Good Headphones
Good Headphones
Post by matt222 »
Hi all,
I have a very small studio thats crammed with hardware so my Spirit Absolute Zero monitors are no doubt doing a pretty poor job - I have them in the corners of my room at head height as I tend to stand.
I don't have room to mount them anywhere else and my room has no acoustic treatment.
So, what's a good set of headphones for reliable monitoring/recording? I currently have a pair of Sennheiser HD580 which must be 15 years old.
matt222
Posts: 272 Joined: Sun Oct 25, 2015 12:00 am
Re: Good Headphones
Post by Sam Inglis »
What's your budget?
Sam Inglis
Posts: 3229 Joined: Fri Dec 15, 2000 12:00 am
Re: Good Headphones
Post by John Willett »
Buy new earpads for your HD 580 - job done
My HD 25 are 25 years old and still going strong, so your HD 580 are actually quite new; and still good headphones.
John Willett
Posts: 7297 Joined: Tue Mar 07, 2000 12:00 am Location: Oxfordshire UK
Re: Good Headphones
Post by Mixedup »
John Willett wrote:your HD 580 are ... still good headphones.
^ This.
You might also want a closed-back set for lower bleed while tracking. But while it's perfectly possible to get better headphones than the HD580, you'll have to spend a fair chunk of cash to do so. Which brings us back to Sam's question: do you have a specific budget in mind?
Mixedup
Posts: 4557 Joined: Wed Sep 03, 2003 12:00 am Location: Cambridgeshire, UK
Re: Good Headphones
Post by matt222 »
Being just a spare bedroom synth enthusiast wanting to make good quality recordings/demos, it sounds like the HD580's will do and yes, I've just got new ear pads and cable!
If I was to upgrade, I doubt I'd want to spend more than £250.
matt222
Re: Good Headphones
matt222 wrote:Being just a spare bedroom synth enthusiast wanting to make good quality recordings/demos, it sounds like the HD580's will do and yes, I've just got new ear pads and cable!
It will be more like a downgrade from the HD 580 if you only have £ 250 to spend.
The upgrade from the HD 580 would be a HD 600 or HD 650 minimum.
John Willett
Re: Good Headphones
Post by matt222 »
Well that's that then.
The HD650's can be found for £250 but if it's not going to make a significant improvement, there's no point.
matt222
Re: Good Headphones
matt222 wrote:Well that's that then.
Actually - I almost forgot - replace the plastic backs for the open mesh ones from the 600 or 650. The designer once told me that the 580 had originaly been designed to have these backs but was told to put plastic ones on instead. So,putting on the oen mesh ones would, basically, change the 580 into a 600 at nominal cost. I did tthis tomy own HD 580s. :D
John Willett
Re: Good Headphones
Post by IvanSC »
Keep thinking about buying some closed backs for tracking.
I already have a pair of HD650s and a couple of pairs of AKG K240DF and K141 that I have had since Adam was a lad.
I would also like a pair of HD600s in addition to the 650s, but that is just extravagance.... :bouncy:
IvanSC
Posts: 3041 Joined: Tue Mar 08, 2005 12:00 am Location: UK France & USA depending on the time of year.
Two bottles of Corona lemon and lime,  please!
Re: Good Headphones
Post by matt222 »
Mike Senior in his book, recommends Beyer DT 880 PRO for the tiny studio where good room acoustics are impossible.
Would these be worth moving to from Senheisser HD580?
matt222
Re: Good Headphones
Post by 4TrackMadman »
I have DT770s and love them, very comfortable for long sessions.
4TrackMadman
Posts: 1114 Joined: Wed Oct 30, 2002 12:00 am
Re: Good Headphones
Post by al_diablo »
I have the DT880s and I love them but I was just thinking - if you are used to the 580s and you can't use your larger monitors would it be worth buying some tiny monitors to replace them?
I got a pair of genelec 8010a when we moved into a flat and my monitors were too big / loud for the room
al_diablo
Posts: 227 Joined: Thu Jul 24, 2003 12:00 am
Re: Good Headphones
Post by oneflightup »
Yep Beyer DT770's are great sounding and very comfy. I also use some of the the 'classic' DT range in the live room, and never have any complaints.
oneflightup
Posts: 789 Joined: Tue Sep 01, 2015 12:00 am Location: Sydney, Australia
One Flight Up Recording Studios Sydney
Re: Good Headphones
Post by Zukan »
Dude can get 712 Pros for that budget.
Zukan
1-2-1 Tuition
Re: Good Headphones
Matt - whatever else you do - get new earpads for your HD 580 (and a headband pad as wellif it's worn) and the open backs for a 600 or 650 to replace the plastic backs of the 580.
It will make them like new and sounding as good as a 600.
John Willett
Re: Good Headphones
Post by The_BPP »
Zukan wrote:Dude can get 712 Pros for that budget.
+1 They're accurate, plus easy-on-the-ears. :D
The_BPP
Posts: 1399 Joined: Thu May 13, 2004 12:00 am Location: Lincolnshire
Touch & Go
Re: Good Headphones
As long as you remember that they need a *huge* burning-in time. I think 500 hours has been mooted by some and definitely well over 100 hours.
John Willett
Re: Good Headphones
Post by Mixedup »
John Willett wrote:As long as you remember that they need a *huge* burning-in time. I think 500 hours has been mooted by some and definitely well over 100 hours.
That might explain why I couldn't abide them, then!
Mixedup
Re: Good Headphones
Post by The_BPP »
Indeed, I was a burn-in skeptic until I got a pair of these... The K812's have the same problem. :frown:
The_BPP
Touch & Go
Re: Good Headphones
John Willett wrote: As long as you remember that they need a *huge* burning-in time. I think 500 hours has been mooted by some and definitely well over 100 hours.
Hey John,
What would you say are the benefits of the burn-in period? Is the freq. response more even after the burn-in?
Cheers,
OFU
oneflightup
Re: Good Headphones
Hey John,
Cheers,
OFU
Basically - they sound horrible before the burn-in and fine after.
Personally, I use teh Sennheisers who need very little burn-in - the 500 hours for the AKG I got from a good friend who has the AKG
John Willett
Re: Good Headphones
100 or so hours and you're 95% there.
Posts: 19210 Joined: Thu May 29, 2003 12:00 am Location: Freethorpe, Norfolk, UK
Re: Good Headphones
Post by Pete Kaine »
Same here... I did wonder what all the fuss was about. I suppose I'm going to have to revisit them again.
Pete Kaine
Posts: 3217 Joined: Thu Jul 10, 2003 12:00 am Location: Manchester
Re: Good Headphones
Post by The_BPP »
Honestly, the difference between pre-burn-in and post-burn-in on AKG's (of which, I have two pairs) is night-and-day, it's not some slight, perceivable improvement.
The_BPP
Touch & Go
Re: Good Headphones
Post by Dynamic Mike »
The_BPP wrote:Honestly, the difference between pre-burn-in and post-burn-in on AKG's (of which, I have two pairs) is night-and-day, it's not some slight, perceivable improvement.
Yep. I was a total skeptic regarding 'burn in' until I got a pair of 702's. You certainly don't need golden ears to appreciate it.
Dynamic Mike
Posts: 5291 Joined: Sun Dec 31, 2006 12:00 am
