Need a simple fade transition between videos
Post by Konrad Chan »
Hi, I'm wanting to add some visuals to our gigs, but I want to do it very simply: edit some visuals as video files and transition between videos with a fade when we change songs. I was hoping I could do it with Keynote or some default app that's on my macbook, but when you switch slides on keynote, the videos freeze until the transition is complete. Does anyone have any ideas? I'm not interested in getting technical with visuals at this stage, since I've got enough on my plate with the performance aspect. Just something I can press a button between songs to switch the visual.
Konrad Chan
Posts: 1 Joined: Fri Apr 01, 2016 12:00 am
Re: Need a simple fade transition between videos
Post by Just Andy »
Hi Konrad,
Have a look here - http://www.mix16apps.com
I use the iPad version for video playback, and it allows fades to be set per video. I assume the Mac version does too.
And it's simple enough not to get in the way when also playing.
Andy
Just Andy
Posts: 8 Joined: Mon Jun 17, 2002 12:00 am Location: UK
justfloyd.co.uk Live rig: Kurzweil PC3K, DSI Mono and/or Poly Evolver Keyboards, Hammond XK1c with custom lower manual, Yamaha VL70m
Post by MarkPAman »
Or take a look at Q Lab on a Mac. The free version should be enough for your requirements.
MarkPAman
Posts: 1020 Joined: Thu Apr 06, 2006 12:00 am Location: Somewhere between Portsmouth & Chichester
Post by seablade »
MarkPAman wrote:Or take a look at Q Lab on a Mac. The free version should be enough for your requirements.
Not sure you can do video crossfades on the free version, but yes a basic video license would certainly do it, which could be rented for about $3/day to try it out if needed.
You could also look at software like ProPresenter, or most VJ software I would imagine would do this.
Seablade
seablade
Posts: 1156 Joined: Sun Nov 21, 2004 12:00 am
Post by The Red Bladder »
Reaper
The Red Bladder
Posts: 3907 Joined: Tue Jun 05, 2007 12:00 am Location: . . .
