˌnē-ō-ˈdi-mē-əm\
Post by Logarhythm »
Hugh Robjohns wrote:If ferrite can generate the required flux density within acceptable size and weight constraints, why go to the expense of neodymium?
It makes a huge difference to the sound... of marketing communications ;)
Logarhythm
Posts: 1093 Joined: Fri Mar 30, 2012 12:00 am Location: On an intergalactic voyage to collect fresh electrons
Hugh Robjohns wrote:neo·dym·i·um \ˌnē-ō-ˈdi-mē-əm\
Ta.
shufflebeat
It also makes a huge difference to the manufacturers bank balance.. coincidentally, yours too in the opposite direction.
Posts: 20876 Joined: Sat Nov 15, 2008 12:00 am Location: The Mudway Towns, UK
Post by IvanSC »
I can lift my 2x10 bass speaker box with one hand since I swapped the original ones for Celestion neos.
Same reason I have swapped out a lot of my gear. Size and weight.
IvanSC
Posts: 3041 Joined: Tue Mar 08, 2005 12:00 am Location: UK France & USA depending on the time of year.
Two bottles of Corona lemon and lime,  please!
IvanSC wrote:I can lift my 2x10 bass speaker box with one hand since I swapped the original ones for Celestion neos.
It makes a huge difference to your general fitness, as you don't get so much exercise :tongue:
Post by AdiT »
if we talk about weight, IMO line array systems used for mobile scene, have the most benefit from neodymium
AdiT
Post by BigRedX »
The main market for Neodymium loudspeakers are musicians who gig regularly and have to move their own gear without the benefit of a road crew. So full-range powered PA cabs and bass cabs are where all the innovations are being made and where you'll find people being enthusiastic about the technology.
It's not really an issue with permanent installations like studios, or bands who are successful enough to be able to employ people to move all their heavy speaker cabs about for them.
Also remember that neodymium speakers are not simply conventional ones with lighter magnets. As soon as the chassis no longer has to support the weight of traditional magnets, the designers have a lot more scope for saving even more weight and improving the performance of the speaker. This means that that neodymium based speakers are never going to sound the same as "traditional" ones. And as we all know in the field of audio, what is technically better is not always as pleasing to the human ear that has years of being attuned to a certain type of sound.
BigRedX
Post by AdiT »
If we take the speaker "A" and turns into a speaker with neodymium magnet "B" the only possible change that I see is some holes marked in red.
If you reduce the size of the chassis, will start to vibrate.
What other changes do you think are possible, to make it sound different?
AdiT
Post by IvanSC »
Chassis does not necessarily have to be made of sheet material.
A cast spider-style chassis would still be rigid enough without having to support the weight of a large magnet.
This has already been done many times in the past to very good effect.
In the early 60's my bass cabinet had a 22" speaker out of a juke box, which had a rigid spider fame made of cast aluminium.
Mind you it DID break pretty easily when I dropped it down a flight of concrete stairs leaving a gig! :lol:
I replaced it with two huge 1x18" Goodmans Audiom 90 reflex boxes! 50 watts handling capacity each!
Powered by a converted mono valve hifi amp made by (local company) Phillips. About 1963/4
IvanSC
Post by AdiT »
I agree that "Chassis does not necessarily have to be made of sheet material."
But chassis has a dual role.
Besides the support of the magnet which is very obviously, has one that is "hidden" must maintain the distance between the the voice coil, top plate and the bottom plate core. This distance must be as small as possible for high efficiency, so it is not possible for the chassis to vibrate neither 1 mm / 0.039 inch even at max output, because it would damage the coil and an variable magnetic flux would have negative consequences.
AdiT
But it doesn't take much to make a rigid frame to support a lightweight magnet. The forces involved aren't huge. Don't forget that most cones are made from paper and they don't break down under the forces involved. The same finger push that can poke a hole in the parer cone will only distort a sold chassis by a few microns.
My experience of the neo speaker has been limited to the Celestion Century and the feedback I read in forums from guitarists.
It is generally tolerated but not raved about, but then there are those that don't like anything that is not a V30!
The problem is always the cost. A brief varder found the Neo at £112 and the V30 at £77 and of course that gets to serious wonga for a 4x`12! Mind you the weight saving for multiples is significant. The Century is also a couple of dB less sensitive than the 30 but I can't help feeing that if the V30 and neo were comparable in price folks would take to the lightweight speaker better?
A very personal and unscientific observation..The Blackstar S1 45 combo was for a long time loaded with two Centuries. You know in all my time at Bs I never had a punter say "these speakers are ***t!" Sadly the cost has now become prohibitive and the combo is loaded with V30s and is consequently now almost as much of a brute to shift as the A30 combo.
Posts: 19140 Joined: Mon May 29, 2006 12:00 am Location: northampton uk
I had an S1 45 with the Centuries (and even that was a brute to shift). But I didn't like the speakers much as there seemed to be very little bottom end from them. My 10" HT5 put out more bass. Not sure if that was due to the cab, speakers or a combination of both. I was contemplating swapping the speakers out for V30s or similar, but the thought of even more weight put me right off that idea.
Wonks wrote:I had an S1 45 with the Centuries (and even that was a brute to shift). But I didn't like the speakers much as there seemed to be very little bottom end from them. My 10" HT5 put out more bass. Not sure if that was due to the cab, speakers or a combination of both. I was contemplating swapping the speakers out for V30s or similar, but the thought of even more weight put me right off that idea.
Loss of LF, a "thin" sound is the most common reaction on forums to the Century but it is hard to know if that is a psychological effect? "Light speaker. Light sound" or a real one. Your experience Wonks tends to suggest it is a real quality. One is paused to wonder why Celestion did not just produce a low weight "copy" of the V30? Maybe some technical reason?
The S1 45 cab is about the same size as the A30 and the Stage 60 (that is a BEAST!)so no change there. I take it you no longer have the 45 Wonks? It would have been interesting for you to try it into another speaker. At a pinch and with care over levels the G10N-40 in the HT 5 would have coped!
I've only just sold it as it was sitting around doing nothing except taking up space. Had it up and running shortly before that to check that it sounded like I remembered, and it did.
Certainly when compared to the Fender HR Deluxe I had at the time (with an alnico Jensen speaker) when I bought the S1 45, the Fender had a lot more bass and turning the bass up and the ISF to full Brit mode made very little difference.
Post by AdiT »
"The forces involved aren't huge."
Aren't ?
I give you two simple examples:
why in a club the clothes are shaking on you ?
why when you play at max volume a medium HI-FI sistem at home the furniture and the things on it are shaking ?
" Don't forget that most cones are made from paper and they don't break down under the forces involved."
because they are "stopped" only by the force of the spider and surround.
"The same finger push that can poke a hole in the parer cone will only distort a sold chassis by a few microns. "
the voice coil is "protected" by the spider and the surround which makes parts remain concentric in a stable frame.
AdiT
Meant to say Wonks...
You could have kept the 45 as a very big and quite expensive pre amp!
A touch OTT Dave. :D
Post by Mihai_dmg »
Well in my opinion neodymium magnets are a huge step for the touring sound systems. The only difference , but minimal, will be on Low frequency's, the neodymium cuts small, but pretty small amount of dynamic from the LF. If we can do a comparation will be like the difference between a medium quality analog sound console and a high-end digital sound console. When you look on specs on the same speaker , one with ferrite and the other with neodymium, you'll see a small boost to LF, but is just the LF are more colorful, defined. In Hi-Fi home systems the ferrite magnets are preferred, because they want to squize as much as possible quality from everything. Well this is my opinion, not sure if it;s true.
Mihai_dmg
Posts: 24 Joined: Wed Aug 06, 2014 12:00 am
Post by damoore »
Anybody know why you get a little less bass? Is it something intrinsic in the type of magnet, is it due to the lower mass of the entire unit, or are manufacturers making other trade-offs elsewhere to further reduce weight that result in less bass?
If it is the case that for some reason the voice coil moves less then one could compensate with eq, so the question is not entirely academic.
damoore
Posts: 981 Joined: Sun Jul 05, 2009 12:00 am Location: New Hampshire
damoore wrote:Anybody know why you get a little less bass? Is it something intrinsic in the type of magnet, is it due to the lower mass of the entire unit, or are manufacturers making other trade-offs elsewhere to further reduce weight that result in less bass?
In "properly" designed speaker systems, high magnet strength tends to give less bass (in a BBC paper about monitor design. Ls2 Hugh?) but guitar speakers are FAR from proper designs! Big enough baffle to take the drive unit(s), footprint dictated by likely head!)
But of course the geetar guys want loud! So high field strengths for high mid band sensitivity is the order of the day. There are so called "Thiel" designs for guitar, no idea what the rational is behind them or if they even work?
L.O.V.E. Someone from Cellies to come and set us all straight here!
